MelRol
(MelRol)
September 26, 2022, 3:34pm
Hello !
I want to change the boot logo to have a custom one on my Banana-Pi (I tried on the M2 zero and the M2 berry with a 16 Gb SD card).
I tried two solutions, and both does not work:
With Raspbian:
I followed this tutorial: How To Change The Boot Logo but every time I have “u-boot error 2"
With Armbian:
I tried to build new image for the Banana Pi by following the tutorial and using this : GitHub - armbian/build: Armbian Linux build framework generates custom Debian or Ubuntu image for x86, aarch64, riscv64 & armhf but it does not boot (black screen)
Does somebody know these errors and how to fix this? Or have other ways of doing it, I am open to different ideas.
Thanks !
igorpec
(Igor)
September 26, 2022, 4:57pm
2
Try harder Check 1st if automated builds works https://github.com/armbian/community (berry = ultra )
Automated testings shows no troubles:
OS: Armbian (22.08.0-trunk) armv7l
Host: Banana Pi BPI-M2-Ultra
Kernel: 5.15.69-sunxi
Uptime: 4 hours, 14 mins
Packages: 968 (dpkg)
Shell: zsh 5.9
CPU: Allwinner sun8i Family (4)
Memory: 154MiB / 2013MiB
MelRol
(MelRol)
September 27, 2022, 10:56am
3
Thanks
Yes the automated builds works !
But i still can’t make it work when i am building it myself
igorpec
(Igor)
September 27, 2022, 4:35pm
4
Did you read system requirements well? Perhaps using WSL to build image? What is inside output/debug/ logs ? Boot logo chaining procedure you are referring is 100% not compatible …
MelRol
(MelRol)
September 28, 2022, 1:46pm
5
Thanks, I am using a virtual box virtual machine (ubuntu 22.04 and unbuntu mate) they have 4 threads and 3 Gb of RAM. now i have something different :
it can’t fetch some packages, does it means it is down and i have to wait or do i install them manually. i also have “errorCode=5 Too slow Downloading speed”
i am building an image for the banana-pi M2 ultra.
igorpec
(Igor)
September 28, 2022, 2:16pm
6
That is pretty irrelevant.
https://docs.armbian.com/Developer-Guide_Build-Options/
Try * NO_APT_CACHER ( yes | no ): disable usage of APT cache. Default yes in containers, but can be overridden
MelRol
(MelRol)
September 29, 2022, 2:42pm
7
Thanks a lot now it works !
