ANreZZ
                (ANDRES COMERON)
                    November 18, 2022,  6:05pm
              Hello everyone,
As I did at the time with a bpi p2 zero and rasbian, I have tried to transfer the image from the SD to the EMMC in a bpi p2 zero with armbian.
The problem I’m running into is that now the EMMC is identified as mmcblk2 instead of mmcblk1 and the bpi-copy command doesn’t work.
I have looked with GPARTED, and currently the EMMC has a partition made in FAT32.
Can someone help me transfer armbian to EMMC?
Thank you very much
                igorpec
                (Igor)
                    November 18, 2022, 11:06pm
              2
                ANreZZ
                (ANDRES COMERON)
                    November 20, 2022, 10:56am
              3
              Thank you very much for the information.
I followed the steps, and apparently the information has been copied to the EMMC but I can’t get it to boot from there.
Following the thread, I understand that I must enter the commands:
then cp /boot/script.bin /boot/script.bak (for safety)
then “bin2fex /boot/script.bin /tmp/script.fex” (or to another directory e.g. /root …)
- then   Change sdc_detmode from 3 to 1 in the script.fex
then “fex2bin /tmp/script.fex /boot/script.bin”
then boot systen with e.g. reboot
But in my bpi p2 zero I haven’t the file script.bin
What can I do?
Thanks!
                igorpec
                (Igor)
                    November 20, 2022,  6:11pm
              4
 ANreZZ:
What can I do?
Follow one instructions, those which I gave you.
                ANreZZ
                (ANDRES COMERON)
                    November 20, 2022,  7:05pm
              5
              Hello Igor,
Thanks for helping me. I am not sure if the first link you sent me is ok (new profile), because when I go there I find 2 additional links and I don’t understand which steps I must follow.
Could you explain me that please?
Regards,
