I’ve tried reading through this huge post, but which SFP modules DO work so far? with links to buy them, please. ![]()
Problems are mostly with 2.5g and gpon sfp. 1g and 10g should work so far.
I have no issues so far with h!fiber 1g and 10g sfp.
i have no shop-link, but right now i use this 1gbit sfp module and it works:
[ 12.538641] sfp sfp1: module OEM GLC-BX-U-C rev 1.0 sn 1152216730 dc 150602
What type are you looking for?
RJ45 that supports at least 1000M and 2500M
I want to replace the ISP’s ONU, but I need a ONU SFP Stick that has WEB management and that works in the BPI-R3 and BPI-R4 SFP WAN slot.
I have found these but I don’t know if they work or are compatible with the BPI-R3 or BPI-R4 and I would also like you to recommend one:
WAS-110
Alcatel-Lucent G-010S-P / Huawei MA5671A / Nokia G-010S-A
ODI DFP-34X-2C2 / HSGQ SFP XPON
LEOX LXT-010S-H
Hisense GPON LTE3415
You want to use one with a rtl8221b on it, behind rollball protocol. I’ve bought the one from the Luleey shop, it has one.
It was reported the BananaPi module is the same.
There are more sources of these modules, but be careful, you might get one with an yt8821 on it, which is not as well supported.
The TP-Link 2.5G module has a rtl8221b on it, but we have not figured out how to reach the phy.
The main difference is the rtl8221b we can control the phy through the kernel. So we can lower the connection speed between MAC and PHY, when the RJ45 is connected at 1000Mbps or lower. That saves quite a bit of power usage. And of course, you have more control over the negotiation and advertisement process.
The yt8821 module is stuck at the highest speed between MAC and PHY. From the kernel side, it is treated as an optical sfp, without any furher control over the connection on the RJ45.
I do not have any of these sticks, or any other gpon, so I can’t help with that.
Same for me…only read that some modules working,but need link to have web interface available…maybe the los-gpio needs to be changed (for sfp).
Hi team, I’m seeing some real strange things on my two sfp ports. I get this error regardless of the sfp+ module I insert
[ 3082.517577] sfp sfp2: Detected broken RTL8672/RTL9601C emulated EEPROM
[ 3082.524118] sfp sfp2: Switching to reading EEPROM to one byte at a time
[ 3082.574024] sfp sfp2: module rev sn dc
[ 3082.578201] sfp sfp2: module is not supported - phys id 0x00 0x00
I have tried Mikrotik S+RJ10, S+85DLC03D, Intel FTLX8571D3BCV-IT, and SFP-10G-T-CIS without any luck (All checked and working fine in multiple other equipment). I cant even debug them. Running 6.6 with all the PHY drivers selected
Any help would be amazing, even if you point out i’m an idiot and haven’t done something correctly
Maybe this 10G XGS-PON ONU SFP+ Stick work on the BPI-R3 and BPI-R4, because on Reddit, on Discord and on Ubiquiti forum have reported that it works (on other hardware but I think they are based on Linux).
Chipset: MaxLinear PRX126
- WAS-110 (Recommended)
- Recommended on Reddit and on Discord for Ubiquiti hardware.
- You need to install the 8311 community firmware based on OpenWrt.
- You can buy it in group (organized on 8311 Discord) to get it cheaper.
- It can be fully configured via the web interface and can also be configured via CLI commands.
I think these 2.5G GPON ONU SFP Sticks work on the BPI-R3 and BPI-R4, because here on the forum, on Reddit, on Discord, on Ubiquiti, on Turris and MikroTik forums have reported that they work (on other hardware but I think they are based on Linux).
Chipset: Lantiq PE98035
- Alcatel-Lucent G-010S-P (Recommended)
- Huawei MA5671A (Recommended)
- FS GPON-ONU-34-20BI
- The “Alcatel-Lucent G-010S-P” is also known as “Nokia G-010S-P”.
- The “Huawei MA5671A” need to be rooted.
- Remove the “Nokia G-010S-A” because it has pin 6 hardware issue.
- The “FS” GPON has disconnection issues on Ubiquiti hardware.
- It can be configured more or less via the web interface and requires the use of CLI commands.
Chipset: Realtek RTL9601D
- ODI DFP-34X-2C2 (Recommended)
- HSGQ-XPON-Stick (Recommended)
- The hardware in both is identical and they are from the same company, but only the “HSGQ” (newer model) receives firmware updates and already comes with the newer firmware.
- The “ODI” and “HSGQ” GPON has an issue that only works at 1000baseX/Full on BPI-R3 and BPI-R4.
Chipset: Realtek RTL9601CI
- LEOX LXT-010S-H
- Recommended on Reddit for Ubiquiti hardware.
- Not detected in BPI-R4 and sometimes works in BPI-R3.
- It has disconnection issues every 10 to 14 days of use on MikroTik hardware.
Source:
if it helps anyone: this one works too: sfp sfp1: module FLEXOPTIX P.B1696.10.AD rev A sn F7ABZLJ dc 221007
ODI DFP-34X-2C2 can work at 2500baseX with 2 options:
- Patching OWRT
- Flashing the SFP eprom.
Regards Sergio
3rd option.
- Rename the sfp.ko module ( example sfp.ko.bkp ). I use that way and it operates at 2500Mb/s. You will lose the diagnostics ( ethtoool -m eth1 on bpi-r3)
There are a misconfigured variable at the eeprom with a baud rate of 1300. That value is for aqn interface at 1.25Gb/s.
Well, i have this stick. And in BPI-R4 is not detected. I have checked this onu-stick in a Mikrotik switch, and it works there
Also i have checked this in BPI-R3 and it sometimes work there and sometimes not.
"kernel": "6.6.30",
"hostname": "r1",
"system": "ARMv8 Processor rev 0",
"model": "Bananapi BPI-R4",
"board_name": "bananapi,bpi-r4",
"rootfs_type": "squashfs",
"release": {
"distribution": "OpenWrt",
"version": "SNAPSHOT",
"revision": "r26305-eb1b022043",
"target": "mediatek/filogic",
"description": "OpenWrt SNAPSHOT r26305-eb1b022043"
have you tried with fibre connected (link detected) or if this is not possible define other gpio for LOS?
so, after the statement of @ericwoud saying the modules will never work, I tried buying a new set. These are even funnier:
let’s try to bring them up:
root@APBureau4:~# ifconfig eth1 up
root@APBureau4:~# dmesg | tail
[ 58.808505] br-lan: port 5(phy0-ap0) entered blocking state
[ 58.808524] br-lan: port 5(phy0-ap0) entered disabled state
[ 58.808559] mt7915e 0002:01:00.0 phy0-ap0: entered allmulticast mode
[ 58.808704] mt7915e 0002:01:00.0 phy0-ap0: entered promiscuous mode
[ 58.980732] br-lan: port 5(phy0-ap0) entered blocking state
[ 58.980755] br-lan: port 5(phy0-ap0) entered forwarding state
[ 59.607616] mt7530-mmio 15020000.switch lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 59.607670] br-lan: port 1(lan1) entered blocking state
[ 59.607684] br-lan: port 1(lan1) entered forwarding state
[15351.219912] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/usxgmii link mode
root@APBureau4:~# ifconfig eth2 up
[15355.307266] device: 'i2c:sfp2': device_add
[15355.307515] PM: Adding info for No Bus:i2c:sfp2
[15382.608963] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/usxgmii link mode
[15409.969346] device: 'i2c:sfp1': device_add
[15409.969504] PM: Adding info for No Bus:i2c:sfp1
ok, so devices are up. Let’s inspect them:
root@APBureau4:~# ethtool -m eth2
Identifier : 0x03 (SFP)
Connector : 0x07 (LC)
Transceiver codes : 0x00 0x00 0x00 0x00 0x00 0x00 0x40 0x00 0x00
Transceiver type : FC: Twisted Pair (TP)
Encoding : 0x01 (8B/10B)
BR, Nominal : 3100MBd
Length (SMF,km) : 0km
Length (SMF) : 0m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 0nm
Vendor name : OEM
Vendor OUI : 00:00:00
Vendor PN : SFP-2G5
Vendor rev : 1.0
Option values : 0x00 0x18
Option : TX_FAULT implemented
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : 2G522112324218
Date code : 220801
root@APBureau4:~# ethtool -m eth1
Length (SMF) : 0m
Length (50um) : 0m
Length (OM3) : 0m
Vendor name : OEM
Vendor PN : SFP-2G5
Vendor rev : 1.0
BR margin, max : 0%
BR margin, min : 0%
Date code : 220801
root@APBureau4:~# ethtool eth1
Settings for eth1:
Supported ports: [ MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
10000baseT/Full
2500baseX/Full
1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
1000baseX/Full
10000baseCR/Full
10000baseSR/Full
10000baseLR/Full
10000baseLRM/Full
10000baseER/Full
2500baseT/Full
5000baseT/Full
Advertised link modes: 10baseT/Half 10baseT/Full
10000baseT/Full
2500baseX/Full
1000baseKX/Full
10000baseKX4/Full
10000baseKR/Full
1000baseX/Full
10000baseCR/Full
10000baseSR/Full
10000baseLR/Full
10000baseLRM/Full
10000baseER/Full
2500baseT/Full
5000baseT/Full
Speed: Unknown!
Duplex: Unknown! (255)
Auto-negotiation: on
Port: MII
PHYAD: 0
Transceiver: internal
Link detected: no
so far, no luck … let’s get some coffee …
[15956.549344] sfp sfp2: no PHY detected
[15956.549374] mtk_soc_eth 15100000.ethernet eth1: switched to inband/2500base-x link mode
[15956.555803] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
[16011.209433] sfp sfp1: no PHY detected
[16011.209463] mtk_soc_eth 15100000.ethernet eth2: switched to inband/2500base-x link mode
Settings for eth1:
Supported ports: [ TP ]
Supported link modes: 2500baseT/Full
Advertised link modes: 2500baseT/Full
Speed: 2500Mb/s
Duplex: Full
Auto-negotiation: off
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Link detected: yes
wth? where does this come from?
any ideas?
So we were trying to find out which module you have, by peeking around with i2cdump. See if you have the RTL8221B on Rollball SFP module. Somehow, we did not get the right output to determine this.
You now have a module that reports it’s supported interface mode via eeprom and actually has link up. However, the PHY is not recognised (unknown vendor & product string).
I still did not check this myself on R4, but I assume the R4 has the same issue with 2500base-x as the R3.
Quick fix:
ethtool -s eth1 autoneg off
This should setup the MAC without auto-negotiation and traffic should pass. You can do the same with a patch that adds a quirk to disable auto-negotiation for this sfp module.
The module is now treated as if it is an optical module.
To gain control over the PHY (If it is the RTL8221B behind Rollball protocol) you need to either:
- Use a patch to add a fixup that matches your vendor/product string.
- Change product string on the sfp module’s eeprom (I have a tool that makes this easier).
But this is only useful If it is the RTL8221B behind Rollball protocol.
More can be found on this in other topics on the forum.
Your eeprom hack sounds cool. Can I see your tool?
EDIT: @ericwoud which addresses specify the PHY iD again? so far, I got the following info:
root@APBureau4:~# i2cdump -y 3 0x50
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 03 04 07 00 00 00 00 00 00 40 00 01 1f 00 00 00 ???......@.??...
10: 00 00 00 00 4f 45 4d 20 20 20 20 20 20 20 20 20 ....OEM
20: 20 20 20 20 00 00 00 00 53 46 50 2d 32 47 35 20 ....SFP-2G5
30: 20 20 20 20 20 20 20 20 31 2e 30 20 00 00 00 82 1.0 ...?
40: 00 18 00 00 32 47 35 32 32 31 31 32 33 32 34 32 .?..2G5221123242
50: 31 38 20 20 32 32 30 38 30 31 20 20 00 00 00 9f 18 220801 ...?
60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
root@APBureau4:~# i2cdump -y 3 0x51
00: 50 00 f6 00 4b 00 fb 00 8c a0 75 30 88 b8 79 18 P.?.K.?.??u0??y?
10: 1d 4c 01 f4 19 64 03 e8 4d f0 06 30 3d e8 06 f2 ?L???d??M??0=???
20: 2b d4 00 c7 27 10 00 df 00 00 00 00 00 00 00 00 +?.?'?.?........
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
40: 00 00 00 00 3f 80 00 00 00 00 00 00 01 00 00 00 ....??......?...
50: 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 23 ?...?...?......#
60: 18 40 83 bd 0b b8 13 88 00 00 00 00 00 00 02 00 ?@??????......?.
70: 00 40 00 00 00 40 00 00 00 00 00 ff ff ff ff 00 .@...@..........
80: 02 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 ?..?............
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
root@APBureau4:~# i2cdump -y 3 0x56
00: 11 79 01 0c 0d 41 00 00 00 02 00 00 00 00 00 a0 ?y???A...?.....?
10: 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 ...........?....
20: 11 79 01 0c 0d 41 00 00 00 02 00 00 00 00 00 a0 ?y???A...?.....?
30: 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 ...........?....
40: 11 79 01 0c 0d 41 00 00 00 02 00 00 00 00 00 a0 ?y???A...?.....?
50: 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 ...........?....
60: 11 79 01 0c 0d 41 00 00 00 02 00 00 00 00 00 a0 ?y???A...?.....?
70: 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 ...........?....
80: 11 79 01 0c 0d 41 00 00 00 02 00 00 00 00 00 a0 ?y???A...?.....?
90: 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 ...........?....
a0: 11 79 01 0c 0d 41 00 00 00 02 00 00 00 00 00 a0 ?y???A...?.....?
b0: 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 ...........?....
c0: 11 79 01 0c 0d 41 00 00 00 02 00 00 00 00 00 a0 ?y???A...?.....?
d0: 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 ...........?....
e0: 11 79 01 0c 0d 41 00 00 00 02 00 00 00 00 00 a0 ?y???A...?.....?
f0: 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 ...........?....
EDIT2: this is the vanilla openwrt kernel with all sorts of mdio and i2c devices compiled in (so without your patches):
[ 36.902576] bus: 'platform': __driver_probe_device: matched device sfp2 with driver sfp
[ 36.910620] bus: 'platform': really_probe: probing driver sfp with device sfp2
[ 36.921898] sfp sfp2: no pinctrl handle
[ 36.982436] sfp sfp2: Host maximum power 3.0W
[ 36.991783] driver: 'sfp': driver_bound: bound to device 'sfp2'
[ 37.002451] sfp sfp2: Dropping the link to 1001f000.pinctrl
[ 37.008025] device: 'platform:1001f000.pinctrl--platform:sfp2': device_unregister
[ 37.015614] bus: 'platform': really_probe: bound device sfp2 to driver sfp
[ 37.022501] devices_kset: Moving sfp1 to end of list
[ 37.022504] PM: Moving platform:sfp1 to end of list
[ 37.022508] platform sfp1: Retrying from deferred list
[ 37.030918] bus: 'platform': __driver_probe_device: matched device sfp1 with driver sfp
[ 37.040834] bus: 'platform': really_probe: probing driver sfp with device sfp1
[ 37.058398] sfp sfp1: no pinctrl handle
[ 37.123592] sfp sfp1: Host maximum power 3.0W
[ 37.128389] driver: 'sfp': driver_bound: bound to device 'sfp1'
[ 37.134318] sfp sfp1: Dropping the link to 1001f000.pinctrl
[ 37.139960] device: 'platform:1001f000.pinctrl--platform:sfp1': device_unregister
[ 37.147556] bus: 'platform': really_probe: bound device sfp1 to driver sfp
[ 37.330125] sfp sfp2: module OEM SFP-2G5 rev 1.0 sn 2G522112324218 dc 220801
[ 37.339544] mtk_soc_eth 15100000.ethernet eth1: unsupported SFP module: no common interface modes
[ 37.459424] sfp sfp1: module OEM SFP-2G5 rev 1.0 sn 2G522112324218 dc 220801
[ 37.474012] mtk_soc_eth 15100000.ethernet eth2: unsupported SFP module: no common interface modes
[ 38.237617] bus: 'mdio_bus': __driver_probe_device: matched device r8169-1-300:00 with driver RTL8226B_RTL8221B 2.5Gbps PHY
[ 38.248769] bus: 'mdio_bus': really_probe: probing driver RTL8226B_RTL8221B 2.5Gbps PHY with device r8169-1-300:00
[ 38.259122] RTL8226B_RTL8221B 2.5Gbps PHY r8169-1-300:00: no of_node; not parsing pinctrl DT
[ 38.267568] RTL8226B_RTL8221B 2.5Gbps PHY r8169-1-300:00: no default pinctrl state
[ 38.275180] driver: 'RTL8226B_RTL8221B 2.5Gbps PHY': driver_bound: bound to device 'r8169-1-300:00'
[ 38.284255] bus: 'mdio_bus': really_probe: bound device r8169-1-300:00 to driver RTL8226B_RTL8221B 2.5Gbps PHY
[ 38.477745] bus: 'mdio_bus': __driver_probe_device: matched device r8169-1-400:00 with driver RTL8226B_RTL8221B 2.5Gbps PHY
[ 38.488874] bus: 'mdio_bus': really_probe: probing driver RTL8226B_RTL8221B 2.5Gbps PHY with device r8169-1-400:00
[ 38.499216] RTL8226B_RTL8221B 2.5Gbps PHY r8169-1-400:00: no of_node; not parsing pinctrl DT
[ 38.507654] RTL8226B_RTL8221B 2.5Gbps PHY r8169-1-400:00: no default pinctrl state
[ 38.515249] driver: 'RTL8226B_RTL8221B 2.5Gbps PHY': driver_bound: bound to device 'r8169-1-400:00'
[ 38.524299] bus: 'mdio_bus': really_probe: bound device r8169-1-400:00 to driver RTL8226B_RTL8221B 2.5Gbps PHY
[ 187.266862] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/usxgmii link mode
[ 194.138474] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/usxgmii link mode
I do not know where you keep buying your sfp modules, but this is not a Rollball module. These look like this:
Check bytes 4 to 7 at i2c address 0x56 for PHY ID on these Rollball modules.
Perhaps you get more info using word access i2cdump of 0x56, but it isn’t Rollball.
So best we can do is have it behave like an optical module, MAC fixed at 2500base-x (and autoneg disabled).
My tool is here, but you do not have the eeprom password. Could use brute force attack, but that might take a little time… https://forum.banana-pi.org/t/i2csfp-sfp-debugging-via-i2c/17761
At github: ericwoud/i2csfp (github.com)
But…
did you try if ethtool -s eth1 autoneg off gives you a functional eth1 (pingable)?
Edit:
So I guess it does not report it’s supported interface mode… ( address 0x50, byte 0x24 = 0 )
