Can't get any image to boot
This is my first time using banana pi. I picked up a BPI M2 Zero (Allwinner H3 chip) to replace a raspberry pi zero.
I can’t get any image I load onto the sd card to boot past the startup screen, some images don’t even make it that far. I tried the latest available images I could find for:
  • Armbian desktop
  • Raspbian
  • RetrorangePi
  • Libre
Any advice would be appreciated, thank you :slight_smile:
Check those topics and act: https://forum.armbian.com/forum/31-sd-card-and-psu-issues/
Which software do you use to write the image to sdcard? I prefere blenaEtcher
I’ve been using balenaEtcher to write the images to sd card. Also been formating the sd card before writing each image to test on the BPI-m2 zero
