What do I need to change the configuration BPI-SINOVOIP / BPI-M3-bsp to be able to configure the kernel using the direct Banana-Pi-M3 running debian jessie ?
The script that I posted before should have all the necessary information for you to build a fresh mainline kernel with jessie.
Did that not work for you ?
Cheers,
Damien
??? What script ? Any further information ?
I thought that you had tested it before ? I can’t seem to find it on the forum anymore though, so perhaps they deleted it for some reason shrug
Anyway, I will upload it to my webserver so that they can’t take it down. http://tusker.org/buildBananaPiM3OnSdCard.sh
Cheers,
Damien
Yes , I remember . But it was armbian forum. Your script is not working yet quite correctly . Tonight will test this new and let you know . Greetings
@tusker I found a few bugs and I test the script on to your part … " ${SDCARD}1" must be “${SDCARD}p1” /// Line 31,47,49
Line51 “qemu-debootstrap”… - only “debootstrap” …(?)
After compiling the kernel - - .“dtb” (sun8i-a83t-sinovoip-bpi-m3.dtb) has not been generated… (Errors)
…Work in Progress… Great…
The 1 vs p1 is in relation to the type of driver used to load the device. Perhaps SDCARD needs to have two variables, SDCARD and SDCARD_PARTITION_ONE, where SDCARD_PARTITION_ONE defaults to ${SDCARD}1.
Ie, when I insert a USB storage device, I get the following:
[117453.388577] scsi host6: usb-storage 3-1:1.0
[117455.087561] scsi 6:0:0:0: Direct-Access Sony Storage Media 0100 PQ: 0 ANSI: 0 CCS
[117455.088008] sd 6:0:0:0: Attached scsi generic sg2 type 0
[117455.088146] sd 6:0:0:0: [sdc] 31303680 512-byte logical blocks: (16.0 GB/14.9 GiB)
[117455.088605] sd 6:0:0:0: [sdc] Write Protect is off
[117455.088607] sd 6:0:0:0: [sdc] Mode Sense: 43 00 00 00
[117455.089078] sd 6:0:0:0: [sdc] No Caching mode page found
[117455.089081] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[117455.102043] sdc: sdc1 sdc2
[117455.103672] sd 6:0:0:0: [sdc] Attached SCSI removable disk
qemu-debootstrap is necessary, since it sets up the cross architecture setup correctly. You can find it in debian/ubuntu package qemu-user-static
Let me know if that sorts it out for you!
Cheers,
Damien
I use SDCard physical - not USB - Stick…
At night I will continue to work…
Great
Ubuntu was the authoring environment, so the dmesg posted and the qemu-user-static package relates to the building/authoring system
can reference this document:
W: Target architecture is the same as host architecture; disabling QEMU support
I: Running command: debootstrap --arch armhf --verbose --include=linux-image-armmp-lpae,locales,sunxi-tools,firmware-linux,ssh,debconf --components=main,non-free jessie /mnt/NEW http://ftp.at.debian.org/debian/
to be continued
