That’s not true. OpenWrt uses overlayfs usually backed by a filesystem in a persistent storage volume on the device used for booting. This doesn’t need to be configured in any way and happens by default.
Only in case of that filesystem not being available, tmpfs is used for overlay. Ie. when something is broken you still get to a shell somehow, but it’s not a good setup for production, obviously.
I guess that about 95% of all devices supported by OpenWrt come with rather small SPI-NOR or SPI-NAND flash chips. Linux and rootfs easily fits in less than 10 MiB, still leaving a few MiB for user data and configuration to the user even on just 16 MiB SPI-NOR.
128 MiB of SPI-NAND is really huge for a router firmware, you end up with > 80 MiB of free space even with excessive amount of pre-installed software. Ok, if you are a device vendor and want to ship translations for 26 different human languages for UI, all possible USB drivers, … out of the box, then SPI-NAND is a good choice.
IMHO eMMC is really only needed for multimedia OS (hence the name…) or when using the device as a server to host complex container or VM images to provide additional services provided only in this format (but in that case it’s probably advisable to add NVMe SSD).
Of course, when using a general purpose OS like Debian, that’s a different story. It comes with all documentation and even development tools on-disk and hence needs lots more space…
You don’t need to build OpenWrt from source if you are not planning to modify low-level sources. Just use the OpenWrt Firmware Selector which also allows you to customize the generated firmware image (click on Customize installed packages), e.g. adding luci-ssl will generate an image with pre-installed Web-UI.
lol yeah correct, but how I wish we all are expert like you dangowrt. without UART its like a blind man driving a car for me, in case something went wrong I don’t know which direction to go. I am still scratching my head with Xiaomi AX3200.
hi every morning i have one question when i set openwrt and click save & apply button then use openwrt luci`s reboot it is recovery to not set openwrt how can i fix this bug? or operational problems?
i use openwrt firmware and it can success save my set, but new i receive other question.
when i ues web-ui and change luci set just like server name , and i click save/apply can see countdown timer , when countdown timer in 85 and web say save [The configuration changes have been applied.] and now i poweroff and poweron, wait to ui and check my change and i find The configuration changes haven`t been applied.but if i ues web-ui system reboot onece than poweroff and poweron The configuration changes have been applied,so how can i check this question or fix it?
for resizing partition daniel posts some instructions and warnings because this may break sysupgrade if root-partition is larger or equal in size of ram
for 5G-channel: it depends on regioncode is there is any free 160MHz-channel as this maps different channels together and afair i have seen a patch which allows only 80Mhz channelwidth.
