My problem is not that i am stuck at 4.5gbps. My problem is that the SFP-to-RJ45-Adapter is somehow not working as 10gbit but as 1gbit module only, even tho it first tries to configure it as 10gbit device. So it is another problem i assume.
The relevant part is this:
[ 375.074255] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[ 375.082649] br-lan: port 1(eth1) entered blocking state
[ 375.087869] br-lan: port 1(eth1) entered forwarding state
[ 596.337946] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 596.343976] br-lan: port 1(eth1) entered disabled state
[ 600.321819] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[ 600.330212] br-lan: port 1(eth1) entered blocking state
[ 600.335430] br-lan: port 1(eth1) entered forwarding state
[ 950.490529] mt7530-mmio 15020000.switch lan1: Link is Down
[ 950.496514] br-lan: port 2(lan1) entered disabled state
[ 955.620389] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 955.636473] br-lan: port 1(eth1) entered disabled state
[ 958.895361] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[ 958.903753] br-lan: port 1(eth1) entered blocking state
[ 958.908972] br-lan: port 1(eth1) entered forwarding state
[ 1585.863092] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 1585.879175] br-lan: port 1(eth1) entered disabled state
[ 1589.416943] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[ 1589.425334] br-lan: port 1(eth1) entered blocking state
[ 1589.430554] br-lan: port 1(eth1) entered forwarding state
[ 1620.154853] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 1620.160905] br-lan: port 1(eth1) entered disabled state
[ 1627.672129] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[ 1627.680522] br-lan: port 1(eth1) entered blocking state
[ 1627.685747] br-lan: port 1(eth1) entered forwarding state
[ 1645.935906] mtk_soc_eth 15100000.ethernet eth1: Link is Down
[ 1645.941923] br-lan: port 1(eth1) entered disabled state
[ 1660.802783] sfp sfp2: module removed
[ 1663.014358] sfp sfp2: module OEM SFP+10G-T-I rev A sn WEPOQTBZ1001 dc 230915
[ 1663.023781] mtk_soc_eth 15100000.ethernet eth1: switched to inband/1000base-x link mode
when i take a look at the ethtool help it states: ethtool [ FLAGS ] -m|âdump-module-eeprom|
Are you sure this is not a hex-dump? When i do the same on eth2 (my internet connection) i also get a hex dump, but that module works fine as expected.
well, it tries to print those in a human readable way, if possible. i am wondering where it gets those information. maybe this is an extra package that is linked during compile time or maybe at runtime. maybe the version that is built for openwrt is very different from the version that is built for debian (stripped etc.). so my guess is, that just because it is not able to print some nice text, its no proof that the eeprom has issues. its just not recognized by ethtool, so it prints it in raw. wondering if there is a way to decode that online or so. also, the WAN sfp port is working perfectly fine, but it also shows only the raw hex.
i found this: Ethtool Print EEPROM | Hack GPON
when i copy/paste the output of ethtool -m into this, it looks really nice, but i have no idea what information you need.
Nice update
I just built a new openwrt image, before that i was using kernel 6.1 and now its 6.6.
And now its 10gbit. So my assumption is that something has been updated in the kernel, now i also get more than 1gbit over the sfp-rj45-connection.
Yes,but we have both not yet workingâŚso i wonder why you get 10GâŚor do you mean you get the max of 4.5g like i did (or at least interface mode is 10g)
when i say âits 10gbitâ i mean dmesg shows me that its recognized as 10gbit module. what i really retrieve on my workstation cant be 10gbit as my workstation has a 2.5gbit nic only. also, i dont have a endpoint where i can test the 10gbit. not sure if speedtest.net can handle 10gbit per connection
