Got an update. Magically, after updating some packages today (might be unrelated!) and restarting the 4G modem started to work as expected. No, at least intentional, change to the configuration … as follows my log in case anyone spots the difference compared to previously shared logs.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 0.000000] Linux version 5.15.134 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.3.0 r23497-6637af95aa) 12.3.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Mon Oct 9 21:45:35 2023
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Machine model: Bananapi BPI-R3
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Zone ranges:
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] DMA [mem 0x0000000040000000-0x00000000bfffffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] DMA32 empty
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Normal empty
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Movable zone start for each node
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Early memory node ranges
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000043000000-0x000000004302ffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000043030000-0x000000004fbfffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] node 0: [mem 0x000000004fc00000-0x000000004ffbffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] node 0: [mem 0x000000004ffc0000-0x00000000bfffffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] psci: probing for conduit method from DT.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] psci: PSCIv1.1 detected in firmware.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] psci: SMC Calling Convention v1.4
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] percpu: Embedded 17 pages/cpu s30040 r8192 d31400 u69632
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 0.000000] pcpu-alloc: s30040 r8192 d31400 u69632 alloc=17*4096
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Detected VIPT I-cache on CPU0
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] CPU features: detected: GIC system register CPU interface
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 0.000000] Kernel command line: root=/dev/mmcblk0p65
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Memory: 2040968K/2097152K available (8384K kernel code, 912K rwdata, 1472K rodata, 448K init, 303K bss, 56184K reserved, 0K cma-reserved)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Tracing variant of Tasks RCU enabled.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] GICv3: 640 SPIs implemented
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] GICv3: 0 Extended SPIs implemented
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] GICv3: Distributor has no Range Selector support
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] Root IRQ handler: 0xffffffc008421f74
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] GICv3: 16 PPIs implemented
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 13.00MHz (phys).
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000123] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000131] pid_max: default: 32768 minimum: 301
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000338] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.000350] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.001378] rcu: Hierarchical SRCU implementation.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.001670] smp: Bringing up secondary CPUs ...
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.001928] Detected VIPT I-cache on CPU1
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.001950] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.001975] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002238] Detected VIPT I-cache on CPU2
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002250] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002261] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002496] Detected VIPT I-cache on CPU3
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002506] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002514] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002540] smp: Brought up 1 node, 4 CPUs
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002553] SMP: Total of 4 processors activated.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002556] CPU features: detected: 32-bit EL0 Support
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002559] CPU features: detected: CRC32 instructions
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002582] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002635] CPU: All CPU(s) started at EL2
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.002645] alternatives: patching kernel code
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.005536] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.005559] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.005703] pinctrl core: initialized pinctrl subsystem
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.006329] NET: Registered PF_NETLINK/PF_ROUTE protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.006576] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.006606] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.006631] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.006877] thermal_sys: Registered thermal governor 'fair_share'
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.006880] thermal_sys: Registered thermal governor 'bang_bang'
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.006883] thermal_sys: Registered thermal governor 'step_wise'
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.006886] thermal_sys: Registered thermal governor 'user_space'
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.007080] ASID allocator initialised with 65536 entries
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.007399] pstore: Registered ramoops as persistent store backend
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.007402] ramoops: using 0x10000@0x42ff0000, ecc: 0
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.017106] cryptd: max_cpu_qlen set to 1000
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.018699] 1.8vd: supplied by 12vd
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.018862] 3.3vd: supplied by 12vd
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 0.019112] SCSI subsystem initialized
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 0.019198] libata version 3.00 loaded.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.020080] clocksource: Switched to clocksource arch_sys_counter
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.020532] NET: Registered PF_INET protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.020637] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021304] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021323] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021331] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021398] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021571] TCP: Hash tables configured (established 16384 bind 16384)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021645] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021673] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021800] NET: Registered PF_UNIX/PF_LOCAL protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.021820] PCI: CLS 0 bytes, default 64
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.023880] workingset: timestamp_bits=46 max_order=19 bucket_order=0
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.026522] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.026534] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.048494] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Mon Nov 13 10:07:44 2023 kern.err kernel: [ 0.049560] pwm-mediatek 10048000.pwm: clock: top fail: -517
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.049827] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 0.049844] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.049852] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
Mon Nov 13 10:07:44 2023 kern.err kernel: [ 0.049923] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
Mon Nov 13 10:07:44 2023 kern.err kernel: [ 0.049931] mtk-pcie-gen3 11280000.pcie: failed to get clocks
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.052735] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.054089] printk: console [ttyS0] disabled
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.074235] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.761823] printk: console [ttyS0] enabled
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.786594] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.816318] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 124, base_baud = 1625000) is a ST16650V2
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.826148] mtk_rng 1020f000.rng: registered RNG driver
Mon Nov 13 10:07:44 2023 kern.warn kernel: [ 0.826207] hwrng: no data available
Mon Nov 13 10:07:44 2023 kern.warn kernel: [ 0.831645] cacheinfo: Unable to detect cache hierarchy for CPU 0
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.843105] loop: module loaded
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.846254] Loading iSCSI transport class v2.0-870.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.852567] spi-nand spi0.0: Winbond SPI NAND was found.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 0.857874] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 0.866120] 4 fixed-partitions partitions found on MTD device spi0.0
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 0.872463] Creating 4 MTD partitions on "spi0.0":
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 0.877236] 0x000000580000-0x000008000000 : "ubi"
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 1.009214] 0x000000380000-0x000000580000 : "fip"
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 1.016320] 0x000000080000-0x000000380000 : "reserved"
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 1.024888] 0x000000000000-0x000000080000 : "bl2"
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.163217] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009680000, irq 136
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.173011] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009680000, irq 136
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.182543] i2c_dev: i2c /dev entries driver
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.188297] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.196823] NET: Registered PF_INET6 protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.202433] Segment Routing with IPv6
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.206105] In-situ OAM (IOAM) with IPv6
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.210068] NET: Registered PF_PACKET protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.215128] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.228297] 8021q: 802.1Q VLAN Support v1.8
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.233317] pstore: Using crash dump compression: deflate
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.244395] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.251734] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.257987] mtk-pcie-gen3 11280000.pcie: MEM 0x0020000000..0x002fffffff -> 0x0020000000
Mon Nov 13 10:07:44 2023 kern.warn kernel: [ 1.274628] mmc0: host does not support reading read-only switch, assuming write-enable
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.285458] mmc0: new high speed SDXC card at address aaaa
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.291721] mmcblk0: mmc0:aaaa SC256 238 GiB
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.303140] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.312183] FIT: kernel sub-image 0x00001000..0x004ed1ae "kernel-1" (ARM64 OpenWrt Linux-5.15.134)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.322082] FIT: flat_dt sub-image 0x004ee000..0x004f5b66 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.333282] FIT: flat_dt sub-image 0x004f6000..0x004f61dc "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.349597] FIT: flat_dt sub-image 0x004f7000..0x004f7390 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.365915] FIT: flat_dt sub-image 0x004f8000..0x004f838f "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.382061] FIT: flat_dt sub-image 0x004f9000..0x004f9146 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.398025] FIT: filesystem sub-image 0x004fa000..0x00a4dfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 1.408612] FIT: selecting configured loadable "rootfs-1" to be root filesystem
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.415905] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p65(rootfs-1) p66(rootfs_data)
Mon Nov 13 10:07:44 2023 kern.err kernel: [ 1.482067] mtk-pcie-gen3 11280000.pcie: PCIe link down, ltssm reg val: 0x1000001
Mon Nov 13 10:07:44 2023 kern.warn kernel: [ 1.489564] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.518397] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.527447] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.536134] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=144)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.556471] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=145)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.576495] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=146)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.596495] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=147)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.616482] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=148)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 1.627587] DSA: tree 0 setup
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 1.632721] UBI: auto-attach mtd0
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 1.636034] ubi0: default fastmap pool size: 45
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 1.640555] ubi0: default fastmap WL pool size: 22
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 1.645329] ubi0: attaching mtd0
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.249357] ubi0: scanning is finished
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.294294] ubi0: attached mtd0 (name "ubi", size 122 MiB)
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.299774] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.306635] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.313404] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.320347] ubi0: good PEBs: 980, bad PEBs: 0, corrupted PEBs: 0
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.326332] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.333533] ubi0: max/mean erase counter: 3/0, WL threshold: 4096, image sequence number: 1642748947
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.342641] ubi0: available PEBs: 465, total reserved PEBs: 515, PEBs reserved for bad PEB handling: 20
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 5.352015] ubi0: background thread "ubi_bgt0d" started, PID 556
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.358072] block ubiblock0_1: created from ubi0:1(rootfs)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.372452] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.379721] Freeing unused kernel memory: 448K
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.410102] Run /sbin/init as init process
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 5.414182] with arguments:
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 5.417132] /sbin/init
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 5.419823] with environment:
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 5.422952] HOME=/
Mon Nov 13 10:07:44 2023 kern.debug kernel: [ 5.425296] TERM=linux
Mon Nov 13 10:07:44 2023 user.info kernel: [ 5.550314] init: Console is alive
Mon Nov 13 10:07:44 2023 user.info kernel: [ 5.553805] init: - watchdog -
Mon Nov 13 10:07:44 2023 user.info kernel: [ 5.813749] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.836017] usbcore: registered new interface driver usbfs
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.841550] usbcore: registered new interface driver hub
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.846874] usbcore: registered new device driver usb
Mon Nov 13 10:07:44 2023 kern.warn kernel: [ 5.855237] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
Mon Nov 13 10:07:44 2023 kern.warn kernel: [ 5.862644] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.870787] xhci-mtk 11200000.usb: xHCI Host Controller
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.876016] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.886467] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.895617] xhci-mtk 11200000.usb: irq 128, io mem 0x11200000
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.901447] xhci-mtk 11200000.usb: xHCI Host Controller
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.906657] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.914041] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.921422] hub 1-0:1.0: USB hub found
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.925175] hub 1-0:1.0: 2 ports detected
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.929409] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.937748] hub 2-0:1.0: USB hub found
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 5.941510] hub 2-0:1.0: 1 port detected
Mon Nov 13 10:07:44 2023 user.info kernel: [ 5.947768] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Mon Nov 13 10:07:44 2023 user.info kernel: [ 5.961779] init: - preinit -
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 6.163018] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 6.171488] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 6.179661] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 6.410054] usb 1-1: new high-speed USB device number 2 using xhci-mtk
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 6.590725] hub 1-1:1.0: USB hub found
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 6.591641] random: procd: uninitialized urandom read (4 bytes read)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 6.594505] hub 1-1:1.0: 4 ports detected
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 7.020054] usb 1-1.1: new high-speed USB device number 3 using xhci-mtk
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 9.221164] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = 1ae19688
Mon Nov 13 10:07:44 2023 user.info kernel: [ 9.231665] mount_root: switching to f2fs overlay
Mon Nov 13 10:07:44 2023 kern.warn kernel: [ 9.238323] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
Mon Nov 13 10:07:44 2023 user.debug kernel: [ 9.254304] urandom-seed: Seeding with /etc/urandom.seed
Mon Nov 13 10:07:44 2023 user.info kernel: [ 9.292463] procd: - early -
Mon Nov 13 10:07:44 2023 user.info kernel: [ 9.295388] procd: - watchdog -
Mon Nov 13 10:07:44 2023 user.info kernel: [ 9.825166] procd: - watchdog -
Mon Nov 13 10:07:44 2023 user.info kernel: [ 9.829298] procd: - ubus -
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 9.854044] random: ubusd: uninitialized urandom read (4 bytes read)
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 9.881425] random: ubusd: uninitialized urandom read (4 bytes read)
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 9.890596] random: ubusd: uninitialized urandom read (4 bytes read)
Mon Nov 13 10:07:44 2023 user.info kernel: [ 9.899354] procd: - init -
Mon Nov 13 10:07:44 2023 user.info kernel: [ 10.120309] kmodloader: loading kernel modules from /etc/modules.d/*
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.132418] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.139035] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.148240] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.162818] usbcore: registered new interface driver cdc_wdm
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.168737] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.176220] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.186663] sfp sfp-1: Host maximum power 3.0W
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.191917] sfp sfp-2: Host maximum power 3.0W
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.198843] usbcore: registered new interface driver usbserial_generic
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.205443] usbserial: USB Serial support registered for generic
Mon Nov 13 10:07:44 2023 user.info kernel: [ 10.243052] urngd: v1.0.2 started.
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 10.347471] random: crng init done
Mon Nov 13 10:07:44 2023 kern.notice kernel: [ 10.350872] random: 28 urandom warning(s) missed due to ratelimiting
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.683497] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.810241] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 10.887300] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 13.656961] PPP generic driver version 2.4.2
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 13.661941] NET: Registered PF_PPPOX protocol family
Mon Nov 13 10:07:44 2023 kern.err kernel: [ 13.667824] xhci-mtk 11200000.usb: drop_ep_quirk high-speed ep9in intr, mpkt:8, interval:9/32ms
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 13.677368] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 13.683666] qmi_wwan 1-1.1:1.4 wwan0: register 'qmi_wwan' at usb-11200000.usb-1.1, WWAN/QMI device, 12:ae:6f:c1:87:d7
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 13.694424] usbcore: registered new interface driver qmi_wwan
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 13.704604] usbcore: registered new interface driver qcserial
Mon Nov 13 10:07:44 2023 kern.info kernel: [ 13.710422] usbserial: USB Serial support registered for Qualcomm USB modem
Mon Nov 13 10:07:44 2023 user.info kernel: [ 13.717631] kmodloader: done loading kernel modules from /etc/modules.d/*
Mon Nov 13 10:07:45 2023 daemon.notice procd: /etc/rc.d/S13openssl: Generating engines.cnf
Mon Nov 13 10:07:45 2023 daemon.notice procd: /etc/rc.d/S13openssl: Generating providers.cnf
Mon Nov 13 10:07:45 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mon Nov 13 10:07:45 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: DNS service limited to local subnets
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:07:45 2023 daemon.warn dnsmasq[1]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 6 names
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: bonding
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: 8021ad
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: 8021q
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: macvlan
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: veth
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: bridge
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: Network device
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: tunnel
Mon Nov 13 10:07:45 2023 daemon.notice procd: /etc/rc.d/S25packet_steering: uci: Entry not found
Mon Nov 13 10:07:45 2023 daemon.notice wpa_supplicant[1778]: Successfully initialized wpa_supplicant
Mon Nov 13 10:07:45 2023 cron.err crond[2030]: crond (busybox 1.36.1) started, log level 5
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: configfile: stat (/etc/collectd/conf.d/*.conf) failed: No such file or directory
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "cpu" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "interface" successfully loaded.
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/network
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/wireless
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "iwinfo" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "load" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "memory" successfully loaded.
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/luci-splash reload dependency on /etc/config/firewall
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/qos reload dependency on /etc/config/firewall
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/miniupnpd reload dependency on /etc/config/firewall
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "rrdtool" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: rrdtool plugin: RRASingle = true: creating only AVERAGE RRAs
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "sensors" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: Initialization complete, entering read-loop.
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.358508] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/odhcpd reload dependency on /etc/config/dhcp
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.370704] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.379136] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.383354] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.397767] br-lan: port 1(lan1) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.403061] br-lan: port 1(lan1) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.409716] device lan1 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.414450] device eth0 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.421492] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'lan' is enabled
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'lan' is setting up now
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'lan' is now up
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.437772] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.447664] br-lan: port 2(lan2) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.452936] br-lan: port 2(lan2) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.459913] device lan2 entered promiscuous mode
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.472088] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.481951] br-lan: port 3(lan3) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.487178] br-lan: port 3(lan3) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.494447] device lan3 entered promiscuous mode
Mon Nov 13 10:07:46 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/luci_statistics reload dependency on /etc/config/system
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.506490] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.516405] br-lan: port 4(lan4) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.521680] br-lan: port 4(lan4) entered disabled state
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/system
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.528937] device lan4 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.538083] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.547805] br-lan: port 5(sfp2) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.553097] br-lan: port 5(sfp2) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.560572] device sfp2 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.569227] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.579780] br-wan: port 1(eth1) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.585128] br-wan: port 1(eth1) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.590616] device eth1 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.596845] br-wan: port 1(eth1) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.602117] br-wan: port 1(eth1) entered forwarding state
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' is enabled
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan6' is enabled
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.612477] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.622245] br-wan: port 2(wan) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.627395] br-wan: port 2(wan) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [ 15.634129] device wan entered promiscuous mode
Mon Nov 13 10:07:46 2023 daemon.notice netifd: bridge 'br-wan' link is up
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' has link connectivity
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' is setting up now
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan6' has link connectivity
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'loopback' is enabled
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'loopback' is setting up now
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'loopback' is now up
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'qmi_wwan' is setting up now
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Network device 'eth0' link is up
Mon Nov 13 10:07:46 2023 daemon.notice netifd: bridge 'br-wan' link is down
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' has link connectivity loss
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Network device 'lo' link is up
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'loopback' has link connectivity
Mon Nov 13 10:07:46 2023 daemon.notice netifd: radio1 (2595): WARNING: Variable 'data' does not exist or is not an array/object
Mon Nov 13 10:07:46 2023 daemon.notice netifd: qmi_wwan (2592): Waiting for SIM initialization
Mon Nov 13 10:07:46 2023 daemon.notice netifd: radio0 (2594): WARNING: Variable 'data' does not exist or is not an array/object
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' is now down
Mon Nov 13 10:07:46 2023 daemon.info pppd[2676]: Plugin pppoe.so loaded.
Mon Nov 13 10:07:46 2023 daemon.info pppd[2676]: PPPoE plugin from pppd 2.4.9
Mon Nov 13 10:07:46 2023 daemon.notice pppd[2676]: pppd 2.4.9 started by root, uid 0
Mon Nov 13 10:07:46 2023 daemon.info procd: - init complete -
Mon Nov 13 10:07:47 2023 daemon.notice netifd: qmi_wwan (2592): Failed to parse message data
Mon Nov 13 10:07:47 2023 daemon.notice netifd: qmi_wwan (2592): PIN already verified
Mon Nov 13 10:07:47 2023 kern.info kernel: [ 16.400938] br-wan: port 1(eth1) entered disabled state
Mon Nov 13 10:07:47 2023 authpriv.warn dropbear[2944]: Failed listening on '2101': Error listening: Address not available
Mon Nov 13 10:07:47 2023 authpriv.info dropbear[2944]: Not backgrounding
Mon Nov 13 10:07:47 2023 daemon.notice netifd: qmi_wwan (2592): Device does not support 802.3 mode. Informing driver of raw-ip only for wwan0 ..
Mon Nov 13 10:07:47 2023 daemon.notice hostapd: Set new config for phy phy1:
Mon Nov 13 10:07:47 2023 daemon.notice wpa_supplicant[1778]: Set new config for phy phy1
Mon Nov 13 10:07:47 2023 daemon.notice hostapd: Set new config for phy phy0:
Mon Nov 13 10:07:47 2023 daemon.notice wpa_supplicant[1778]: Set new config for phy phy0
Mon Nov 13 10:07:47 2023 daemon.notice netifd: qmi_wwan (2592): Waiting for network registration
Mon Nov 13 10:07:47 2023 daemon.notice netifd: radio0 (2594): sh: acs_survey: out of range
Mon Nov 13 10:07:48 2023 daemon.notice netifd: radio0 (2594): sh: acs_survey: out of range
Mon Nov 13 10:07:48 2023 daemon.notice wpa_supplicant[1778]: Set new config for phy phy1
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Set new config for phy phy1: /var/run/hostapd-phy1.conf
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Restart interface for phy phy1
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=DE ieee80211d=1 ieee80211h=1 hw_mode=a beacon_int=100 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935] ieee80211ac=1 vht_oper_chwidth=2 vht_oper_centr_freq_seg0_idx=acs_survey vht_capab=[RXLDPC][SHORT-GI-80][SHORT-GI-160][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-4][BF-ANTENNA-4][VHT160][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7] ieee80211ax=1 he_oper_chwidth=2 he_oper_centr_freq_seg0_idx=acs_survey he_su_beamformer=1 he_su_beamformee=1 he_mu_beamformer=1 he_bss_color=128 he_spr_sr_control=3 he_default_pe_duration=4 he_rts_threshold=1023 he_mu_edca_qos_info_param_count=0 he_mu_edca_qos_info_q_ack=0 he_mu_edca_qos_info_queue_request=0 he_mu_edca_qos_in
Mon Nov 13 10:07:48 2023 daemon.notice wpa_supplicant[1778]: Set new config for phy phy0
Mon Nov 13 10:07:48 2023 kern.info kernel: [ 17.145873] br-lan: port 6(phy1-ap0) entered blocking state
Mon Nov 13 10:07:48 2023 kern.info kernel: [ 17.151537] br-lan: port 6(phy1-ap0) entered disabled state
Mon Nov 13 10:07:48 2023 kern.info kernel: [ 17.157328] device phy1-ap0 entered promiscuous mode
Mon Nov 13 10:07:48 2023 kern.info kernel: [ 17.711831] br-lan: port 6(phy1-ap0) entered blocking state
Mon Nov 13 10:07:48 2023 kern.info kernel: [ 17.717410] br-lan: port 6(phy1-ap0) entered forwarding state
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: phy1-ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Mon Nov 13 10:07:48 2023 kern.info kernel: [ 17.725960] device phy1-ap0 left promiscuous mode
Mon Nov 13 10:07:48 2023 kern.info kernel: [ 17.730785] br-lan: port 6(phy1-ap0) entered disabled state
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: phy1-ap0: interface state COUNTRY_UPDATE->ACS
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: phy1-ap0: ACS-STARTED
Mon Nov 13 10:07:48 2023 daemon.notice netifd: bridge 'br-wan' link is down
Mon Nov 13 10:07:48 2023 daemon.notice netifd: Interface 'wan' has link connectivity loss
Mon Nov 13 10:07:48 2023 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Restart interface for phy phy0
Mon Nov 13 10:07:48 2023 daemon.err pppd[2676]: select (waitForPADO): Interrupted system call
Mon Nov 13 10:07:48 2023 daemon.warn pppd[2676]: Timeout waiting for PADO packets
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=DE ieee80211d=1 hw_mode=g supported_rates=60 90 120 180 240 360 480 540 basic_rates=60 120 240 beacon_int=100 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935] channel=acs_survey interface=phy0-ap0 bssid=9a:ab:b8:68:ce:3c ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 disassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_advertisement_enabled=1 utf8_ssid=1 multi_ap=0 sae_require_mfp=1 sae_pwe=2 wpa_passphrase=19Triathlon#85unsernest wpa_psk_file=/var/run/hostapd-phy0-ap0.psk auth_algs=1 wpa=2 wpa_pairwise=CCMP ssid=unsernest bridge=br-lan wds_bridge= snoop_iface=br-lan wpa_disable_eapol_key_retries=0 wpa_key_mgmt=WPA-PSK WPA-PSK-SHA256 SAE okc=1 ieee80211w=1 group_mgmt_cipher=AES
Mon Nov 13 10:07:48 2023 daemon.err pppd[2676]: Unable to complete PPPoE Discovery
Mon Nov 13 10:07:48 2023 daemon.info pppd[2676]: Exit.
Mon Nov 13 10:07:48 2023 kern.info kernel: [ 18.001428] mt7530-mdio mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.338813] br-lan: port 6(phy0-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.344415] br-lan: port 6(phy0-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.350129] device phy0-ap0 entered promiscuous mode
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.355201] br-lan: port 6(phy0-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.360785] br-lan: port 6(phy0-ap0) entered forwarding state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.366592] br-wan: port 2(wan) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.371723] br-wan: port 2(wan) entered forwarding state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.377106] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Mon Nov 13 10:07:49 2023 daemon.notice hostapd: phy0-ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'wan' is now down
Mon Nov 13 10:07:49 2023 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Mon Nov 13 10:07:49 2023 daemon.notice hostapd: phy0-ap0: interface state COUNTRY_UPDATE->ACS
Mon Nov 13 10:07:49 2023 daemon.notice hostapd: phy0-ap0: ACS-STARTED
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.386072] device phy0-ap0 left promiscuous mode
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.390952] br-lan: port 6(phy0-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan' is now up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Wireless device 'radio1' is now up
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.454780] br-lan: port 6(phy1-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.460417] br-lan: port 6(phy1-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.466252] device phy1-ap0 entered promiscuous mode
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan (2592): Starting network qmi_wwan
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan (2592): Setting up wwan0
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Network device 'wan' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: bridge 'br-lan' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'lan' has link connectivity
Mon Nov 13 10:07:49 2023 daemon.notice netifd: bridge 'br-wan' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'wan' has link connectivity
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'wan' is setting up now
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'wan6' has link connectivity
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Network device 'wwan0' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Wireless device 'radio0' is now up
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.526255] br-lan: port 7(phy0-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.531890] br-lan: port 7(phy0-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.537648] device phy0-ap0 entered promiscuous mode
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.542813] br-lan: port 7(phy0-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 user.notice firewall: Reloading firewall due to ifup of qmi_wwan (wwan0)
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.548384] br-lan: port 7(phy0-ap0) entered forwarding state
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::aaaa#53
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::bbbb#53
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: Plugin pppoe.so loaded.
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: PPPoE plugin from pppd 2.4.9
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Network alias 'wwan0' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan_4' is enabled
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan_4' has link connectivity
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan_4' is setting up now
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 6 names
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c.2946 - 6 names
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 0 names
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: started, v1.36.1
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: broadcasting discover
Mon Nov 13 10:07:49 2023 daemon.notice pppd[3508]: pppd 2.4.9 started by root, uid 0
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: broadcasting select for 10.240.160.174, server 10.240.160.173
Mon Nov 13 10:07:49 2023 daemon.notice netifd: bridge 'br-lan' link is down
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'lan' has link connectivity loss
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.800176] br-lan: port 7(phy0-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: PPP session is 11
Mon Nov 13 10:07:49 2023 user.notice firewall: Reloading firewall due to ifupdate of qmi_wwan (wwan0)
Mon Nov 13 10:07:49 2023 daemon.warn pppd[3508]: Connected to f4:cc:55:8f:d6:e7 via interface br-wan
Mon Nov 13 10:07:49 2023 kern.info kernel: [ 18.900806] pppoe-wan: renamed from ppp0
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: lease of 10.240.160.174 obtained from 10.240.160.173, lease time 7200
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: Renamed interface ppp0 to pppoe-wan
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: Using interface pppoe-wan
Mon Nov 13 10:07:49 2023 daemon.notice pppd[3508]: Connect: pppoe-wan <--> br-wan
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan_4' is now up
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.17#53
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.18#53
Mon Nov 13 10:07:50 2023 user.notice firewall: Reloading firewall due to ifup of qmi_wwan_4 (wwan0)
Mon Nov 13 10:07:50 2023 kern.info kernel: [ 19.432716] mt7530-mdio mdio-bus:1f lan4: Link is Up - 1Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:50 2023 kern.info kernel: [ 19.440666] br-lan: port 4(lan4) entered blocking state
Mon Nov 13 10:07:50 2023 kern.info kernel: [ 19.445876] br-lan: port 4(lan4) entered forwarding state
Mon Nov 13 10:07:50 2023 daemon.notice netifd: Network device 'lan4' link is up
Mon Nov 13 10:07:50 2023 daemon.notice netifd: bridge 'br-lan' link is up
Mon Nov 13 10:07:50 2023 daemon.notice netifd: Interface 'lan' has link connectivity
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: DNS service limited to local subnets
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::aaaa#53
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::bbbb#53
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.17#53
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.18#53
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 0 names
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:07:51 2023 authpriv.info dropbear[2944]: Early exit: Terminated by signal
Mon Nov 13 10:07:51 2023 authpriv.info dropbear[3843]: Not backgrounding
Mon Nov 13 10:07:51 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:07:51 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:07:51 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 0 names
Mon Nov 13 10:07:51 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:35:32 2023 daemon.info pppd[3508]: Remote message: Accepted.
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: PAP authentication succeeded
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: peer from calling number F4:CC:55:8F:D6:E7 authorized
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: local LL address fe80::d816:ec54:508e:6fe0
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: remote LL address fe80::da49:0bff:feb7:37b5
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: local IP address 77.185.111.30
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: remote IP address 62.52.200.219
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: primary DNS address 62.109.121.1
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: secondary DNS address 62.109.121.2
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Network device 'pppoe-wan' link is up
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Interface 'wan' is now up
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::aaaa#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::bbbb#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.17#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.18#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.1#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.2#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Network alias 'pppoe-wan' link is up
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Interface 'wan_6' is enabled
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Interface 'wan_6' has link connectivity
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Interface 'wan_6' is setting up now
Mon Nov 13 10:35:32 2023 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Mon Nov 13 10:35:32 2023 user.notice firewall: Reloading firewall due to ifupdate of wan (pppoe-wan)
Mon Nov 13 10:35:32 2023 user.notice ddns-scripts[4234]: myddns_ipv4: PID '4234' started at 2023-11-13 10:35
Mon Nov 13 10:35:32 2023 user.warn ddns-scripts[4234]: myddns_ipv4: Service section disabled! - TERMINATE
Mon Nov 13 10:35:32 2023 user.warn ddns-scripts[4234]: myddns_ipv4: PID '4234' exit WITH ERROR '1' at 2023-11-13 10:35
Mon Nov 13 10:35:33 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:35:33 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:35:33 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 4 names
Mon Nov 13 10:35:33 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:35:36 2023 daemon.notice netifd: Interface 'wan_6' is now up
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::aaaa#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::bbbb#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.17#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.18#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.1#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.2#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 2a01:c30::530#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 2a01:c30::531#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 6 names
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:35:36 2023 user.notice firewall: Reloading firewall due to ifup of wan_6 (pppoe-wan)
Mon Nov 13 10:35:39 2023 daemon.notice hostapd: ACS: Survey for freq 2412 is missing noise floor
Mon Nov 13 10:35:39 2023 daemon.notice hostapd: phy0-ap0: ACS-COMPLETED freq=2412 channel=1
Mon Nov 13 10:35:39 2023 daemon.notice hostapd: phy0-ap0: interface state ACS->HT_SCAN
Mon Nov 13 10:35:41 2023 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=1 sec=5 based on overlapping BSSes
Mon Nov 13 10:35:41 2023 daemon.notice hostapd: Fallback to 20 MHz
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.605414] IPv6: ADDRCONF(NETDEV_CHANGE): phy0-ap0: link becomes ready
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.612161] br-lan: port 7(phy0-ap0) entered blocking state
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.617723] br-lan: port 7(phy0-ap0) entered forwarding state
Mon Nov 13 10:35:41 2023 daemon.notice netifd: Network device 'phy0-ap0' link is up
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.751654] br-lan: port 8(phy0-ap1) entered blocking state
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.757238] br-lan: port 8(phy0-ap1) entered disabled state
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.763068] device phy0-ap1 entered promiscuous mode
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.769079] br-lan: port 8(phy0-ap1) entered blocking state
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.774665] br-lan: port 8(phy0-ap1) entered forwarding state
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.780807] device phy0-ap1 left promiscuous mode
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.785556] br-lan: port 8(phy0-ap1) entered disabled state
Mon Nov 13 10:35:41 2023 kern.info kernel: [ 31.858584] IPv6: ADDRCONF(NETDEV_CHANGE): phy0-ap1: link becomes ready
Mon Nov 13 10:35:42 2023 daemon.notice hostapd: phy0-ap0: interface state HT_SCAN->ENABLED
Mon Nov 13 10:35:42 2023 daemon.notice hostapd: phy0-ap0: AP-ENABLED
Mon Nov 13 10:35:44 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.1.123 e4:5f:01:66:6a:d9
Mon Nov 13 10:35:44 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.123 e4:5f:01:66:6a:d9
Mon Nov 13 10:35:44 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.123 e4:5f:01:66:6a:d9
Mon Nov 13 10:35:44 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.123 e4:5f:01:66:6a:d9 nest-assistent
Mon Nov 13 10:35:46 2023 daemon.info hostapd: phy0-ap0: STA 48:55:19:15:0f:bb IEEE 802.11: authenticated
Mon Nov 13 10:35:46 2023 daemon.info hostapd: phy0-ap0: STA 48:55:19:15:0f:bb IEEE 802.11: associated (aid 1)
Mon Nov 13 10:35:46 2023 daemon.notice hostapd: phy0-ap0: AP-STA-CONNECTED 48:55:19:15:0f:bb auth_alg=open
Mon Nov 13 10:35:46 2023 daemon.info hostapd: phy0-ap0: STA 48:55:19:15:0f:bb WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:35:46 2023 daemon.notice hostapd: phy0-ap0: EAPOL-4WAY-HS-COMPLETED 48:55:19:15:0f:bb
Mon Nov 13 10:35:47 2023 daemon.info hostapd: phy0-ap0: STA 70:91:8f:28:7e:d6 IEEE 802.11: authenticated
Mon Nov 13 10:35:48 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 48:55:19:15:0f:bb
Mon Nov 13 10:35:48 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.131 48:55:19:15:0f:bb
Mon Nov 13 10:35:48 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.131 48:55:19:15:0f:bb
Mon Nov 13 10:35:48 2023 daemon.warn dnsmasq-dhcp[1]: Ignoring domain mikeg.de for DHCP host name nest-therm
Mon Nov 13 10:35:48 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.131 48:55:19:15:0f:bb nest-therm
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: phy1-ap0: ACS-COMPLETED freq=5520 channel=104
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: phy1-ap0: interface state ACS->HT_SCAN
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: Switch own primary and secondary channel to get secondary channel with no Beacons from other BSSes
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: phy1-ap0: interface state HT_SCAN->DFS
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: phy1-ap0: DFS-CAC-START freq=5500 chan=100 sec_chan=1, width=2, seg0=114, seg1=0, cac_time=60s
Mon Nov 13 10:35:51 2023 daemon.info hostapd: phy0-ap0: STA 70:91:8f:28:7e:d6 IEEE 802.11: associated (aid 2)
Mon Nov 13 10:35:51 2023 daemon.notice hostapd: phy0-ap0: AP-STA-CONNECTED 70:91:8f:28:7e:d6 auth_alg=sae
Mon Nov 13 10:35:51 2023 daemon.info hostapd: phy0-ap0: STA 70:91:8f:28:7e:d6 WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:35:51 2023 daemon.notice hostapd: phy0-ap0: EAPOL-4WAY-HS-COMPLETED 70:91:8f:28:7e:d6
Mon Nov 13 10:35:55 2023 daemon.err collectd[2221]: Sleeping only 2s because the next interval is 1629.102 seconds in the past!
Mon Nov 13 10:35:56 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 70:91:8f:28:7e:d6
Mon Nov 13 10:35:56 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.118 70:91:8f:28:7e:d6
Mon Nov 13 10:35:56 2023 daemon.err collectd[2221]: rrdtool plugin: rrd_update_r failed: /tmp/rrd/NestRouter/cpu-1/percent-interrupt.rrd: opening '/tmp/rrd/NestRouter/cpu-1/percent-interrupt.rrd': No such file or directory
Mon Nov 13 10:35:56 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.118 70:91:8f:28:7e:d6
Mon Nov 13 10:35:56 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.118 70:91:8f:28:7e:d6
Mon Nov 13 10:36:43 2023 daemon.info hostapd: phy0-ap0: STA 84:78:8b:7b:be:6f IEEE 802.11: authenticated
Mon Nov 13 10:36:43 2023 daemon.info hostapd: phy0-ap0: STA 84:78:8b:7b:be:6f IEEE 802.11: associated (aid 3)
Mon Nov 13 10:36:43 2023 daemon.notice hostapd: phy0-ap0: AP-STA-CONNECTED 84:78:8b:7b:be:6f auth_alg=open
Mon Nov 13 10:36:43 2023 daemon.info hostapd: phy0-ap0: STA 84:78:8b:7b:be:6f WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:36:43 2023 daemon.notice hostapd: phy0-ap0: EAPOL-4WAY-HS-COMPLETED 84:78:8b:7b:be:6f
Mon Nov 13 10:36:43 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.141 84:78:8b:7b:be:6f
Mon Nov 13 10:36:43 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.141 84:78:8b:7b:be:6f iPad-von-Mina
Mon Nov 13 10:36:50 2023 daemon.notice hostapd: phy1-ap0: DFS-CAC-COMPLETED success=1 freq=5500 ht_enabled=0 chan_offset=0 chan_width=5 cf1=5570 cf2=0
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.018073] IPv6: ADDRCONF(NETDEV_CHANGE): phy1-ap0: link becomes ready
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.024824] br-lan: port 6(phy1-ap0) entered blocking state
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.030395] br-lan: port 6(phy1-ap0) entered forwarding state
Mon Nov 13 10:36:51 2023 daemon.notice netifd: Network device 'phy1-ap0' link is up
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.141614] br-lan: port 8(phy1-ap1) entered blocking state
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.147200] br-lan: port 8(phy1-ap1) entered disabled state
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.153069] device phy1-ap1 entered promiscuous mode
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.160126] br-lan: port 8(phy1-ap1) entered blocking state
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.165694] br-lan: port 8(phy1-ap1) entered forwarding state
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.171855] device phy1-ap1 left promiscuous mode
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.176607] br-lan: port 8(phy1-ap1) entered disabled state
Mon Nov 13 10:36:51 2023 kern.info kernel: [ 101.246383] IPv6: ADDRCONF(NETDEV_CHANGE): phy1-ap1: link becomes ready
Mon Nov 13 10:36:51 2023 daemon.notice hostapd: phy1-ap0: interface state DFS->ENABLED
Mon Nov 13 10:36:51 2023 daemon.notice hostapd: phy1-ap0: AP-ENABLED
Mon Nov 13 10:37:15 2023 daemon.info hostapd: phy1-ap0: STA 60:e9:aa:5d:c9:2d IEEE 802.11: associated (aid 1)
Mon Nov 13 10:37:15 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED 60:e9:aa:5d:c9:2d auth_alg=sae
Mon Nov 13 10:37:15 2023 daemon.info hostapd: phy1-ap0: STA 60:e9:aa:5d:c9:2d WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:37:15 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED 60:e9:aa:5d:c9:2d
Mon Nov 13 10:37:16 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:37:16 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:37:16 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 12 names
Mon Nov 13 10:37:16 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:37:18 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.206 60:e9:aa:5d:c9:2d
Mon Nov 13 10:37:18 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.206 60:e9:aa:5d:c9:2d Dose
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA e4:5f:01:66:6a:da IEEE 802.11: authenticated
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA e4:5f:01:66:6a:da IEEE 802.11: associated (aid 2)
Mon Nov 13 10:37:33 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED e4:5f:01:66:6a:da auth_alg=open
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA e4:5f:01:66:6a:da WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:37:33 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED e4:5f:01:66:6a:da
Mon Nov 13 10:37:33 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.124 e4:5f:01:66:6a:da
Mon Nov 13 10:37:33 2023 daemon.warn dnsmasq-dhcp[1]: Ignoring domain mikeg.de for DHCP host name nest-assistent
Mon Nov 13 10:37:33 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.124 e4:5f:01:66:6a:da nest-assistent
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA 72:85:aa:b1:62:01 IEEE 802.11: associated (aid 3)
Mon Nov 13 10:37:33 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED 72:85:aa:b1:62:01 auth_alg=sae
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA 72:85:aa:b1:62:01 WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:37:33 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED 72:85:aa:b1:62:01
Mon Nov 13 10:37:33 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.243 72:85:aa:b1:62:01
Mon Nov 13 10:37:33 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.243 72:85:aa:b1:62:01
Mon Nov 13 10:37:35 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:37:35 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:37:35 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 18 names
Mon Nov 13 10:37:35 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:37:52 2023 daemon.err uhttpd[2100]: [info] luci: accepted login on / for root from 192.168.1.206
Mon Nov 13 10:40:23 2023 daemon.warn dnsmasq[1]: possible DNS-rebind attack detected: dns.msftncsi.com
Mon Nov 13 11:02:55 2023 daemon.notice hostapd: phy1-ap0: AP-STA-POLL-OK e4:5f:01:66:6a:da
Mon Nov 13 11:14:59 2023 daemon.notice hostapd: phy1-ap0: AP-STA-POLL-OK e4:5f:01:66:6a:da
Mon Nov 13 11:18:43 2023 daemon.info hostapd: phy1-ap1: STA f4:7b:09:d3:1b:f2 IEEE 802.11: associated (aid 1)
Mon Nov 13 11:18:44 2023 daemon.notice hostapd: phy1-ap1: AP-STA-CONNECTED f4:7b:09:d3:1b:f2 auth_alg=sae
Mon Nov 13 11:18:44 2023 daemon.info hostapd: phy1-ap1: STA f4:7b:09:d3:1b:f2 WPA: pairwise key handshake completed (RSN)
Mon Nov 13 11:18:44 2023 daemon.notice hostapd: phy1-ap1: EAPOL-4WAY-HS-COMPLETED f4:7b:09:d3:1b:f2
Mon Nov 13 11:25:24 2023 daemon.notice hostapd: phy1-ap0: AP-STA-POLL-OK e4:5f:01:66:6a:da
Mon Nov 13 11:35:29 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: sending renew to server 10.240.160.173
Mon Nov 13 11:35:29 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: lease of 10.240.160.174 obtained from 10.240.160.173, lease time 7200
Mon Nov 13 11:58:45 2023 kern.info kernel: [ 5010.206970] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
Mon Nov 13 11:58:45 2023 kern.info kernel: [ 5010.214907] br-lan: port 1(lan1) entered blocking state
Mon Nov 13 11:58:45 2023 kern.info kernel: [ 5010.220129] br-lan: port 1(lan1) entered forwarding state
Mon Nov 13 11:58:45 2023 daemon.notice netifd: Network device 'lan1' link is up
Mon Nov 13 11:58:47 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.164 04:7c:16:bf:96:df
Mon Nov 13 11:58:47 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.164 04:7c:16:bf:96:df Dose
Mon Nov 13 11:58:48 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 11:58:48 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 11:58:48 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 24 names
Mon Nov 13 11:58:48 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 11:59:16 2023 daemon.notice hostapd: phy1-ap0: AP-STA-DISCONNECTED 60:e9:aa:5d:c9:2d
Mon Nov 13 11:59:16 2023 daemon.info hostapd: phy1-ap0: STA 60:e9:aa:5d:c9:2d IEEE 802.11: disassociated
Mon Nov 13 11:59:17 2023 daemon.info hostapd: phy1-ap0: STA 60:e9:aa:5d:c9:2d IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon Nov 13 12:12:23 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e IEEE 802.11: authenticated
Mon Nov 13 12:12:23 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e IEEE 802.11: associated (aid 2)
Mon Nov 13 12:12:23 2023 daemon.notice hostapd: phy1-ap1: AP-STA-CONNECTED b4:0e:de:2b:de:1e auth_alg=open
Mon Nov 13 12:12:23 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e WPA: pairwise key handshake completed (RSN)
Mon Nov 13 12:12:23 2023 daemon.notice hostapd: phy1-ap1: EAPOL-4WAY-HS-COMPLETED b4:0e:de:2b:de:1e
Mon Nov 13 12:12:31 2023 daemon.notice hostapd: phy1-ap1: AP-STA-DISCONNECTED b4:0e:de:2b:de:1e
Mon Nov 13 12:17:28 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e IEEE 802.11: authenticated
Mon Nov 13 12:17:28 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e IEEE 802.11: associated (aid 2)
Mon Nov 13 12:17:28 2023 daemon.notice hostapd: phy1-ap1: AP-STA-CONNECTED b4:0e:de:2b:de:1e auth_alg=open
Mon Nov 13 12:17:28 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e WPA: pairwise key handshake completed (RSN)
Mon Nov 13 12:17:28 2023 daemon.notice hostapd: phy1-ap1: EAPOL-4WAY-HS-COMPLETED b4:0e:de:2b:de:1e
Mon Nov 13 12:17:40 2023 daemon.notice hostapd: phy1-ap1: AP-STA-DISCONNECTED b4:0e:de:2b:de:1e
Mon Nov 13 12:19:00 2023 daemon.err uhttpd[2100]: [info] luci: accepted login on /admin/status/logs for root from 192.168.1.164
