[BPI-R4] How to use frank-w u-boot to boot from Nvme on BPI-R4?
I boot from SD, It’s boot ok, and I see
But When I use boot from Nvme, kernel name key in “bpi-r4.itb”, I can’t boot and display “Can’t set block device”
How to boot from Nvme? What files or images need put Nvme partition 1?
I success to boot from Nvme.
The installation steps as follows:
  1. Flush frank-w u-boot to NAND or SD.
    After flush, we can see this screen: image
  2. Use normal frank-w BPI-R4 Debian boot
  3. Fdisk Nvme For Nvme boot requirements,
    First Partition must FAT32
    Second Partition must ext4
    Use fdisk maybe better.
  4. Put frank-w BPI-R4 Debian to Nvme
    BPI-BOOT/ => nvme0n1p1/
    Debian rootfs => nvme0n1p2/
  1. umount & reboot to u-boot menu image
  2. Boot from Nvme image
kernel name: bpi-r4.itb
That’s finish, we use Nvme to boot.
How to debug u-boot boot?
u-boot menu and boot scripts are defined in printenv.
  1. Boot to u-boot menu and Select Exit to u-boot cmd image
  2. printenv
  3. Nvme boot script
    run askbootnvme
    askbootnvme=run usenvme; if test “$device” = “nvme”; then run askkernel;if printenv kernelinput; then setenv fit $kernelinput;run newboot;fi;fi
    run usenvme
    run askkernel
    setenv fit $kernelinput (here is bpi-r4.itb)
    run newboot
    newboot=run checkrd; run setbootconf; run buildargs;if printenv fit;then setenv kernel ${fit};if run loadkernel; then bootm ${kaddr}${bootconf}; fi;fi;
    loadkernel=fatload $device $partition $kaddr ${kernel}
Error message “Can’t set block device” occurred at stage “loadkernel”.
So, we fdisk Nvme first partition as FAT32 and boot ok.
You can overwrite the defaults when booting from mmc using a uEnv.txt.
Or change builtin env when compile your own
See ci pipeline for compile steps
Of course you can patch out the askkernel to boot fixed file automaticly.
Thanks.
I will try it.
