[BPI-R4] nvme+i2c
Now those two resistors are not installed by default in newer batches:
Just got the R4. Are you talking about these resistors? Please inform, how to “tape” or cover them? I plan to use an nvme and fiber ports at the same time.
See first post of this topic which shows pin location…just cover them with a tape
people seem to talk about only SFP ports not working, but when i plug in an SSD, then i see zero output on the serial console.
i remember seeing some change on the leds eventually. is the serial port also brought down by the i2c bus? that would explain.
i put tape on the two (tiny!) legs of my SSD as suggested above, and the board booted, serial port and the SSD both works.
i’ll read a bit more about those two resistors, and i’ll maybe desolder them. IIUC that would make the taping unnecessary, right?
Yes, desolder these 2 resistors solves the issue too and taping is no more necessary. Future version do not have these resistors.
When will we be able to buy a R4 without those resistors? What’s the best shop to get the most updated hardware revisions, sinovoip on aliexpress?sino
I’m afraid this could be very difficult!
To reprogram a pick and place not to take this two resistors is easy made. But for a new version print (1.2) you will need a new mask.
Here the command of banana pi:
This is why I think there will never be a 1.2 … (hope for it never dies)
But even the Version 1.1 will be changed to 1.2 you will probably not see it, because the pictures of vendors look often not self made.
So, the boards should be already available!?
Anyway, ask the distributor!
Just recieved my copies #2 and #3 and both still have those resistors.
What are the 4th digit from the left on the barcode sticker on your #2 and #3 ?
The 4th digit from left is ‘3’ for both.
Same as mine. I guest a great number still. :slight_smile:
I needed to correct myself - it doesn’t seem so easy to get an m.2-card working. I need to activate a third mPCIe-card, therefore I got this adapter https://www.amazon.de/dp/B089N34HPV which has one review saying it works with AsiaRF-cards on BPI-R3, hence I thought it would work as well in BPI-R4. I will investigate why it failed (hopefully only in first place).
Without taping the board doesn’t boot into OpenWrt - the green LED would not light up. When it is taped the boot process succeeds. I do not have another device to test the functionality of the adapter though :expressionless:
@simon will PCIe devices work in the nvme-slot provided a working adapter is used? In my case I try to install a third MT7915/MT7916 card.
@kvic I contacted sales and the first batch without R228/R230 will be ready for shipping end of next week.
Theoretically it’s okay, but I don’t know if there is such an adapter
There are a couple of those adapters in reality (Amazon (DE/US) /aliexpress etc.pp.). But your theory doesn’t seem to work. I tried first
m.2 key m slot → mPCIe adapter (an Amazon review says it works with BPI-R3, so I assumed it should work with R4 as well…) → MT7916
and then
m.2 key m slot → m.2 key ae adapter → mPCIe adapter → MT7916
and in both cases the card is not recognised - dmesg doesn’t have any related entry. I followed the first post and a nvme drive is detected without issues this way. Is there something blocked when taping the two pins that is somehow needed for the mPCIe to work properly? I explicitly ordered some new boards without the resistors to make sure it has nothing to do with that but it is really weird. The adapters work in a desktop motherboard without any issues… :neutral_face:
May be this is the wrong topic for this chat, BUT i’m not sure.
To solve this I would recommended to test the MT7916 WiFi boards in the mini PCIE slot → (DO NOT FORGET TO CHECK THE 12V SWITCH BEFORE INSERT THE CARD!)
I suggest this, because in the documentation of R4 it is described as working:
The MT7916 is available in M.2 and Mini PCI-E by default.
grafik … grafik
I really do not think that this caused by the adapter (but I’m a laiman!). To be sure try the M2 card!
I found it strange to buy a new board because the design hasn’t changed (just the two resistors are not there).
It is not possible for you to take away this two resistors? I ask this because in my opinion this “glueing stuff” is for people that are doing this for one time. But it seem for me that you are a guy, who do that more than one time … may be you found someone who can do this for you?
Thanks for your answer. I should have written that mPCIe slots 1&2 are stuffed with MT7915/MT7916-cards that work without issues (yes, the switch is in correct position). I do not need to desolder the resistors, I will just wait for the new (already purchsed) boards that come without them. Buying the m.2 ae-variants of the cards was my last backup-solution. Maybe if it still doesn’t work with the new boards I will just wait for the BE-19 cards, that would solve my problem completely (having 3 cards installed is only a workaround).
I received the V1.1 board today. It had the resistors in place but I removed them. 20240828_232326
Today I received my last 3 boards - I explicitly ordered those without the respective resistors directly from Banana Pi. Revision is still 1.1, serial numbers are 420400206/7/9.
Still, the adapters do not work, so this does not seem to be related to the resistors (unfortunately :frowning: ).
Did the board ship with the resistors on? If so, have you tried removing them before testing the adapters?
