Hi ray,
Due to mt7622 hardware is different from others SoC like mt7629/mt7623…
(mt7622 gpio pinmux function in pinctrl registers is mode 1, not mode 0 )
So we need to upgrade the common part of mediatek pinctrl to fix this problem.
I’ve been busy recently and I just finished patches today,
We still working on ethernet and mediatek switch.
https://patchwork.ozlabs.org/project/uboot/list/?series=146912
Hi Sam,
yeah, got it while ago. But did not help. Maybe your pinctrl patches will help.
@sam33 @moore @Ryder.Lee can’t get it, why are you guys using FDT as local config for u-boot, instead of put it full and pass to kernel?
Thanks!
Patches based on this series: http://patchwork.ozlabs.org/cover/1191085/
have applied them to this tree for testing (build.sh not yet changed to support r64):
compiled it with aarch64 crosscompiler works except warning about CONFIG_OF_EMBED (Please use CONFIG_OF_SEPARATE for boards in mainline), tried booting it via my 2014 uboot over tftp results in crash
BPI-R64> setenv ufile u-boot_2020.01-rc4-bpi-r64-v1.bin
BPI-R64> run ubootnet
ETH already turn on and power on flow will be skipped...
Waitting for RX_DMA_BUSY status Start... done
mt7531: mt7531_sw_init
mt7531: mt7531_core_pll_setup, hwstrap = 000000ff
mt7531: mt7531_mac_port_setup, port = 6
mt7531: mt7531_set_port_sgmii_force_mode, port = 6
mt7531: timeout waiting for SGMII_LINK
mt7531: mt7531_mac_port_setup, PMCR6 = f805633b
0x1b000014 = 0x00110214
Using mtk_eth device
TFTP from server 192.168.0.10; our IP address is 192.168.0.19
Filename 'u-boot_2020.01-rc4-bpi-r64-v1.bin'.
Load address: 0x41dffe00
Loading: T ################################
85.9 KiB/s
done
Bytes transferred = 463504 (71290 hex)
get filesize 0x71290
## Starting application at 0x41E00000 ...
data abort
pc : [<41e0000c>] lr : [<7ef3bc48>]
sp : 7cf32be0 ip : 00000030 fp : 7ef3bbfc
r10: 00000002 r9 : 7cf32f40 r8 : 7cf36e88
r7 : 7ef7883c r6 : 41e00000 r5 : 00000002 r4 : 7cf36e8c
r3 : 41e00000 r2 : 7cf36e8c r1 : 7cf36e8c r0 : 00000001
Flags: nZCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
is this caused by loading the 64bit uboot out of a 32bit (armhf) one?
The 2014 u-boot is 32bits, I think loading an 64 bits u-boot binary to dram, and running in 32 bits CPU mode will cause unexpected results…
I will send our ATF image for upstream u-boot to you in a few days, this ATF image is able to start u-boot in 64 bits CPU mode (default: stating 64 bits u-boot, and can keep holding the WPS button during boot-up to start 32 bits u-boot)
We use CONFIG_OF_EMBED for debug, and forgot to disable it in mt7622 rfb defconfig, But I haven’t tested that it can work with CONFIG_OF_SEPARATE or not
if i understand you right, currently we cannot test uboot due to missing ATF right? can i change arch in uboot before calling go command (after loading the binary)? currently i don’t want to flash it because i need ethernet-support for kernel-testing
I think it is hard to change 32/64 bits in u-boot from my limited knowledge of Arm Cortex-A53.
If we want to change 32/64 bits cpu instruction set, We should use SPSR_EL3 registers to do that.
This register can only be used under ARM Secured World, In our case here, only ATF and pre-loader
are running in the Secured World.
mhm, seems like our ATF does not support 64bit uboot…
F0: 102B 0000
F5: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0000 0041 [0000]
G0: 0190 0000
T0: 0000 03BB [000F]
Jump to BL
UNIVPLL_CON0 = 0xFE000000!!!
mt_pll_init: Set pll frequency for 25M crystal
[PMIC_WRAP]wrap_init pass,the return value=0.
[pmic_init] Preloader Start..................
[pmic_init] MT6380 CHIP Code, reg_val = 0, 1:E2 0:E3
[pmic_init] Done...................
Chip part number:7622A
MT7622 Version: 1.2.7, (iPA)
SSC OFF
mt_pll_post_init: mt_get_cpu_freq = 1350000Khz
mt_pll_post_init: mt_get_mem_freq = 1600000Khz
mt_pll_post_init: mt_get_bus_freq = 1119920Khz
[PLFM] Init I2C: OK(0)
[BLDR] Build Time: 20181123-214255
==== Dump RGU Reg ========
RGU MODE: 4D
RGU LENGTH: FFE0
RGU STA: 0
RGU INTERVAL: FFF
RGU SWSYSRST: 8000
==== Dump RGU Reg End ====
RGU: g_rgu_satus:0
mtk_wdt_mode_config mode value=10, tmp:22000010
PL P ON
WDT does not trigger reboot
WDT NONRST=0x20000000
WDT IRQ_EN=0x340003
RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3)
[EMI] MDL number = 2
[EMI] DRAMC calibration start
[EMI] DRAMC calibration end
[EMI]rank0 size: 0x40000000
[MEM] complex R/W mem test pass
RAM_CONSOLE wdt status (0x0)=0x0
[mmc_init]: msdc1 start mmc_init_host() in PL...
[msdc_init]: msdc1 Host controller intialization start
[SD1] Pins mode(1), none(0), down(1), up(2), keep(3)
[SD1] Pins mode(2), none(0), down(1), up(2), keep(3)
[info][msdc_config_clksrc] input clock is 200000kHz
[SD1] Bus Width: 1
[SD1] SET_CLK(260kHz): SCLK(259kHz) MODE(0) DDR(0) DIV(193) DS(0) RS(0)
[msdc_init]: msdc1 Host controller intialization done
[mmc_init]: msdc1 start mmc_init_card() in PL...
[mmc_init_card]: start
[SD1] Bus Width: 4
[SD1] Size: 30436 MB, Max.Speed: 25000 kHz, blklen(512), nblks(62333952), ro(0)
[mmc_init_mem_card 3140][SD1] Initialized, SD10
before host->cur_bus_clk(259067)
[SD1] SET_CLK(25000kHz): SCLK(25000kHz) MODE(0) DDR(0) DIV(2) DS(0) RS(0)
host->cur_bus_clk(25000000)
[mmc_init_card]: finish successfully
[PLFM] Init Boot Device: OK(0)
[GPT_PL](BPI)Parsing Primary GPT now...
[GPT_PL]check header, err(signature 0x00000054594C5242!=0x5452415020494645)
[GPT_PL]Success to find valid GPT.
[PART] blksz: 512B
[PART] [0x0000000000020000-0x000000000007FFFF] "preloader" (768 blocks)
[PART] [0x0000000000080000-0x00000000000BFFFF] "tee1" (512 blocks)
[PART] [0x00000000000C0000-0x000000000013FFFF] "lk" (1024 blocks)
Device APC domain init setup:
Domain Setup (0x0)
Domain Setup (0x0)
Device APC domain after setup:
Domain Setup (0x0)
Domain Setup (0x0)
[get_part] part->nr_sects=768, part->info->name=preloader
[get_part] part->nr_sects=512, part->info->name=tee1
[get_part] part->nr_sects=1024, part->info->name=lk
[PART] Image with part header
[PART] name : U-Boot
[PART] addr : 41E00000h mode : -1
[PART] size : 462976
[PART] magic: 58881688h
[PART] load "lk" from 0x00000000000C0200 (dev) to 0x41E00000 (mem) [SUCCESS]
[PART] load speed: 3532KB/s, 462976 bytes, 128ms
load lk (ret=0)
[PART] name : atf
[PART] addr : FFFFFFFFh mode : -1
[PART] size : 62032
[PART] load "tee1" from 0x0000000000080200 (dev) to 0x43000DC0 (mem) [SUCCESS]
[PART] load speed: 2752KB/s, 62032 bytes, 22ms
load tee1 (ret=0)
[BLDR] bldr load tee part ret=0x0, addr=0x43001000
[BLDR] boot part. not found
[BLDR] part_load_images ret=0x0
[BLDR] Others, jump to ATF
[BLDR] jump to 0x41E00000
[BLDR] <0x41E00000>=0x1400000A
[BLDR] <0x41E00004>=0xD503201F
Seems that part is for me
Maybe linux even start with such limited tree, but w/o USB/PCI/Ethernet.
Idea to use FDT is just like PCs use ACPI. You don’t need own copy of ACPI ASL for each PC model. Bootloader (BIOS) pass it to OS. It just works and every modern OS parse it and find where is UART/PCI-RC/watchdog/etc.
i tried using the existing jump64smc function to load 64bit uboot binary from old uboot over tftp
this my quick&dirty way (uboot 2014-04):
diff --git a/common/cmd_boot.c b/common/cmd_boot.c
index 8f2e0701b5..540f504d34 100644
--- a/common/cmd_boot.c
+++ b/common/cmd_boot.c
@@ -45,6 +45,17 @@ static int do_go(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return rcode;
+static int do_go64(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
+ ulong addr;
+ addr = simple_strtoul(argv[1], NULL, 16);
+#if defined(CONFIG_MTK_ATF)
+ extern void jumparch64_smc(ulong addr, ulong arg1, ulong arg2);
+ jumparch64_smc(addr, 0, 0);
+#endif
+ //return do_go(cmdtp, flag, argc,argv);
+ return 0;
U_BOOT_CMD(
@@ -54,6 +65,13 @@ U_BOOT_CMD(
" passing 'arg' as arguments"
+U_BOOT_CMD(
+ go64, CONFIG_SYS_MAXARGS, 1, do_go64,
+ "start 64bit application at address 'addr'",
+ "addr [arg ...]\n - start 64bit application at address 'addr'\n"
+ " passing 'arg' as arguments"
#endif
U_BOOT_CMD(
results in this:
BPI-R64> setenv uboot64net 'tftp ${umtkaddr} ${ufile};go64 $uaddr'
BPI-R64> run uboot64net
86.9 KiB/s
done
[ATF][ 55.625586]save kernel info
[ATF][ 55.628626]Kernel_EL2
[ATF][ 55.631382]Kernel is 64Bit
[ATF][ 55.634570]pc=0x41e00000, r0=0x0, r1=0x0
INFO: BL3-1: Preparing for EL3 exit to normal world, Kernel
INFO: BL3-1: Next image address = 0x41e00000
INFO: BL3-1: Next image spsr = 0x3c9
[ATF][ 55.652234]el3_exit
U-Boot 2020.01-rc4-bpi-r64-v1-00023-g8cc6bfc180-dirty (Dec 07 2019 - 10:53:57 +)
CPU: MediaTek MT7622
Model: mt7622-rfb
DRAM: 256 MiB
WDT: Started with servicing (60s timeout)
MMC: mmc@11230000: 0, mmc@11240000: 1
In: serial@11002000
Out: serial@11002000
Err: serial@11002000
Net: No ethernet found.
MT7622>
DRAM seems to be wrong…
i can access both mmc devices (need FS_GENERIC and CMD_FAT)
MT7622> ls mmc 1:1
bananapi/
0 sd.txt
8841288 uImage_5.4
23721 bpi-r64-5.4.dtb
3 file(s), 1 dir(s)
MT7622> ls mmc 0:1
bananapi/
0 emmc.txt
1 file(s), 1 dir(s)
MT7622>
tried now loading kernel, but it seems not working (maybe because it is wrapped into 32bit container via mkimage)
MT7622> setenv kaddr 0x44000000
MT7622> setenv dtaddr 0x47000000
MT7622> setenv bootargs console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait ipp
MT7622> fatload mmc 1:1 ${kaddr} uImage_5.4
8841288 bytes read in 613 ms (13.8 MiB/s)
MT7622> fatload mmc 1:1 ${dtaddr} bpi-r64-5.4.dtb
23721 bytes read in 4 ms (5.7 MiB/s)
MT7622> bootm ${kaddr} - ${dtaddr}
## Booting kernel from Legacy Image at 44000000 ...
Image Name: Linux Kernel 5.4.0-rc1-r64
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 8841224 Bytes = 8.4 MiB
Load Address: 40080000
Entry Point: 40080000
Verifying Checksum ... OK
## Flattened Device Tree blob at 47000000
Booting using the fdt blob at 0x47000000
Loading Kernel Image
Loading Device Tree to 000000004f7f3000, end 000000004f7fbca8 ... OK
Starting kernel ...
F0: 102B 0000
F5: 0000 0000
00: 0000 0000
G0: 0190 0000
T0: 0000 0342 [000F]
Jump to BL
it hangs on “starting kernel” till watchdog reset occours
after changing the mkimage-command in my kernels build.sh this way:
mkimage -A arm64 -O linux -T kernel -C none -a 40080000 -e 40080000 -n "Linux Kernel $kernver$gitbranch" -d arch/arm64/boot/Image ./uImage_nodt
i’m able to boot kernel
MT7622> setenv bootargs console=ttyS0,115200 root=/dev/mmcblk1p2 rw rootwait
MT7622> fatload mmc 1:1 ${kaddr} uImage_5.4_64
8581192 bytes read in 588 ms (13.9 MiB/s)
MT7622> fatload mmc 1:1 ${dtaddr} bpi-r64-5.4_64.dtb
24264 bytes read in 3 ms (7.7 MiB/s)
for wrong DRAM value i tried modifying the memory-node in arch/arm/dts/mt7622-rfb.dts matching same reg as in linux (except in linux memory-node is 64bit by globally #address-cells = <2>;#size-cells = <2>; in mt7622.dtsi)
memory@40000000 {
device_type = "memory";
- reg = <0x40000000 0x10000000>;
+ reg = <0x40000000 0x40000000>;
now i see
DRAM: 1 GiB
but after this is printed board hangs
i tried to adjust CONFIG_NR_DRAM_BANKS to 2 and 4 without success
ATF image for 64 bits u-boot
mt7622_ATF_32_64_release.img (61.1 KB)
thank you
i was able to start new uboot directly with this ATF
U-Boot 2020.01-rc4-bpi-r64-v1 (Dec 09 2019 - 07:43:54 +0100)
Model: mt7622-rfb
DRAM: 256 MiB
In: serial@11002000
MT7622>
steps to write ATF if anyone else also want to test it
ATF=~/Downloads/mt7622_ATF_32_64_release.img
O=/dev/sdb
sudo dd if=$ATF of=$O bs=1k seek=512
made a quick test with WPS-button to start old uboot using this ATF…works…is it possible to invert the button-handling (not press boot 32,press boot 64)?
[BLDR] <0x41E00000>=0xEA00000F
[BLDR] <0x41E00004>=0xE59FF014
U-Boot 2014.04-rc1-00045-g955f02c553 (Dec 09 2019 - 07:53:38)
DRAM: 1008 MiB
relocation Offset is: 3d134000
WARNING: Caches not enabled
Now running in RAM - U-Boot at: 7ef34000
any idea about DRAM?
I think it’s mm_region problem.
I forgot to consider bpir64 1Gb dram.
You can modify mt7622_mem_map in.
“arch/arm/mach-mediatek/mt7622/init.c”
The size of first mm_region of mt7622_mem_map[] should be 0x40000000UL to support both RFB and BPIR64.
I will send a v2 patch to fix this problem.
Greate idea, it is possible to invert the button-handling for ATF jump to 32/64 bits u-boot.
I will send this to you recently.
Ok~ It seems that I should use FDT and CONFIG_OF_SEPARATE to check it works or not.
In the previous development, I was only through the uImage + bootm command to test it.
in my tests it worked…see my tree https://github.com/frank-w/u-boot/commits/2020-01-bpi-r64-v1
i have OF_SEPARATE already active
and load kernel like posted above with “bootm $kaddr - $dtaddr”
it is important to use aarch64 uImage not arm uImage like the 32bit uboot (mkimage command)
DRAM is now 1Gib
thank you
till ethernet is working it is better for us press button to go to new uboot…if all is working there we can use the 64bit default atf
it looks like the go64 does not work with the new ATF ;( is something different to the bpi version in 32bit way? i cannot even start kernel there…seems that the jump64_smc target is missing to go back to 64bit-mode…is there the sourcecode of ATF (yours/bpi)?
Is go64 work in 2014 u-boot with new ATF ?
Or it only not work in upstream u-boot with new ATF ?
go64 is my own function in old 32bit uboot (my repo) to switch to 64bit mode (to load new 64bit uboot binary). See here. This uses existing jumparch64_smc which was used to start 64bit kernel. Both is not working with new ATF in 32bit-mode (wps button).
Upstream uboot is 64bit and does not not need this switch. The switch is needed only in 32bit (2014) uboot and does only work in bpi’s ATF not in 32bit mode of yours
If ethernet will be ready soon i can switch completely,but i guess it’s much work so my main uboot needs to be the old and i want to be able to load new one for testing without permanently flashing it
waiting for v2 show up in patchwork…seems it hangs, got mails but cannot export to mbox
@sam can you tell me adress for exception (smc) handler in your atf which is used for switch to 64bit mode?
i don’t know why there is a fixed address and not the smc-command above which seems to be commented out
OK, I know the root cause of this …
The SMC handler of jumparch64_smc was gone …
I will update a new version, and also provide WPS button 32 bits & WPS button 64 bits (In previous discussion) images to you.
“… and this lets us keep the files otherwise unchanged from the Linux kernel we import them from.”
But that can be committed later.
Thanks.
