BPI-R3 SFP Module compatibility
Hi, I have something similar, that report itself as “OEM SFP-GE-T”, doing the loop:
mt7530-mdio mdio-bus:1f sfp2: Link is Up - 1Gbps/Full - flow control off
br-lan: port 5(sfp2) entered blocking state
br-lan: port 5(sfp2) entered forwarding state
mt7530-mdio mdio-bus:1f sfp2: Link is Down
br-lan: port 5(sfp2) entered disabled state
any thought how it can be fixed?
upd: looks like on BPI R4 something similar works FYI: This $10 1000Base-T SFP Transceiver works with the BPi-R4
upd2: looks like there is patch already done by @dangowrt https://patchwork.kernel.org/project/netdevbpf/patch/[email protected]/
I i understand correctly it will be integrated into next OpenWRT stable release
For my BPI-R3 I now gave H!Fiber ASF-GE-T-Cisco-2pcs-HF(EU) a try.
But unfortunately with no success.
I run 6.12-main (and also tried others) from Franks Repo BPI-Router-Linux. Thanks for providing this.
Both SFPs RJ45 (originally named lan4 and eth1) are connected to a Gbit/s Switch to test 1000BASE-T.
After
ifup lan4
or
ifup eth1
respectively the Gbit/s Switch LEDs light up and indicate a link.
But the logging says:
Dec 20 08:18:18 kernel: [ 7320.940397] mt7530-mdio mdio-bus:1f lan4: configuring for inband/2500base-x link mode
Dec 20 08:18:19 kernel: [ 7321.013900] mt7530-mdio mdio-bus:1f lan4: validation with support 00,00000000,00000000,00000000 failed: -EINVAL
Dec 20 08:18:19 kernel: [ 7321.024254] sfp sfp-2: sfp_add_phy failed: -EINVAL
Dec 20 08:24:08  kernel: [ 7670.058393] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
Dec 20 08:24:08  kernel: [ 7670.138427] mtk_soc_eth 15100000.ethernet eth1: validation with support 00,00000000,00000000,00000000 failed: -EINVAL
Dec 20 08:24:08  kernel: [ 7670.149271] sfp sfp-1: sfp_add_phy failed: -EINVAL
# ethtool eth1
Settings for eth1:
        Supported ports: [ MII ]
        Supported link modes:   2500baseX/Full
                                2500baseT/Full
        Advertised link modes:  2500baseX/Full
                                2500baseT/Full
        Advertised auto-negotiation: No
        Speed: 2500Mb/s
        Duplex: Full
        Auto-negotiation: off
        Port: MII
        PHYAD: 0
        Transceiver: internal
        Link detected: no
# ethtool -m eth1
        Identifier                                : 0x03 (SFP)
        Extended identifier                       : 0x04 (GBIC/SFP defined by 2-wire interface ID)
        Connector                                 : 0x00 (unknown or unspecified)
        Transceiver codes                         : 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00 0x00
        Transceiver type                          : Ethernet: 1000BASE-T
        Encoding                                  : 0x01 (8B/10B)
        BR, Nominal                               : 1300MBd
        Rate identifier                           : 0x00 (unspecified)
        Length (SMF,km)                           : 0km
        Length (SMF)                              : 0m
        Length (50um)                             : 0m
        Length (62.5um)                           : 0m
        Length (Copper)                           : 100m
        Length (OM3)                              : 0m
        Laser wavelength                          : 0nm
        Vendor name                               : OEM
        Vendor OUI                                : 00:00:00
        Vendor PN                                 : SFP-GE-T
        Vendor rev                                :
        Option values                             : 0x00 0x1a
        Option                                    : RX_LOS implemented
        Option                                    : TX_FAULT implemented
        Option                                    : TX_DISABLE implemented
        BR margin, max                            : 0%
        BR margin, min                            : 0%
        Vendor SN                                 : CSGE2K3K403
        Date code                                 : 24052501
# dmesg | egrep -i sfp
[    1.865361] sfp sfp-2: module OEM              SFP-GE-T         rev      sn CSGE2303947      dc 24052501
[    1.904782] sfp sfp-1: module OEM              SFP-GE-T         rev      sn CSGE2K3K403      dc 24052501
[   23.407285] sfp sfp-2: sfp_add_phy failed: -EINVAL
[   23.447733] sfp sfp-1: sfp_add_phy failed: -EINVAL
In ‘drivers/net/phy/sfp.c’ I see
    // OEM SFP-GE-T is a 1000Base-T module with broken TX_FAULT indicator
    SFP_QUIRK_F("OEM", "SFP-GE-T", sfp_fixup_ignore_tx_fault),
exists.
Is there a known way (special kernel version, patches etc.) to get SFP-GE-T working with 1000BASE-T?
Are there other brand SFPs around with better support for 1000BASE-T to work in a BPI-R3?
For the h!fibre i needed no quirk/fixup,it worked out-of-the-box…seems there is something broken now.
Seems your mac is forced to 2500-base…and not allowong the 1g mode
ok, but as I’ve seen you use an optical medium (no copper as I do). Maybe this has an impact too on the issue.
What kernel version/patches do you use? I could give this a try…
Ah,right,i use optical one,possibly that eeprom differs
after the big disappointment with cheap H!Fiber ASF-GE-T-Cisco-2pcs-HF(EU) SFPs I have now tested with (not so cheap):
10Gtek ASF-2G2-T+(OEM-EU)
What can i say? It’s awesome!
The first 1000BASE-T Copper RJ45 SFP Transceiver I know of that just works in a BPI-R3 :grinning:
On Debian + Kernel e.g. 6.12.0-bpi-r3-main.
I can tell you what’s broken:
You forgot to include
<M>   Marvell Alaska PHYs
<M>   Marvell Alaska 10Gbit PHYs
<M>   Marvell 88Q2XXX PHY
<M>   Marvell 88X2222 PHY
drivers in your .config. After doing that now even H!Fiber ASF-GE-T-Cisco-2pcs-HF(EU) SFPs work with 1000BASE-T Copper RJ45
thanks to @bruzzin for hinting me the missing drivers
Ok,when the sfp has a phy (seems often for copper sfp,but unlikely for fibre) a driver is maybe needed.
ok, you could consider to include SFP related phy drivers in your build since it is essential for a BPI-R3 based “router”. The overhead to build such additional modules is minimal…
Which one do you need? I try to keep the defconfig as small as possible to reduce compile time (also for pipeline).
Thinking about an additional options for full builds which are appended to the minimal defconfig,but had no good idea how to do it exactly.
to support H!Fiber ASF-GE-T-Cisco-2pcs-HF(EU) with 1000BASE-T Copper RJ45 it’s sufficient to set
CONFIG_MARVELL_PHY=m
Added to r3/r4 defconfigs
and added function+files to 6.13-rc to append defconfig
It works with Openwrt 24.10. Thanks for fixing, now we have dirt cheap (mine was 2usd on promotion) Ethernet modules. upd: (context BPI-R3 SFP Module compatibility - #121 by bademux)
What was fixed? Did I miss something?
Afaik kmod-phy-marvell has always been there, one only needs to install that module to have support for 1G copper SFP with Marvell PHY…
Since i upgraded to Openwrt 24.10 now my SFP transceiver randomly disconnect
TP-LINK TL-SM410U rev 2.0 sn 122C304001372 dc 221228
Sat Feb 15 11:32:12 2025 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.10 40:ed:00:a2:eb:7b
Sat Feb 15 11:32:12 2025 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.10 40:ed:00:a2:eb:7b win11
Sat Feb 15 11:32:20 2025 kern.info kernel: [  548.365462] mt7530-mdio mdio-bus:1f sfp2: Link is Down
Sat Feb 15 11:32:20 2025 kern.info kernel: [  548.365551] br-lan: port 5(sfp2) entered disabled state
Sat Feb 15 11:32:20 2025 daemon.notice netifd: Network device 'sfp2' link is down
Sat Feb 15 11:32:33 2025 kern.info kernel: [  561.870503] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 2.5Gbps/Full - flow control off
Sat Feb 15 11:32:33 2025 kern.info kernel: [  561.870699] br-lan: port 5(sfp2) entered blocking state
Sat Feb 15 11:32:33 2025 daemon.notice netifd: Network device 'sfp2' link is up
Sat Feb 15 11:32:33 2025 kern.info kernel: [  561.883632] br-lan: port 5(sfp2) entered forwarding state
Sat Feb 15 11:32:35 2025 kern.info kernel: [  563.948316] mt7530-mdio mdio-bus:1f sfp2: Link is Down
Sat Feb 15 11:32:35 2025 kern.info kernel: [  563.948404] br-lan: port 5(sfp2) entered disabled state
Sat Feb 15 11:32:35 2025 daemon.notice netifd: Network device 'sfp2' link is down
Sat Feb 15 11:32:39 2025 kern.info kernel: [  568.104162] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 2.5Gbps/Full - flow control off
Sat Feb 15 11:32:39 2025 kern.info kernel: [  568.104357] br-lan: port 5(sfp2) entered blocking state
Sat Feb 15 11:32:39 2025 daemon.notice netifd: Network device 'sfp2' link is up
Sat Feb 15 11:32:39 2025 kern.info kernel: [  568.117294] br-lan: port 5(sfp2) entered forwarding state
Sat Feb 15 11:32:41 2025 kern.info kernel: [  569.143056] mt7530-mdio mdio-bus:1f sfp2: Link is Down
Sat Feb 15 11:32:41 2025 kern.info kernel: [  569.143145] br-lan: port 5(sfp2) entered disabled state
Sat Feb 15 11:32:41 2025 daemon.notice netifd: Network device 'sfp2' link is down
Sat Feb 15 11:32:45 2025 kern.info kernel: [  573.299007] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 2.5Gbps/Full - flow control off
Sat Feb 15 11:32:45 2025 kern.info kernel: [  573.299200] br-lan: port 5(sfp2) entered blocking state
Sat Feb 15 11:32:45 2025 daemon.notice netifd: Network device 'sfp2' link is up
Sat Feb 15 11:32:45 2025 kern.info kernel: [  573.312132] br-lan: port 5(sfp2) entered forwarding state
Sat Feb 15 11:32:46 2025 kern.info kernel: [  574.338044] mt7530-mdio mdio-bus:1f sfp2: Link is Down
Sat Feb 15 11:32:46 2025 kern.info kernel: [  574.338132] br-lan: port 5(sfp2) entered disabled state
Sat Feb 15 11:32:46 2025 daemon.notice netifd: Network device 'sfp2' link is down
Sat Feb 15 11:32:50 2025 kern.info kernel: [  578.494141] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 2.5Gbps/Full - flow control off
Sat Feb 15 11:32:50 2025 kern.info kernel: [  578.494338] br-lan: port 5(sfp2) entered blocking state
Sat Feb 15 11:32:50 2025 daemon.notice netifd: Network device 'sfp2' link is up
Sat Feb 15 11:32:50 2025 kern.info kernel: [  578.507268] br-lan: port 5(sfp2) entered forwarding state
Sat Feb 15 11:32:52 2025 kern.info kernel: [  580.572244] mt7530-mdio mdio-bus:1f sfp2: Link is Down
Sat Feb 15 11:32:52 2025 kern.info kernel: [  580.572334] br-lan: port 5(sfp2) entered disabled state
Sat Feb 15 11:32:52 2025 daemon.notice netifd: Network device 'sfp2' link is down
Sat Feb 15 11:32:56 2025 kern.info kernel: [  584.728535] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 2.5Gbps/Full - flow control off
Sat Feb 15 11:32:56 2025 kern.info kernel: [  584.728729] br-lan: port 5(sfp2) entered blocking state
Sat Feb 15 11:32:56 2025 kern.info kernel: [  584.741665] br-lan: port 5(sfp2) entered forwarding state
Sat Feb 15 11:32:56 2025 daemon.notice netifd: Network device 'sfp2' link is up
Sat Feb 15 11:32:57 2025 kern.info kernel: [  585.767630] mt7530-mdio mdio-bus:1f sfp2: Link is Down
Sat Feb 15 11:32:57 2025 kern.info kernel: [  585.767720] br-lan: port 5(sfp2) entered disabled state
Sat Feb 15 11:32:57 2025 daemon.notice netifd: Network device 'sfp2' link is down
Sat Feb 15 11:33:01 2025 kern.info kernel: [  589.924071] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 2.5Gbps/Full - flow control off
Sat Feb 15 11:33:01 2025 kern.info kernel: [  589.924264] br-lan: port 5(sfp2) entered blocking state
Sat Feb 15 11:33:01 2025 daemon.notice netifd: Network device 'sfp2' link is up
Sat Feb 15 11:33:01 2025 kern.info kernel: [  589.937199] br-lan: port 5(sfp2) entered forwarding state
Sat Feb 15 11:33:02 2025 kern.info kernel: [  590.963222] mt7530-mdio mdio-bus:1f sfp2: Link is Down
Sat Feb 15 11:33:02 2025 kern.info kernel: [  590.963312] br-lan: port 5(sfp2) entered disabled state
Sat Feb 15 11:33:02 2025 daemon.notice netifd: Network device 'sfp2' link is down
Sat Feb 15 11:33:07 2025 kern.info kernel: [  595.119793] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 2.5Gbps/Full - flow control off
Sat Feb 15 11:33:07 2025 kern.info kernel: [  595.119988] br-lan: port 5(sfp2) entered blocking state
Sat Feb 15 11:33:07 2025 daemon.notice netifd: Network device 'sfp2' link is up
Sat Feb 15 11:33:07 2025 kern.info kernel: [  595.132920] br-lan: port 5(sfp2) entered forwarding state
Sat Feb 15 11:33:08 2025 kern.info kernel: [  596.158954] mt7530-mdio mdio-bus:1f sfp2: Link is Down
Sat Feb 15 11:33:08 2025 kern.info kernel: [  596.159043] br-lan: port 5(sfp2) entered disabled state
Sat Feb 15 11:33:08 2025 daemon.notice netifd: Network device 'sfp2' link is down
I have to unplug it from the transceiver and plug it into an RJ45 port to regain network access. It’s not a cable problem, i’m using a brand new one cat 7.
Sometimes it works for 15 minutes and then it starts disconecting. i never had this problem before, with the previous versions of openwrt.
My module is only working at 2.5Gbps, it doesn’t support 1Gbps.
root@OpenWrt:~# ethtool sfp2
Settings for sfp2:
        Supported ports: [ FIBRE ]
        Speed: 2500Mb/s
        Duplex: Full
        Auto-negotiation: on
        Port: FIBRE
        PHYAD: 0
        Supports Wake-on: d
        Wake-on: d
        Link detected: no
root@OpenWrt:~#
It was fixed some time ago, I had this one: BPI-R3 SFP Module compatibility - #121 by bademux
With this patch I successfully put HGSQ XPON-Stick to 2.5G, in fact it is the same as ODI DFP-34X-2C2 since ODI is a brand of HSGQ.
1000-sfp-hsgq-quirk-basex.patch (440 Bytes)
I’m a complete newbie to BananaPi but is there a list of compatible 2.5gb SFP Adaptors that work with the R3? I’m struggling to find any with many links mentioned out of date or unavailable in my region.
Can any of those adaptors operate at less than the 2.5gb speed if linked to lower speed networks?
Most of them will, but some of them do not lower the speed at the MAC (cage) side, only on the cable side. It saves quite a bit of current if also the MAC side slows down.
BPI‐Router‐Linux Wiki · frank-w/BPI-Router-Linux Wiki
The ones from the BPI store and Luleey store do have the ability to slow down on the mac side, but the driver for both mac and module (and phylink) need to be up to date. Also a fixup is required in the kernel so the module is recognised and the driver can be bound.
Any recent image of openwrt/debian/ubuntu/archlinuxarm should have these fixes.
If the stores change something on the module and sell under the same label, you don’t know unless you try.
If you only use 1Gbps, then get one with a 88E1111.
Ah… ok … so when you talk about those stores I assume you mean The Luleey Store which sells This 2.5Gb SFP and The Banana Pi Store who sell This one
After posting I found the BananaPi Wiki page on accessories - - Do you think a link between there and the compability list that you provided () would be useful? I am happy to update as I think it might make it eaiser for other people.
I’m planning on using Openwrt on my R3 (when it arrives) if I’m paying €20 per SFP adaptor I was thinking that I maybe hold off on purchasing 2.4gb ones until I can actually use them and instead just get 1gb ones - Would one of these work? - I’m just searching Aliexpress using the Product Code / Vendor code from the list you provided - I feel like I need to put some stock statement about how purcahsing from Aliexpress always seems more difficult than it should be. - e.g on that slower SFP module I have no idea which brand I would select
Regardless, thanks for the response. Its possibly been the most helpful piece of information I have got. I really would like to make it easiser for others to use this kind of hardware with Openwrt.
