I want to link the network via PPPoE using a single RJ45 interface. But I ran into some problems, it said that the link was wrong.
syslog:
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.203675] usbcore: registered new device driver usb
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.209412] Bluetooth: Core ver 2.22
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.213047] NET: Registered protocol family 31
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.217509] Bluetooth: HCI device and connection manager initialized
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.223894] Bluetooth: HCI socket layer initialized
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.228792] Bluetooth: L2CAP socket layer initialized
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.233869] Bluetooth: SCO socket layer initialized
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.238955] clocksource: Switched to clocksource arch_sys_counter
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.245575] thermal_sys: Registered thermal governor 'fair_share'
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.245578] thermal_sys: Registered thermal governor 'bang_bang'
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.251705] thermal_sys: Registered thermal governor 'step_wise'
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.257737] thermal_sys: Registered thermal governor 'user_space'
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.263769] thermal_sys: Registered thermal governor 'power_allocator'
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.270098] NET: Registered protocol family 2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.281128] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.289114] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.297717] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.305734] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.313231] TCP: Hash tables configured (established 16384 bind 16384)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.319859] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.326614] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.333870] NET: Registered protocol family 1
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.338261] PCI: CLS 0 bytes, default 64
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.342876] workingset: timestamp_bits=46 max_order=19 bucket_order=0
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.351871] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.357769] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.375758] io scheduler mq-deadline registered
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.380316] io scheduler kyber registered
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.384393] io scheduler bfq registered
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.389209] mtk-pcie 11280000.pcie: host bridge /pcie@11280000 ranges:
Sun Apr 17 09:39:05 2022 kern.debug kernel: [ 0.395785] mtk-pcie 11280000.pcie: Parsing ranges property...
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.401652] mtk-pcie 11280000.pcie: MEM 0x20000000..0x2fffffff -> 0x20000000
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.408928] phy [email protected]: try to get sw efuse
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.414613] phy [email protected]: try to get sw efuse+
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.420398] phy [email protected]: u3 auto load valid efuse: ENABLE with value: 1
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.428456] phy [email protected]: u3 efuse - intr 29, rx_imp 11, tx_imp 11
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.435980] phy [email protected]: pcie auto load valid efuse: ENABLE with value: 1
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.444213] phy [email protected]: u3 lane1 efuse - intr 29, rx_imp 11, tx_imp 11
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.658975] mtk-pcie 11280000.pcie: PCIe link down, ltssm reg val: 0x1000001
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 0.666105] mtk-pcie: probe of 11280000.pcie failed with error -110
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.679841] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.686681] printk: console [ttyS0] disabled
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.711088] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 12, base_baud = 2500000) is a ST16650V2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.720293] printk: console [ttyS0] enabled
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.728643] printk: bootconsole [uart8250] disabled
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.758721] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 13, base_baud = 1625000) is a ST16650V2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.788158] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 14, base_baud = 1625000) is a ST16650V2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.797712] mtk_rng 1020f000.trng: registered RNG driver
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 0.797920] random: fast init done
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 0.806641] crng init done
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 0.810229] cacheinfo: Unable to detect cache hierarchy for CPU 0
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.818635] loop: module loaded
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.823476] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ef aa 21 00 00
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 0.830355] spi-nor: probe of spi0.0 failed with error -2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.835892] spi-nand spi0.1: Winbond SPI NAND was found.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.841195] spi-nand spi0.1: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.850890] [mtk_hw_init] reset_lock:0, force:0
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.855456] [mtk_hw_init] execute fe cold reset
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.916154] mtk_soc_eth 15100000.ethernet: generated random MAC address 1e:29:94:e9:24:c0
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.924539] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc011c80000, irq 124
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.933673] mtk_soc_eth 15100000.ethernet: generated random MAC address de:72:ac:a6:51:17
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.941995] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc011c80000, irq 124
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.951108] mtk_eth (dummy): netif_napi_add() called with weight 256
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 0.957783] xhci-mtk 11200000.xhci: 11200000.xhci supply vbus not found, using dummy regulator
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 0.966426] xhci-mtk 11200000.xhci: 11200000.xhci supply vusb33 not found, using dummy regulator
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.975287] phy [email protected]: try to get sw efuse
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.980845] phy [email protected]: try to get sw efuse+
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.986498] phy [email protected]: u2 auto load valid efuse: ENABLE with value: 1
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 0.994398] phy [email protected]: u2 efuse - intr 14
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 0.999872] phy [email protected]: try to get sw efuse
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 1.005428] phy [email protected]: try to get sw efuse+
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.011075] phy [email protected]: u3 auto load valid efuse: ENABLE with value: 1
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.018986] phy [email protected]: u3 efuse - intr 29, rx_imp 11, tx_imp 10
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 1.026366] phy [email protected]: try to get sw efuse
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 1.031921] phy [email protected]: try to get sw efuse+
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.037568] phy [email protected]: u2 auto load valid efuse: ENABLE with value: 1
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.045470] phy [email protected]: u2 efuse - intr 16
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.051360] xhci-mtk 11200000.xhci: xHCI Host Controller
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.056666] xhci-mtk 11200000.xhci: new USB bus registered, assigned bus number 1
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.067217] xhci-mtk 11200000.xhci: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.076444] xhci-mtk 11200000.xhci: irq 135, io mem 0x11200000
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.082608] hub 1-0:1.0: USB hub found
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.086364] hub 1-0:1.0: 2 ports detected
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.090549] xhci-mtk 11200000.xhci: xHCI Host Controller
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.095855] xhci-mtk 11200000.xhci: new USB bus registered, assigned bus number 2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.103321] xhci-mtk 11200000.xhci: Host supports USB 3.2 Enhanced SuperSpeed
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.110474] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.118747] hub 2-0:1.0: USB hub found
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.122501] hub 2-0:1.0: 1 port detected
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.126716] usbcore: registered new interface driver uas
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.132052] usbcore: registered new interface driver usb-storage
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.138090] usbcore: registered new interface driver usbserial_generic
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.144610] usbserial: USB Serial support registered for generic
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.150612] usbcore: registered new interface driver pl2303
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.156178] usbserial: USB Serial support registered for pl2303
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.162101] usbcore: registered new interface driver qcaux
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.167580] usbserial: USB Serial support registered for qcaux
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.173409] usbcore: registered new interface driver qcserial
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.179147] usbserial: USB Serial support registered for Qualcomm USB modem
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.186190] i2c /dev entries driver
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.190792] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.198599] Bluetooth: HCI UART driver ver 2.3
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.203032] Bluetooth: HCI UART protocol H4 registered
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.208154] Bluetooth: HCI UART protocol BCSP registered
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.213484] Bluetooth: HCI UART protocol Broadcom registered
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.219137] Bluetooth: HCI UART protocol QCA registered
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.251109] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.264739] Initializing XFRM netlink socket
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.269244] NET: Registered protocol family 10
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.274136] Segment Routing with IPv6
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.277844] NET: Registered protocol family 17
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.282382] 8021q: 802.1Q VLAN Support v1.8
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.293504] nmbm nmbm_spim_nand: Signature found at block 1023 [0x07fe0000]
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.301844] nmbm nmbm_spim_nand: First info table with writecount 0 found in block 960
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.313838] nmbm nmbm_spim_nand: Second info table with writecount 0 found in block 963
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.321838] nmbm nmbm_spim_nand: NMBM has been successfully attached
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.328283] 4 fixed-partitions partitions found on MTD device nmbm_spim_nand
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.335312] Creating 4 MTD partitions on "nmbm_spim_nand":
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.340783] 0x000000000000-0x000000100000 : "BL2"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.345961] 0x000000100000-0x000000180000 : "u-boot-env"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.351642] 0x000000180000-0x000000380000 : "Factory"
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.353166] mtk-msdc 11230000.mmc: phase: [map:ffffffff] [maxlen:32] [final:10]
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.357044] 0x000000380000-0x000000580000 : "FIP"
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.364902] mmc0: new HS400 MMC card at address 0001
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.374366] mmcblk0: mmc0:0001 008GB0 7.28 GiB
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.379460] mmcblk0boot0: mmc0:0001 008GB0 partition 1 4.00 MiB
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.385909] mmcblk0boot1: mmc0:0001 008GB0 partition 2 4.00 MiB
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.391863] mmcblk0rpmb: mmc0:0001 008GB0 partition 3 4.00 MiB, chardev (249:0)
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 1.401889] GPT:Primary header thinks Alt. header is not at the end of the disk.
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 1.409272] GPT:1 != 15269887
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 1.412226] GPT:Alternate GPT header not at the end of the disk.
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 1.418213] GPT:1 != 15269887
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 1.421166] GPT: Use GNU Parted to correct GPT errors.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.426305] mmcblk0: p1 p2 p3 p4 p5 p6
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.498965] usb 1-1: new high-speed USB device number 2 using xhci-mtk
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.559644] mt7530 mdio-bus:1f lan0 (uninitialized): PHY [dsa-0.0:00] driver [Generic PHY]
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.569057] mt7530 mdio-bus:1f lan1 (uninitialized): PHY [dsa-0.0:01] driver [Generic PHY]
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.578390] mt7530 mdio-bus:1f lan2 (uninitialized): PHY [dsa-0.0:02] driver [Generic PHY]
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.587707] mt7530 mdio-bus:1f lan3 (uninitialized): PHY [dsa-0.0:03] driver [Generic PHY]
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.597015] mt7530 mdio-bus:1f lan4 (uninitialized): PHY [dsa-0.0:04] driver [Generic PHY]
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.605950] mt7530 mdio-bus:1f: configuring for fixed/2500base-x link mode
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.613092] DSA: tree 0 setup
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.613345] mt7530 mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.616173] 7 cmdlinepart partitions found on MTD device block2mtd: /dev/mmcblk0
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.630633] Creating 7 MTD partitions on "block2mtd: /dev/mmcblk0":
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.636886] 0x000000000000-0x000000480000 : "BL2"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.642027] 0x000000480000-0x000000680000 : "RF"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.646997] 0x000000680000-0x000000880000 : "FIP"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.652042] 0x000000880000-0x000002880000 : "Kernel"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.657326] 0x000002880000-0x000042880000 : "rootfs"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.662643] mtd: device 9 (rootfs) set to be root filesystem
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.663039] hub 1-1:1.0: USB hub found
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.672101] 1 squashfs-split partitions found on MTD device rootfs
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.672108] hub 1-1:1.0: 4 ports detected
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.678275] 0x000004260000-0x000042880000 : "rootfs_data"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.688043] 0x000042880000-0x0000c2880000 : "usrdata"
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 1.693416] 0x0000c2880000-0x0001d2000000 : "bmtpool"
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.698788] block2mtd: mtd0: [/dev/mmcblk0] erase_size = 64KiB [65536]
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.705408] hctosys: unable to open rtc device (rtc0)
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.712767] VFS: Mounted root (squashfs filesystem) readonly on device 31:9.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.719967] Freeing unused kernel memory: 448K
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 1.738964] Run /sbin/init as init process
Sun Apr 17 09:39:05 2022 user.info kernel: [ 1.858541] init: Console is alive
Sun Apr 17 09:39:05 2022 user.info kernel: [ 1.862072] init: - watchdog -
Sun Apr 17 09:39:05 2022 user.info kernel: [ 2.277799] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.310495] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.317464] ehci-fsl: Freescale EHCI Host controller driver
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.323428] ehci-platform: EHCI generic platform driver
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.329635] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.336136] ohci-platform: OHCI generic platform driver
Sun Apr 17 09:39:05 2022 user.info kernel: [ 2.342405] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Sun Apr 17 09:39:05 2022 user.info kernel: [ 2.358886] init: - preinit -
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.597835] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.606156] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.620645] mt7530 mdio-bus:1f lan1: configuring for phy/gmii link mode
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 2.627740] 8021q: adding VLAN 0 to HW filter on device lan1
Sun Apr 17 09:39:05 2022 user.info kernel: [ 6.684223] mount_root: loading kmods from internal overlay
Sun Apr 17 09:39:05 2022 user.info kernel: [ 6.697898] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Sun Apr 17 09:39:05 2022 user.info kernel: [ 6.705806] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 12.173210] jffs2: notice: (972) jffs2_build_xattr_subsystem: complete building xattr subsystem, 23 of xdatum (18 unchecked, 5 orphan) and 27 of xref (5 dead, 0 orphan) found.
Sun Apr 17 09:39:05 2022 user.info kernel: [ 12.190306] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
Sun Apr 17 09:39:05 2022 user.info kernel: [ 12.199497] block: extroot: not configured
Sun Apr 17 09:39:05 2022 kern.notice kernel: [ 12.261158] jffs2: notice: (970) jffs2_build_xattr_subsystem: complete building xattr subsystem, 23 of xdatum (18 unchecked, 5 orphan) and 27 of xref (5 dead, 0 orphan) found.
Sun Apr 17 09:39:05 2022 user.info kernel: [ 13.380642] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
Sun Apr 17 09:39:05 2022 user.info kernel: [ 13.387875] block: extroot: not configured
Sun Apr 17 09:39:05 2022 user.info kernel: [ 13.392403] mount_root: switching to jffs2 overlay
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 13.398065] overlayfs: upper fs does not support tmpfile.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 13.403490] overlayfs: "xino" feature enabled using 32 upper inode bits.
Sun Apr 17 09:39:05 2022 user.debug kernel: [ 13.411766] urandom-seed: Seeding with /etc/urandom.seed
Sun Apr 17 09:39:05 2022 user.info kernel: [ 13.445547] procd: - early -
Sun Apr 17 09:39:05 2022 user.info kernel: [ 13.448486] procd: - watchdog -
Sun Apr 17 09:39:05 2022 user.info kernel: [ 13.973750] procd: - watchdog -
Sun Apr 17 09:39:05 2022 user.info kernel: [ 13.977291] procd: - ubus -
Sun Apr 17 09:39:05 2022 user.info kernel: [ 14.031783] procd: - init -
Sun Apr 17 09:39:05 2022 user.info kernel: [ 14.215458] kmodloader: loading kernel modules from /etc/modules.d/*
Sun Apr 17 09:39:05 2022 user.info kernel: [ 14.219872] urngd: v1.0.2 started.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.244172] MACsec IEEE 802.1AE
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.251506] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: [email protected]
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.267811] RPC: Registered named UNIX socket transport module.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.273757] RPC: Registered udp transport module.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.278456] RPC: Registered tcp transport module.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.283149] RPC: Registered tcp NFSv4.1 backchannel transport module.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.293916] NET: Registered protocol family 15
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.307443] l2tp_core: L2TP core driver, V2.0
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.312421] l2tp_netlink: L2TP netlink interface
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.317728] gre: GRE over IPv4 demultiplexor driver
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.323423] ip_gre: GRE over IPv4 tunneling driver
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.330229] ip6_gre: GRE over IPv6 tunneling driver
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.339503] Installing knfsd (copyright (C) 1996 [email protected]).
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.367142] hidraw: raw HID events driver (C) Jiri Kosina
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.374384] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.379701] Bluetooth: BNEP filters: protocol multicast
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.384931] Bluetooth: BNEP socket layer initialized
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.391541] usbcore: registered new interface driver btusb
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.397660] Loading modules backported from Linux version v5.15.33-0-g06f50ca83ace
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.405228] Backport generated by backports.git v5.15.33-1-0-g183c4ab2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.412906] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.418861] Bluetooth: HIDP socket layer initialized
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.450815] Bluetooth: RFCOMM TTY layer initialized
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.455726] Bluetooth: RFCOMM socket layer initialized
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.460864] Bluetooth: RFCOMM ver 1.11
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.478360] xt_time: kernel timezone is -0000
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 14.520602] mt7986-wmac 18000000.wbsys: mcu clock not found
Sun Apr 17 09:39:05 2022 kern.err kernel: [ 14.526192] mt7986-wmac 18000000.wbsys: ap2conn clock not found
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 14.949644] mt7986-wmac 18000000.wbsys: HW/SW Version: 0x8a108a10, Build Time: 20220113162701a
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 15.060142] mt7986-wmac 18000000.wbsys: WM Firmware Version: ____000000, Build Time: 20220113162756
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 15.132376] mt7986-wmac 18000000.wbsys: WA Firmware Version: DEV_000000, Build Time: 20220113163034
Sun Apr 17 09:39:05 2022 kern.warn kernel: [ 15.236446] mt7986-wmac 18000000.wbsys: eeprom load fail, use default bin
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 18.487594] PPP generic driver version 2.4.2
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 18.492715] PPP MPPE Compression module registered
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 18.498418] NET: Registered protocol family 24
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 18.503589] PPTP driver version 0.8.5
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 18.508404] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Sun Apr 17 09:39:05 2022 user.info kernel: [ 18.514365] kmodloader: done loading kernel modules from /etc/modules.d/*
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 18.686680] mtk_soc_eth 15100000.ethernet eth0: TX vlan offload cannot be enabled when dsa is attached.
Sun Apr 17 09:39:05 2022 kern.info kernel: [ 18.696758] mtk_soc_eth 15100000.ethernet eth0: TX vlan offload cannot be enabled when dsa is attached.
Sun Apr 17 09:39:05 2022 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sun Apr 17 09:39:06 2022 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: Connected to system UBus
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: started, version 2.85 cachesize 150
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: DNS service limited to local subnets
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: UBus support enabled: connected to system bus
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: using only locally-known addresses for domain test
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: using only locally-known addresses for domain onion
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: using only locally-known addresses for domain localhost
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: using only locally-known addresses for domain invalid
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: using only locally-known addresses for domain bind
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: using only locally-known addresses for domain lan
Sun Apr 17 09:39:06 2022 daemon.warn dnsmasq[1966]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: read /etc/hosts - 4 addresses
Sun Apr 17 09:39:06 2022 daemon.info dnsmasq[1966]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Sun Apr 17 09:39:06 2022 user.notice : Added device handler type: bonding
Sun Apr 17 09:39:06 2022 user.notice : Added device handler type: 8021ad
Sun Apr 17 09:39:06 2022 user.notice : Added device handler type: 8021q
Sun Apr 17 09:39:06 2022 user.notice : Added device handler type: macvlan
Sun Apr 17 09:39:06 2022 user.notice : Added device handler type: veth
Sun Apr 17 09:39:06 2022 user.notice : Added device handler type: bridge
Sun Apr 17 09:39:06 2022 user.notice : Added device handler type: Network device
Sun Apr 17 09:39:06 2022 user.notice : Added device handler type: tunnel
Sun Apr 17 09:39:06 2022 daemon.notice wpa_supplicant[2172]: Successfully initialized wpa_supplicant
Sun Apr 17 09:39:06 2022 kern.info kernel: [ 20.077330] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Sun Apr 17 09:39:06 2022 kern.info kernel: [ 20.092157] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Sun Apr 17 09:39:06 2022 kern.info kernel: [ 20.100492] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sun Apr 17 09:39:06 2022 kern.info kernel: [ 20.101584] mt7530 mdio-bus:1f lan1: configuring for phy/gmii link mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.116422] 8021q: adding VLAN 0 to HW filter on device lan1
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.124200] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.130621] br-lan: port 1(lan1) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.135832] br-lan: port 1(lan1) entered disabled state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.141335] device lan1 entered promiscuous mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.145947] device eth0 entered promiscuous mode
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'lan' is enabled
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'lan' is setting up now
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'lan' is now up
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.156305] mt7530 mdio-bus:1f lan2: configuring for phy/gmii link mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.163486] 8021q: adding VLAN 0 to HW filter on device lan2
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.171456] br-lan: port 2(lan2) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.176695] br-lan: port 2(lan2) entered disabled state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.182457] device lan2 entered promiscuous mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.191190] mt7530 mdio-bus:1f lan3: configuring for phy/gmii link mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.198348] 8021q: adding VLAN 0 to HW filter on device lan3
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.206279] br-lan: port 3(lan3) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.211504] br-lan: port 3(lan3) entered disabled state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.217378] device lan3 entered promiscuous mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.226246] mt7530 mdio-bus:1f lan4: configuring for phy/gmii link mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.233338] 8021q: adding VLAN 0 to HW filter on device lan4
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.241255] br-lan: port 4(lan4) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.246474] br-lan: port 4(lan4) entered disabled state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.252530] device lan4 entered promiscuous mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.261380] mt7530 mdio-bus:1f lan5: configuring for fixed/2500base-x link mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.269787] 8021q: adding VLAN 0 to HW filter on device lan5
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.270007] mt7530 mdio-bus:1f lan5: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.277665] br-lan: port 5(lan5) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.288281] br-lan: port 5(lan5) entered disabled state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.294498] device lan5 entered promiscuous mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.301786] br-lan: port 5(lan5) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.306999] br-lan: port 5(lan5) entered forwarding state
Sun Apr 17 09:39:07 2022 daemon.notice netifd: bridge 'br-lan' link is up
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'lan' has link connectivity
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.312859] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.321386] mt7530 mdio-bus:1f lan0: configuring for phy/gmii link mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.328565] 8021q: adding VLAN 0 to HW filter on device lan0
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'wan' is enabled
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'ONT' is enabled
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.336601] br-wan: port 1(lan0) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.341820] br-wan: port 1(lan0) entered disabled state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.347364] device lan0 entered promiscuous mode
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'wan6' is enabled
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.356891] mtk_soc_eth 15100000.ethernet eth1: configuring for fixed/2500base-x link mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.365233] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.365520] br-wan: port 2(eth1) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.379071] br-wan: port 2(eth1) entered disabled state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.384444] device eth1 entered promiscuous mode
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.389110] br-wan: port 2(eth1) entered blocking state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.394323] br-wan: port 2(eth1) entered forwarding state
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.399792] IPv6: ADDRCONF(NETDEV_CHANGE): br-wan: link becomes ready
Sun Apr 17 09:39:07 2022 daemon.notice netifd: bridge 'br-wan' link is up
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'wan6' has link connectivity
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'wan6' is setting up now
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'loopback' is enabled
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'loopback' is setting up now
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'loopback' is now up
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Network device 'eth0' link is up
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Network device 'lan5' link is up
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Network device 'lo' link is up
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Interface 'loopback' has link connectivity
Sun Apr 17 09:39:07 2022 daemon.notice netifd: Network device 'eth1' link is up
Sun Apr 17 09:39:07 2022 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sun Apr 17 09:39:07 2022 daemon.err odhcp6c[2433]: Failed to send RS (Address not available)
Sun Apr 17 09:39:07 2022 daemon.notice hostapd: Configuration file: /var/run/hostapd-phy0.conf (phy wlan0) --> new PHY
Sun Apr 17 09:39:07 2022 kern.info kernel: [ 20.706587] mt7915_mcu_set_sku_en: enable = 1
Sun Apr 17 09:39:07 2022 cron.err crond[2693]: crond (busybox 1.33.2) started, log level 5
Sun Apr 17 09:39:07 2022 daemon.notice procd: /etc/rc.d/S50uhttpd: 4+0 records in
Sun Apr 17 09:39:07 2022 daemon.notice procd: /etc/rc.d/S50uhttpd: 4+0 records out
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.208157] br-lan: port 6(wlan0) entered blocking state
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.213521] br-lan: port 6(wlan0) entered disabled state
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.219104] device wlan0 entered promiscuous mode
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.224001] br-lan: port 6(wlan0) entered blocking state
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.229343] br-lan: port 6(wlan0) entered forwarding state
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.235269] br-lan: port 6(wlan0) entered disabled state
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/ssr_mudb_server reload trigger for non-procd /etc/init.d/ssr_mudb_server
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.318857] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.325398] br-lan: port 6(wlan0) entered blocking state
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.330754] br-lan: port 6(wlan0) entered forwarding state
Sun Apr 17 09:39:08 2022 user.notice ucitrack: Setting up /etc/config/shadowsocksr reload trigger for non-procd /etc/init.d/shadowsocksr
Sun Apr 17 09:39:08 2022 daemon.err odhcp6c[2433]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Sun Apr 17 09:39:08 2022 authpriv.info dropbear[3154]: Not backgrounding
Sun Apr 17 09:39:08 2022 daemon.notice hostapd: Configuration file: /var/run/hostapd-phy1.conf (phy wlan1) --> new PHY
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.457975] mt7915_mcu_set_sku_en: enable = 1
Sun Apr 17 09:39:08 2022 daemon.info dnsmasq[1966]: exiting on receipt of SIGTERM
Sun Apr 17 09:39:08 2022 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sun Apr 17 09:39:08 2022 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.907555] br-lan: port 7(wlan1) entered blocking state
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.912920] br-lan: port 7(wlan1) entered disabled state
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.918422] device wlan1 entered promiscuous mode
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.923211] br-lan: port 7(wlan1) entered blocking state
Sun Apr 17 09:39:08 2022 kern.info kernel: [ 21.928566] br-lan: port 7(wlan1) entered forwarding state
Sun Apr 17 09:39:08 2022 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Sun Apr 17 09:39:08 2022 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ACS
Sun Apr 17 09:39:08 2022 daemon.notice hostapd: wlan1: ACS-STARTED
Sun Apr 17 09:39:08 2022 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->ENABLED
Sun Apr 17 09:39:08 2022 daemon.notice hostapd: wlan0: AP-ENABLED
Sun Apr 17 09:39:09 2022 kern.info kernel: [ 22.243037] br-lan: port 7(wlan1) entered disabled state
Sun Apr 17 09:39:09 2022 daemon.notice netifd: Wireless device 'radio1' is now up
Sun Apr 17 09:39:09 2022 daemon.notice netifd: Wireless device 'radio0' is now up
Sun Apr 17 09:39:09 2022 daemon.notice netifd: Network device 'wlan0' link is up
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: Connected to system UBus
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: started, version 2.85 cachesize 150
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: DNS service limited to local subnets
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: UBus support enabled: connected to system bus
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq-dhcp[3563]: DHCP, IP range 192.168.2.100 -- 192.168.2.249, lease time 12h
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: using only locally-known addresses for domain test
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: using only locally-known addresses for domain onion
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: using only locally-known addresses for domain localhost
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: using only locally-known addresses for domain invalid
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: using only locally-known addresses for domain bind
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: using only locally-known addresses for domain lan
Sun Apr 17 09:39:11 2022 daemon.warn dnsmasq[3563]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: read /etc/hosts - 4 addresses
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Sun Apr 17 09:39:11 2022 daemon.info dnsmasq-dhcp[3563]: read /etc/ethers - 0 addresses
Sun Apr 17 09:39:12 2022 daemon.notice ksmbd: Starting Ksmbd userspace service.
Sun Apr 17 09:39:12 2022 cron.err crond[3880]: crond (busybox 1.33.2) started, log level 5
Sun Apr 17 09:39:12 2022 daemon.notice hostapd: wlan1: ACS-COMPLETED freq=5180 channel=36
Sun Apr 17 09:39:12 2022 daemon.notice hostapd: wlan1: interface state ACS->HT_SCAN
Sun Apr 17 09:39:13 2022 kern.info kernel: [ 26.180330] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Sun Apr 17 09:39:13 2022 kern.info kernel: [ 26.186795] br-lan: port 7(wlan1) entered blocking state
Sun Apr 17 09:39:13 2022 kern.info kernel: [ 26.192106] br-lan: port 7(wlan1) entered forwarding state
Sun Apr 17 09:39:13 2022 daemon.notice netifd: Network device 'wlan1' link is up
Sun Apr 17 09:39:13 2022 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Sun Apr 17 09:39:13 2022 daemon.notice hostapd: wlan1: AP-ENABLED
Sun Apr 17 09:39:14 2022 daemon.err hostapd: Failed to set beacon parameters
Sun Apr 17 09:39:17 2022 daemon.err wsdd2: samba36/4 or ksmbd is not running, can't start wsdd2!
Sun Apr 17 09:39:17 2022 daemon.info procd: - init complete -
Sun Apr 17 09:39:18 2022 daemon.err hostapd: Failed to set beacon parameters
Sun Apr 17 09:41:49 2022 daemon.info hostapd: wlan1: STA fc:b3:bc:02:78:3f IEEE 802.11: associated (aid 1)
Sun Apr 17 09:41:49 2022 daemon.notice hostapd: wlan1: STA-OPMODE-SMPS-MODE-CHANGED fc:b3:bc:02:78:3f off
Sun Apr 17 09:41:49 2022 daemon.notice hostapd: wlan1: AP-STA-CONNECTED fc:b3:bc:02:78:3f
Sun Apr 17 09:41:49 2022 daemon.info hostapd: wlan1: STA fc:b3:bc:02:78:3f RADIUS: starting accounting session 8F71FDC82F6D9B8C
Sun Apr 17 09:41:49 2022 daemon.info hostapd: wlan1: STA fc:b3:bc:02:78:3f WPA: pairwise key handshake completed (RSN)
Sun Apr 17 09:41:49 2022 daemon.notice hostapd: wlan1: EAPOL-4WAY-HS-COMPLETED fc:b3:bc:02:78:3f
Sun Apr 17 09:41:49 2022 daemon.info dnsmasq-dhcp[3563]: DHCPREQUEST(br-lan) 192.168.2.120 fc:b3:bc:02:78:3f
Sun Apr 17 09:41:49 2022 daemon.info dnsmasq-dhcp[3563]: DHCPACK(br-lan) 192.168.2.120 fc:b3:bc:02:78:3f Hulk-Yoga
Sun Apr 17 09:41:59 2022 daemon.info dnsmasq[3563]: read /etc/hosts - 4 addresses
Sun Apr 17 09:41:59 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/odhcpd - 0 addresses
Sun Apr 17 09:41:59 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Sun Apr 17 09:41:59 2022 daemon.info dnsmasq-dhcp[3563]: read /etc/ethers - 0 addresses
Sun Apr 17 09:42:00 2022 daemon.info dnsmasq[3563]: read /etc/hosts - 4 addresses
Sun Apr 17 09:42:00 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/odhcpd - 1 addresses
Sun Apr 17 09:42:00 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Sun Apr 17 09:42:00 2022 daemon.info dnsmasq-dhcp[3563]: read /etc/ethers - 0 addresses
Sun Apr 17 09:42:16 2022 authpriv.info dropbear[4066]: Child connection from 192.168.2.120:8205
Sun Apr 17 09:42:16 2022 authpriv.notice dropbear[4066]: Password auth succeeded for 'root' from 192.168.2.120:8205
Sun Apr 17 09:43:12 2022 user.info : luci: accepted login on /admin/network/network for root from 192.168.2.120
Sun Apr 17 09:44:38 2022 kern.info kernel: [ 352.043245] device lan0 left promiscuous mode
Sun Apr 17 09:44:38 2022 kern.info kernel: [ 352.047805] br-wan: port 1(lan0) entered disabled state
Sun Apr 17 09:44:38 2022 daemon.notice netifd: Interface 'wan' is disabled
Sun Apr 17 09:44:38 2022 daemon.notice netifd: Interface 'ONT' is disabled
Sun Apr 17 09:44:38 2022 kern.info kernel: [ 352.073259] mt7530 mdio-bus:1f lan0: configuring for phy/gmii link mode
Sun Apr 17 09:44:38 2022 kern.info kernel: [ 352.080638] 8021q: adding VLAN 0 to HW filter on device lan0
Sun Apr 17 09:44:38 2022 daemon.notice netifd: Interface 'wan' is enabled
Sun Apr 17 09:44:38 2022 daemon.notice netifd: Interface 'ONT' is enabled
Sun Apr 17 09:44:38 2022 kern.info kernel: [ 352.088660] br-wan: port 1(lan0) entered blocking state
Sun Apr 17 09:44:38 2022 kern.info kernel: [ 352.093889] br-wan: port 1(lan0) entered disabled state
Sun Apr 17 09:44:38 2022 kern.info kernel: [ 352.099455] device lan0 entered promiscuous mode
Sun Apr 17 09:45:14 2022 kern.info kernel: [ 387.908262] mt7530 mdio-bus:1f lan0: Link is Up - 1Gbps/Full - flow control rx/tx
Sun Apr 17 09:45:14 2022 kern.info kernel: [ 387.915781] br-wan: port 1(lan0) entered blocking state
Sun Apr 17 09:45:14 2022 kern.info kernel: [ 387.921003] br-wan: port 1(lan0) entered forwarding state
Sun Apr 17 09:45:14 2022 daemon.notice netifd: Network device 'lan0' link is up
Sun Apr 17 09:45:14 2022 daemon.notice netifd: Interface 'wan' has link connectivity
Sun Apr 17 09:45:14 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:45:14 2022 daemon.notice netifd: Interface 'ONT' has link connectivity
Sun Apr 17 09:45:14 2022 daemon.notice netifd: Interface 'ONT' is setting up now
Sun Apr 17 09:45:14 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:45:14 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:45:14 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:45:14 2022 daemon.notice netifd: ONT (4225): udhcpc: started, v1.33.2
Sun Apr 17 09:45:14 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:45:14 2022 daemon.info pppd[4231]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:45:14 2022 daemon.info pppd[4231]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:45:14 2022 daemon.notice netifd: ONT (4225): udhcpc: sending discover
Sun Apr 17 09:45:14 2022 daemon.notice pppd[4231]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:45:17 2022 daemon.notice netifd: ONT (4225): udhcpc: sending discover
Sun Apr 17 09:45:20 2022 daemon.notice netifd: ONT (4225): udhcpc: sending discover
Sun Apr 17 09:45:29 2022 daemon.warn pppd[4231]: Timeout waiting for PADO packets
Sun Apr 17 09:45:29 2022 daemon.err pppd[4231]: Unable to complete PPPoE Discovery
Sun Apr 17 09:45:29 2022 daemon.info pppd[4231]: Exit.
Sun Apr 17 09:45:29 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:45:29 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:45:30 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:45:30 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:45:30 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:45:30 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:45:30 2022 daemon.info pppd[4263]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:45:30 2022 daemon.info pppd[4263]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:45:30 2022 daemon.notice pppd[4263]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:45:44 2022 daemon.err pppd[4263]: select (waitForPADO): Interrupted system call
Sun Apr 17 09:45:44 2022 daemon.warn pppd[4263]: Timeout waiting for PADO packets
Sun Apr 17 09:45:44 2022 daemon.err pppd[4263]: Unable to complete PPPoE Discovery
Sun Apr 17 09:45:44 2022 daemon.info pppd[4263]: Exit.
Sun Apr 17 09:45:44 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:45:44 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:45:44 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:45:44 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:45:44 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:45:44 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:45:44 2022 daemon.info pppd[4445]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:45:44 2022 daemon.info pppd[4445]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:45:44 2022 daemon.notice pppd[4445]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:45:59 2022 daemon.warn pppd[4445]: Timeout waiting for PADO packets
Sun Apr 17 09:45:59 2022 daemon.err pppd[4445]: Unable to complete PPPoE Discovery
Sun Apr 17 09:45:59 2022 daemon.info pppd[4445]: Exit.
Sun Apr 17 09:45:59 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:45:59 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:45:59 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:45:59 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:45:59 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:45:59 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:45:59 2022 daemon.info pppd[4617]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:45:59 2022 daemon.info pppd[4617]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:45:59 2022 daemon.notice pppd[4617]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:46:14 2022 daemon.warn pppd[4617]: Timeout waiting for PADO packets
Sun Apr 17 09:46:14 2022 daemon.err pppd[4617]: Unable to complete PPPoE Discovery
Sun Apr 17 09:46:14 2022 daemon.info pppd[4617]: Exit.
Sun Apr 17 09:46:14 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:46:14 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:46:14 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:46:14 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:46:14 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:46:14 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:46:14 2022 daemon.info pppd[4789]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:46:14 2022 daemon.info pppd[4789]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:46:14 2022 daemon.notice pppd[4789]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.515126] br-wan: port 1(lan0) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.520464] br-wan: port 2(eth1) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.527132] device eth1 left promiscuous mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.531551] br-wan: port 2(eth1) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.555612] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.561616] device lan0 left promiscuous mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.566124] br-wan: port 1(lan0) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.660688] mtk_soc_eth 15100000.ethernet eth1: configuring for fixed/2500base-x link mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.669047] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.669522] br-wan: port 1(eth1) entered blocking state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.682902] br-wan: port 1(eth1) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.688306] device eth1 entered promiscuous mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.693542] br-wan: port 2(lan0) entered blocking state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.698772] br-wan: port 2(lan0) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.704342] device lan0 entered promiscuous mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.712410] br-wan: port 2(lan0) entered blocking state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.717629] br-wan: port 2(lan0) entered forwarding state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.723056] br-wan: port 1(eth1) entered blocking state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.728269] br-wan: port 1(eth1) entered forwarding state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.734376] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.741878] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.750191] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.758856] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sun Apr 17 09:46:27 2022 daemon.err odhcp6c[2433]: Failed to send SOLICIT message to ff02::1:2 (Permission denied)
Sun Apr 17 09:46:27 2022 daemon.notice netifd: Interface 'wan6' is now down
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.808271] br-wan: port 2(lan0) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.813619] br-wan: port 1(eth1) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.822485] device eth1 left promiscuous mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.826921] br-wan: port 1(eth1) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.847442] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.855085] device lan0 left promiscuous mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.859574] br-wan: port 2(lan0) entered disabled state
Sun Apr 17 09:46:27 2022 daemon.notice netifd: Interface 'wan6' is disabled
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.964565] mtk_soc_eth 15100000.ethernet eth1: configuring for fixed/2500base-x link mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.972881] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.973211] br-wan: port 1(eth1) entered blocking state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.986739] br-wan: port 1(eth1) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.992119] device eth1 entered promiscuous mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 460.997441] br-wan: port 2(lan0) entered blocking state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 461.002678] br-wan: port 2(lan0) entered disabled state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 461.008220] device lan0 entered promiscuous mode
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 461.016292] br-wan: port 2(lan0) entered blocking state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 461.021512] br-wan: port 2(lan0) entered forwarding state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 461.026928] br-wan: port 1(eth1) entered blocking state
Sun Apr 17 09:46:27 2022 kern.info kernel: [ 461.032141] br-wan: port 1(eth1) entered forwarding state
Sun Apr 17 09:46:27 2022 daemon.notice netifd: Interface 'wan6' is enabled
Sun Apr 17 09:46:27 2022 daemon.notice netifd: Interface 'wan6' is setting up now
Sun Apr 17 09:46:27 2022 daemon.notice netifd: ONT (4225): udhcpc: sending select for 192.168.1.2
Sun Apr 17 09:46:27 2022 daemon.err odhcp6c[5102]: Failed to send RS (Address not available)
Sun Apr 17 09:46:28 2022 daemon.err odhcp6c[5102]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Sun Apr 17 09:46:29 2022 daemon.err odhcp6c[5102]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Sun Apr 17 09:46:29 2022 daemon.warn pppd[4789]: Timeout waiting for PADO packets
Sun Apr 17 09:46:29 2022 daemon.err pppd[4789]: Unable to complete PPPoE Discovery
Sun Apr 17 09:46:29 2022 daemon.info pppd[4789]: Exit.
Sun Apr 17 09:46:29 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:46:29 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:46:29 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:46:29 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:46:29 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:46:29 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:46:29 2022 daemon.info pppd[5284]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:46:29 2022 daemon.info pppd[5284]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:46:29 2022 daemon.notice pppd[5284]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:46:30 2022 daemon.notice netifd: ONT (4225): udhcpc: sending select for 192.168.1.2
Sun Apr 17 09:46:33 2022 daemon.notice netifd: ONT (4225): udhcpc: sending select for 192.168.1.2
Sun Apr 17 09:46:44 2022 daemon.warn pppd[5284]: Timeout waiting for PADO packets
Sun Apr 17 09:46:44 2022 daemon.err pppd[5284]: Unable to complete PPPoE Discovery
Sun Apr 17 09:46:44 2022 daemon.info pppd[5284]: Exit.
Sun Apr 17 09:46:45 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:46:45 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:46:45 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:46:45 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:46:45 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:46:45 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:46:45 2022 daemon.info pppd[5460]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:46:45 2022 daemon.info pppd[5460]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:46:45 2022 daemon.notice pppd[5460]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:47:00 2022 daemon.warn pppd[5460]: Timeout waiting for PADO packets
Sun Apr 17 09:47:00 2022 daemon.err pppd[5460]: Unable to complete PPPoE Discovery
Sun Apr 17 09:47:00 2022 daemon.info pppd[5460]: Exit.
Sun Apr 17 09:47:00 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:47:00 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:47:00 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:47:00 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:47:00 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:47:00 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:47:00 2022 daemon.info pppd[5632]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:47:00 2022 daemon.info pppd[5632]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:47:00 2022 daemon.notice pppd[5632]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:47:04 2022 daemon.notice ksmbd: Stopping Ksmbd userspace service.
Sun Apr 17 09:47:04 2022 daemon.notice ksmbd: Starting Ksmbd userspace service.
Sun Apr 17 09:47:04 2022 daemon.info dnsmasq[3563]: read /etc/hosts - 4 addresses
Sun Apr 17 09:47:04 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/odhcpd - 1 addresses
Sun Apr 17 09:47:04 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Sun Apr 17 09:47:04 2022 daemon.info dnsmasq-dhcp[3563]: read /etc/ethers - 0 addresses
Sun Apr 17 09:47:04 2022 daemon.err pppd[5632]: select (waitForPADO): Interrupted system call
Sun Apr 17 09:47:04 2022 daemon.warn pppd[5632]: Timeout waiting for PADO packets
Sun Apr 17 09:47:04 2022 daemon.err pppd[5632]: Unable to complete PPPoE Discovery
Sun Apr 17 09:47:04 2022 daemon.info pppd[5632]: Exit.
Sun Apr 17 09:47:04 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:47:04 2022 daemon.notice netifd: Interface 'wan' has link connectivity loss
Sun Apr 17 09:47:04 2022 daemon.notice netifd: VLAN 'lan0.41' link is up
Sun Apr 17 09:47:04 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:47:04 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:47:04 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:47:04 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:47:04 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:47:04 2022 daemon.info pppd[6160]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:47:04 2022 daemon.info pppd[6160]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:47:04 2022 daemon.notice pppd[6160]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:47:05 2022 daemon.info dnsmasq[3563]: read /etc/hosts - 4 addresses
Sun Apr 17 09:47:05 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/odhcpd - 1 addresses
Sun Apr 17 09:47:05 2022 daemon.info dnsmasq[3563]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Sun Apr 17 09:47:05 2022 daemon.info dnsmasq-dhcp[3563]: read /etc/ethers - 0 addresses
Sun Apr 17 09:47:05 2022 daemon.notice ksmbd: Stopping Ksmbd userspace service.
Sun Apr 17 09:47:05 2022 daemon.notice ksmbd: Starting Ksmbd userspace service.
Sun Apr 17 09:47:19 2022 daemon.warn pppd[6160]: Timeout waiting for PADO packets
Sun Apr 17 09:47:19 2022 daemon.err pppd[6160]: Unable to complete PPPoE Discovery
Sun Apr 17 09:47:19 2022 daemon.info pppd[6160]: Exit.
Sun Apr 17 09:47:19 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:47:20 2022 daemon.notice netifd: Interface 'wan' is disabled
Sun Apr 17 09:47:20 2022 daemon.notice netifd: Interface 'wan' is enabled
Sun Apr 17 09:47:20 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:47:20 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:47:20 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:47:20 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:47:20 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:47:20 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:47:20 2022 daemon.info pppd[6806]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:47:20 2022 daemon.info pppd[6806]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:47:20 2022 daemon.notice pppd[6806]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:47:35 2022 daemon.warn pppd[6806]: Timeout waiting for PADO packets
Sun Apr 17 09:47:35 2022 daemon.err pppd[6806]: Unable to complete PPPoE Discovery
Sun Apr 17 09:47:35 2022 daemon.info pppd[6806]: Exit.
Sun Apr 17 09:47:35 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:47:35 2022 daemon.notice netifd: Interface 'wan' is disabled
Sun Apr 17 09:47:35 2022 daemon.notice netifd: Interface 'wan' is enabled
Sun Apr 17 09:47:35 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:47:35 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:47:35 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:47:35 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:47:35 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:47:35 2022 daemon.info pppd[7014]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:47:35 2022 daemon.info pppd[7014]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:47:35 2022 daemon.notice pppd[7014]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:47:50 2022 daemon.warn pppd[7014]: Timeout waiting for PADO packets
Sun Apr 17 09:47:50 2022 daemon.err pppd[7014]: Unable to complete PPPoE Discovery
Sun Apr 17 09:47:50 2022 daemon.info pppd[7014]: Exit.
Sun Apr 17 09:47:50 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:47:50 2022 daemon.notice netifd: Interface 'wan' is disabled
Sun Apr 17 09:47:50 2022 daemon.notice netifd: Interface 'wan' is enabled
Sun Apr 17 09:47:50 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:47:50 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:47:50 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:47:51 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:47:51 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:47:51 2022 daemon.info pppd[7217]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:47:51 2022 daemon.info pppd[7217]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:47:51 2022 daemon.notice pppd[7217]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:48:06 2022 daemon.warn pppd[7217]: Timeout waiting for PADO packets
Sun Apr 17 09:48:06 2022 daemon.err pppd[7217]: Unable to complete PPPoE Discovery
Sun Apr 17 09:48:06 2022 daemon.info pppd[7217]: Exit.
Sun Apr 17 09:48:06 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:48:06 2022 daemon.notice netifd: Interface 'wan' is disabled
Sun Apr 17 09:48:06 2022 daemon.notice netifd: Interface 'wan' is enabled
Sun Apr 17 09:48:06 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:48:06 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:48:06 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:48:06 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:48:06 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:48:06 2022 daemon.info pppd[7424]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:48:06 2022 daemon.info pppd[7424]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:48:06 2022 daemon.notice pppd[7424]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:48:21 2022 daemon.warn pppd[7424]: Timeout waiting for PADO packets
Sun Apr 17 09:48:21 2022 daemon.err pppd[7424]: Unable to complete PPPoE Discovery
Sun Apr 17 09:48:21 2022 daemon.info pppd[7424]: Exit.
Sun Apr 17 09:48:21 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:48:21 2022 daemon.notice netifd: Interface 'wan' is disabled
Sun Apr 17 09:48:21 2022 daemon.notice netifd: Interface 'wan' is enabled
Sun Apr 17 09:48:21 2022 daemon.notice netifd: Interface 'wan' is setting up now
Sun Apr 17 09:48:21 2022 daemon.err insmod: module is already loaded - slhc
Sun Apr 17 09:48:21 2022 daemon.err insmod: module is already loaded - ppp_generic
Sun Apr 17 09:48:21 2022 daemon.err insmod: module is already loaded - pppox
Sun Apr 17 09:48:21 2022 daemon.err insmod: module is already loaded - pppoe
Sun Apr 17 09:48:21 2022 daemon.info pppd[7627]: Plugin rp-pppoe.so loaded.
Sun Apr 17 09:48:21 2022 daemon.info pppd[7627]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sun Apr 17 09:48:21 2022 daemon.notice pppd[7627]: pppd 2.4.8 started by root, uid 0
Sun Apr 17 09:48:35 2022 daemon.notice netifd: Network device 'lan0' link is down
Sun Apr 17 09:48:35 2022 daemon.notice netifd: Interface 'ONT' has link connectivity loss
Sun Apr 17 09:48:35 2022 kern.info kernel: [ 588.611535] br-wan: port 2(lan0) entered disabled state
Sun Apr 17 09:48:35 2022 kern.info kernel: [ 588.617003] mt7530 mdio-bus:1f lan0: Link is Down
Sun Apr 17 09:48:35 2022 daemon.notice netifd: VLAN 'lan0.41' link is down
Sun Apr 17 09:48:35 2022 daemon.notice netifd: Interface 'wan' has link connectivity loss
Sun Apr 17 09:48:35 2022 daemon.notice netifd: ONT (4225): udhcpc: received SIGTERM
Sun Apr 17 09:48:35 2022 daemon.notice netifd: ONT (4225): udhcpc: entering released state
Sun Apr 17 09:48:35 2022 daemon.notice netifd: ONT (4225): Command failed: Permission denied
Sun Apr 17 09:48:35 2022 daemon.err pppd[7627]: select (waitForPADO): Interrupted system call
Sun Apr 17 09:48:35 2022 daemon.warn pppd[7627]: Timeout waiting for PADO packets
Sun Apr 17 09:48:35 2022 daemon.notice netifd: Interface 'ONT' is now down
Sun Apr 17 09:48:35 2022 daemon.err pppd[7627]: Unable to complete PPPoE Discovery
Sun Apr 17 09:48:35 2022 daemon.info pppd[7627]: Exit.
Sun Apr 17 09:48:35 2022 daemon.notice netifd: Interface 'wan' is now down
Sun Apr 17 09:48:35 2022 daemon.notice netifd: Interface 'wan' is disabled
Sun Apr 17 09:48:35 2022 daemon.notice netifd: Interface 'wan' is enabled
