[BPI-R4 | Solved] Bad 10gbit sfp performance?
Hi, i just got my 10gbit connection but somehow i only get about 1gbit (up+down). So i am not sure if this is a provider problem or something in the r4/openwrt.
root@OpenWrt:~# ethtool eth2
Settings for eth2:
	Supported ports: [ FIBRE ]
	Supported link modes:   10000baseLR/Full
	Advertised link modes:  10000baseLR/Full
	Speed: 10000Mb/s
	Duplex: Full
	Port: FIBRE
	PHYAD: 0
	Transceiver: internal
	Auto-negotiation: on
	Link detected: yes
I already rebooted, running openwrt snapshot from maybe a week ago. To me, it looks ok on my side (imo), so probably an ISP problem? Anyone an idea how to figure out more?
edit: it cant be lan3 as this is a 1gbit port :smiley: i changed it now to the first sfp+ rj45 port, but still only 1gbit. so i checked eth1 (thats the port)
root@OpenWrt:/tmp# ethtool eth1
Settings for eth1:
	Supported link modes:   1000baseX/Full
	Advertised link modes:  1000baseX/Full
	Link partner advertised link modes:  1000baseX/Full
	Link partner advertised pause frame use: Symmetric Receive-only
	Speed: 1000Mb/s
	Duplex: Full
	Port: FIBRE
	PHYAD: 0
	Link detected: yes
looks to me there is really a problem with this auto-negotiation thingen?
root@OpenWrt:/tmp# ethtool -A eth1 rx off tx off autoneg off
Cannot get device pause settings: Not supported
root@OpenWrt:/tmp# ethtool -s eth1 speed 10000
Cannot advertise speed 10000
is this sfp-rj45-adapter crap? :confused:
edit 2:
root@OpenWrt:/tmp# ./speedtest-netperf.sh -H netperf-eu.bufferbloat.net
2024-05-07 11:12:03 Starting speedtest for 60 seconds per transfer session.
Measure speed to netperf-eu.bufferbloat.net (IPv4) while pinging gstatic.com.
Download and upload sessions are sequential, each with 5 simultaneous streams.
 Download: 2264.54 Mbps
  Latency: [in msec, 61 pings, 0.00% packet loss]
      Min:   2.254
    10pct:   2.310
   Median:   2.466
      Avg:   2.471
    90pct:   2.614
      Max:   2.709
 CPU Load: [in % busy (avg +/- std dev) @ avg frequency, 58 samples]
     cpu0:  55.5 +/-  5.3  @ 1500 MHz
     cpu1:  13.7 +/-  3.2  @ 1500 MHz
     cpu2:  21.1 +/-  6.8  @ 1500 MHz
     cpu3:  13.7 +/-  3.5  @ 1500 MHz
 Overhead: [in % used of total CPU available]
  netperf:   8.6
   Upload: 3731.88 Mbps
      Min:   2.213
    10pct:   2.239
   Median:   2.343
      Avg:   2.377
    90pct:   2.525
      Max:   2.680
     cpu0:  16.0 +/-  4.1  @ 1500 MHz
     cpu1:   8.5 +/-  2.7  @ 1500 MHz
     cpu2:  17.4 +/-  1.4  @ 1500 MHz
     cpu3:   6.4 +/-  2.6  @ 1500 MHz
  netperf:   5.0
So it seems like this sfp-rj45-adapter is crap i guess? Or is this a driver problem?
From where to where do you test? Switchports (existing rj45 - wan,lan0-lan2) are only 1g.
10g are only the sfp (eth1 and eth2). Eth2 shows 10g,eth1 only 1g linkspeed.
Please not that we have not yet 10G working,only ~4.5g due to missing rss/lro support in mainline code
i test from: my workstation → eth1 (rj45 sfp+) → speedtest.net
eth1 is a sfp+rj45-10gbit-adapter, so i assume there is some problem with the driver
Please try without forwarding,step by step,so if your provider is connected on eth2 (wan sfp) then make speedtest over this only first.
thats what i did, and reached about 2.5gbit down and 3.5gbit upload, see above the speedtest-netperf.sh
Ok,sorry,so this test was eth2,right? As eth1 is only supporting 1000Mbit/s (1G) speed acording to ethtool…are you sure is should be a 10G adapter?
What does ethtool -m eth1 say and maybe dmesg?
i will answer in a couple days, i am now at another location for the next 3-4 days. it should be 100% a 10g rj45-sfp-adapter
I think one of the SFP is only 2.5Gbps to data throughput. The other one I have tested at 5Gbps so trying in the other socket might be worth a try. Some extra features like LRO and RSS are needed to reach higher than that.
For me it sounds like the 3.5g/2.5g are ok (maximum from ISP) and only the other sfp is the problem which only supports 1g mode based on ethtool output
close, yes. Max from ISP is 10/10, but its totally fine for me to have only 2 or 3gbit as long as no hw acceleration is possible. The other SFP is indeed a problem. It is this one: https://www.aliexpress.us/item/3256805471213618.html
Without rss/lro you should get ~4.5gbit/s if your isp supports it…
maybe speedtest.net does not provide more :wink:
i will test again when i am back home
measured again:
root@OpenWrt:/# speedtest-netperf.sh -H netperf-eu.bufferbloat.net
2024-05-10 14:37:24 Starting speedtest for 60 seconds per transfer session.
 Download: 2372.16 Mbps
      Min:   2.140
    10pct:   2.258
   Median:   2.446
      Avg:   2.435
    90pct:   2.562
      Max:   2.767
     cpu0:  56.2 +/-  3.2  @ 1500 MHz
     cpu1:  13.8 +/-  3.2  @ 1500 MHz
     cpu2:  20.5 +/-  3.1  @ 1500 MHz
     cpu3:  13.1 +/-  3.2  @ 1500 MHz
  netperf:   9.1
   Upload: 3914.68 Mbps
      Min:   2.131
    10pct:   2.191
   Median:   2.278
      Avg:   2.328
    90pct:   2.475
      Max:   3.155
     cpu0:  16.4 +/-  4.4  @ 1500 MHz
     cpu1:   7.8 +/-  2.7  @ 1500 MHz
     cpu2:  17.5 +/-  0.9  @ 1500 MHz
     cpu3:   6.5 +/-  3.0  @ 1500 MHz
  netperf:   5.5
root@OpenWrt:~# ethtool -m eth1
Offset		Values
0x0000:		03 04 07 00 00 00 01 00 00 00 01 01 0d 00 00 00
0x0010:		08 03 00 1e 4f 45 4d 20 20 20 20 20 20 20 20 20
0x0020:		20 20 20 20 00 00 1b 21 53 46 50 2b 31 30 47 2d
0x0030:		54 2d 49 20 20 20 20 20 41 20 20 20 03 52 00 4d
0x0040:		00 1a 00 00 57 45 50 4f 51 54 42 5a 31 30 30 31
0x0050:		20 20 20 20 32 33 30 39 31 35 20 20 68 f0 05 a9
0x0060:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0070:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0080:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0090:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00a0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00b0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00c0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00d0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00e0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00f0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0100:		5f 00 d3 00 55 00 d8 00 8c a0 75 30 88 b8 79 18
0x0110:		1d 4c 01 f4 19 64 03 e8 4d f0 06 30 3d e8 06 f2
0x0120:		2b d4 00 c7 27 10 00 df 00 00 00 00 00 00 00 00
0x0130:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0140:		00 00 00 00 3f 80 00 00 00 00 00 00 01 00 00 00
0x0150:		01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 23
0x0160:		2d 40 83 bd 0b b8 13 90 18 a0 00 00 00 00 00 00
0x0170:		00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff 00
0x0180:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x0190:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01a0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01b0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01c0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01d0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01e0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x01f0:		00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
dmesg log at:
The dmesg log is interesting. It seems like as if it tries to use 10gbit but falls back to 1gbit.
Okay so i’ve checked this with support, and they say vendor image has no problem.
which support (bpi/sfp vendor)? yes, we have not yet rss/lro in mainline-code…it is still in progress…we still porting some other parts.
BPI support, by vendor image i mean the one from MTK.
it seems to me that this is the wrong thread you are posting to?
No I don’t think so.
Ok, can you then please tell me what your posting
has to do with my problem with a bad sfp+ performance with that 10gbit rj45 adapter? Because i dont get it. Or did you check my problem with the BPI support?
Again, vendor image from MTK has no problem reaching 10gbps on sfp+ port. This is what they said.
OpenWRT on the other hand is stuck with ~4.5gbps.
