yesterday I was trying to install my BPI-R3-Mini in production but I experienced an issue when directly attach a Gigaset A510 IP base station.
This client is only 100Mbps, the link is successfully negotiated, but not traffic. Only way to make it works is to use a gigabit switch that will handle the 100Mbps link.
What do you mean for latest version? I’ve installed snapshot 2600x still based on kernel 6.1 and this client directly connected doesn’t pass any traffic
For the moment I’ve got a cheap 1G switch and put between
EDIT: oh wait for net-next you mean 6.8 and other kernels?
Openwrt only uses lts kernel versions as there is much work porting patches. Last is 6.6 (6.8 and 6.9 are no lts…next is around 6.11) and maybe erics driver will be backported…afair currently it is also an earlier version of his version.
