[BPI-R3]: BPI-4G LTE Module SIM
I am trying to get the Quectel EC25-E 4G modem to run on my BPI-R3.
Trying both of the following documentations resulted in a similar issue “sim_not_present”
I installed
opkg install kmod-usb-net-qmi-wwan uqmi luci-proto-qmi kmod-usb-serial-qualcomm
Rebooted and the device appears. I can configure the interface using the O2 settings
Here is the syslog if that helps.
Tue Oct 24 22:32:24 2023 daemon.notice netifd: Interface 'qmi_wwan' is setting up now
Tue Oct 24 15:57:39 2023 kern.info kernel: [   13.686259] PPP generic driver version 2.4.2
Tue Oct 24 15:57:39 2023 kern.info kernel: [   13.691208] NET: Registered PF_PPPOX protocol family
Tue Oct 24 15:57:39 2023 kern.err kernel: [   13.697076] xhci-mtk 11200000.usb: drop_ep_quirk high-speed ep9in intr, mpkt:8, interval:9/32ms
Tue Oct 24 15:57:39 2023 kern.info kernel: [   13.706762] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Tue Oct 24 15:57:39 2023 kern.info kernel: [   13.713215] qmi_wwan 1-1.1:1.4 wwan0: register 'qmi_wwan' at usb-11200000.usb-1.1, WWAN/QMI device, 0a:34:33:b0:22:a7
Tue Oct 24 15:57:39 2023 kern.info kernel: [   13.723977] usbcore: registered new interface driver qmi_wwan
Tue Oct 24 22:32:24 2023 daemon.notice netifd: qmi_wwan (5006): Waiting for SIM initialization
Tue Oct 24 22:32:24 2023 daemon.notice netifd: qmi_wwan (5006): Failed to parse message data
Tue Oct 24 22:32:24 2023 daemon.notice netifd: qmi_wwan (5006): PIN status failed (sim_not_present)
Tue Oct 24 22:32:24 2023 daemon.notice netifd: qmi_wwan (5035): Stopping network qmi_wwan
Tue Oct 24 22:32:24 2023 daemon.notice netifd: qmi_wwan (5035): Command failed: ubus call network.interface notify_proto { "action": 0, "link-up": false, "keep": false, "interface": "qmi_wwan" } (Permission denied)
Tue Oct 24 22:32:24 2023 daemon.notice netifd: Interface 'qmi_wwan' is now down
Using the modem manager as mentioned before did not work either and yielded the same issues which I try to rectify in:
Does anyone have a suggestion or idea?
Thanks in advance Mike
Does your card has a sim-slot or do you use the one from r3?
R3 Shematic says that pins 8,10,12,14 of mpci slot are connected to r3 sim slot.
Have not found schematic of this card but pictures show that it can hold a sim-slot on bottom so maybe some cards exist with soldered sim-interface.
I am using the slot from the BPI-R3. The extension card delivered with the modem cannot be plugged in anywhere except via USB. having that dangling outside w/o an enclosure doesn’t meet my eye :wink:
But I will unmount it just to be certain if there isn’t a SIM slot hidden beneath. Thanks for the tip!
Oh,you do not use the mpcie slot and connected usb “over the air”? How does this look like?
Then you miss the sim pins of the mpcie slot…sorry for not mention this before (it is not only usb).
There is an old image, still with the “abusive” antenna wiring, in this post of mine:
I have the 4G module plugged into the mPCIe so very much as expected. I guess I expressed myself inaccurately causing some confusion.
Ok,if your card is in the mPCIe slot then you can look into your cards shematics if the pins for sim-slot are exposed on the mPCIe connector on same position (i guess if exposed then pins match). Maybe there is a switch or soldering point to choose between pins or the on-card sim slot if there is one.
Else make sure the sim is correctly inserted.
Hi @dangowrt,
apologize to drag you into this topic but I found your comment from another post quite interesting:
Do you have a suggestion how I might proceed getting the original BPI bpi 4g module to work on the BPI-R3?
PS: I believe the SIM got blocked unintentionally and the error that it was not found is misleading as I can get the SIM IDs via:
qmicli --device=/dev/cdc-wdm0 -p --dms-get-ids
[/dev/cdc-wdm0] Device IDs retrieved:
            ESN: 'NUMBER'
           IMEI: 'NUMBER'
           MEID: 'NUMBER'
        IMEI SV: '6'
Update: Digging into QMI-cli
qmicli --device=/dev/cdc-wdm0 -p --uim-get-card-status
[/dev/cdc-wdm0] Successfully got card status
Provisioning applications:
        Primary GW:   session doesn't exist
        Primary 1X:   session doesn't exist
        Secondary GW: session doesn't exist
        Secondary 1X: session doesn't exist
Slot [1]:
        Card state: 'error: no-atr-received (3)'
        UPIN state: 'not-initialized'
                UPIN retries: '0'
                UPUK retries: '0'
followed by some googleing I found:
Though, here my Latin ends as I have no oscilloscope nor any other means to proceed. And even if, I start to believe (I sincerely hope it isn’t), this is a hardware issue.
Many thanks in advance Mike
If you see the card/phone number then access to sim works.
I wrote some steps when playing with my modem in debian (not really good structured i know…more notes than tutorial), but maybe this helps a bit
https://wiki.fw-web.de/doku.php?id=en:bpi-r3:lte
In my case i had only mbim mode working as i could not change the FCC authentication in qmi mode
Afair the bpi modem is not compatible to (all) european frequencies.
Yep, have checked your doku today after which I was inclined to “drag in” Daniel since his post was my “final destination”. If that modem indeed in incompatible with EU frequencies, I’d have to have a conversation with the seller on Amazon but I think it’s totally fine because the necessary bands are supported:
qmicli --device=/dev/cdc-wdm0 -p --dms-get-band-capabilities
[/dev/cdc-wdm0] Device band capabilities retrieved:
        Bands: 'gsm-dcs-1800, gsm-900-extended, gsm-900-primary, wcdma-2100, wcdma-850-us, wcdma-900'
        LTE bands: '1, 3, 5, 7, 8, 20, 38, 40, 41'
Checking the validity of the PIN makes me think the SIM in blocked.
qmicli --device=/dev/cdc-wdm0 -p --uim-verify-pin=PIN1,####
error: couldn't verify PIN: QMI protocol error (3): 'Internal'
[/dev/cdc-wdm0] Retries left:
        Verify: 0
        Unblock: 0
Attempting to unblock it throws an error I find no explanation for:
qmicli --device=/dev/cdc-wdm0 -p --uim-unblock-pin=PIN1,########,####
error: couldn't unblock PIN: QMI protocol error (3): 'Internal'
        Verify: 0
        Unblock: 0
The modem also seems to have established a GSM connection
uqmi -d /dev/cdc-wdm0 --get-signal-info
        "type": "gsm",
        "signal": -65
Inserting the SIM into my mobile it unlocks at first attempt. Quite a riddle, isn’t it …
Edit: Some more details. Maybe anyone spots something.
 qmicli -p -d /dev/cdc-wdm0 -v --dms-get-manufacturer
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] opening device with flags 'proxy                     , auto'...
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] automatically selecting QMI mode
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] created endpoint
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<<   length = 28
<<<<<<   data   = 01:1B:00:00:00:00:00:01:00:FF:10:00...
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] sent generic request (translated                     )...
<<<<<< QMUX:
<<<<<<   length  = 27
<<<<<<   flags   = 0x00
<<<<<<   service = "ctl"
<<<<<<   client  = 0
<<<<<< QMI:
<<<<<<   flags       = "none"
<<<<<<   transaction = 1
<<<<<<   tlv_length  = 16
<<<<<<   message     = "Internal Proxy Open" (0xFF00)
<<<<<< TLV:
<<<<<<   type       = "Device Path" (0x01)
<<<<<<   length     = 13
<<<<<<   value      = 2F:64:65:76:2F:63:64:63:2D:77:64:6D:30
<<<<<<   translated = /dev/cdc-wdm0
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<<   length = 19
<<<<<<   data   = 01:12:00:80:00:00:01:01:00:FF:07:00...
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] received generic response (trans                     lated)...
<<<<<< QMUX:
<<<<<<   length  = 18
<<<<<<   flags   = 0x80
<<<<<<   client  = 0
<<<<<< QMI:
<<<<<<   flags       = "response"
<<<<<<   tlv_length  = 7
<<<<<< TLV:
<<<<<<   type       = "Result" (0x02)
<<<<<<   length     = 4
<<<<<<   value      = 00:00:00:00
<<<<<<   translated = SUCCESS
[25 Oct 2023, 20:38:00] [Debug] QMI Device at '/dev/cdc-wdm0' ready
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] assuming service 'dms' is suppor                     ted...
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] allocating new client ID...
<<<<<< RAW:
<<<<<<   length = 16
<<<<<<   data   = 01:0F:00:00:00:00:00:02:22:00:04:00...
<<<<<< QMUX:
<<<<<<   length  = 15
<<<<<<   flags   = 0x00
<<<<<<   client  = 0
<<<<<< QMI:
<<<<<<   transaction = 2
<<<<<<   tlv_length  = 4
<<<<<<   message     = "Allocate CID" (0x0022)
<<<<<< TLV:
<<<<<<   type       = "Service" (0x01)
<<<<<<   length     = 1
<<<<<<   value      = 02
<<<<<<   translated = dms
<<<<<< RAW:
<<<<<<   length = 24
<<<<<<   data   = 01:17:00:80:00:00:01:02:22:00:0C:00...
<<<<<< QMUX:
<<<<<<   length  = 23
<<<<<<   flags   = 0x80
<<<<<<   client  = 0
<<<<<< QMI:
<<<<<<   tlv_length  = 12
<<<<<< TLV:
<<<<<<   length     = 4
<<<<<< TLV:
<<<<<<   type       = "Allocation Info" (0x01)
<<<<<<   length     = 2
<<<<<<   value      = 02:01
<<<<<<   translated = [ service = 'dms' cid = '1' ]
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] registered 'dms' (version unknow                     n) client with ID '1'
[25 Oct 2023, 20:38:00] [Debug] Asynchronously getting manufacturer...
<<<<<< RAW:
<<<<<<   length = 13
<<<<<<   data   = 01:0C:00:00:02:01:00:01:00:21:00:00...
<<<<<< QMUX:
<<<<<<   length  = 12
<<<<<<   flags   = 0x00
<<<<<<   service = "dms"
<<<<<<   client  = 1
<<<<<< QMI:
<<<<<<   tlv_length  = 0
<<<<<<   message     = "Get Manufacturer" (0x0021)
<<<<<< RAW:
<<<<<<   length = 44
<<<<<<   data   = 01:2B:00:80:02:01:02:01:00:21:00:1F...
<<<<<< QMUX:
<<<<<<   length  = 43
<<<<<<   flags   = 0x80
<<<<<<   client  = 1
<<<<<< QMI:
<<<<<<   tlv_length  = 31
<<<<<< TLV:
<<<<<<   length     = 4
<<<<<< TLV:
<<<<<<   type       = "Manufacturer" (0x01)
<<<<<<   length     = 21
<<<<<<   value      = 51:55:41:4C:43:4F:4D:4D:20:49:4E:43:4F:52:50:4F:52:41:54:4                     5:44
<<<<<<   translated = QUALCOMM INCORPORATED
[/dev/cdc-wdm0] Device manufacturer retrieved:
        Manufacturer: 'QUALCOMM INCORPORATED'
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] releasing 'dms' client with flag                     s 'release-cid'...
[25 Oct 2023, 20:38:00] [Debug] [/dev/cdc-wdm0] unregistered 'dms' client with I                     D '1'
<<<<<< RAW:
<<<<<<   length = 17
<<<<<<   data   = 01:10:00:00:00:00:00:03:23:00:05:00...
<<<<<< QMUX:
<<<<<<   length  = 16
<<<<<<   flags   = 0x00
<<<<<<   client  = 0
<<<<<< QMI:
<<<<<<   transaction = 3
<<<<<<   tlv_length  = 5
<<<<<<   message     = "Release CID" (0x0023)
<<<<<< TLV:
<<<<<<   type       = "Release Info" (0x01)
<<<<<<   length     = 2
<<<<<< RAW:
<<<<<<   length = 24
<<<<<<   data   = 01:17:00:80:00:00:01:03:23:00:0C:00...
<<<<<< QMUX:
<<<<<<   length  = 23
<<<<<<   flags   = 0x80
<<<<<<   client  = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<<   length     = 4
<<<<<< TLV:
<<<<<<   length     = 2
[25 Oct 2023, 20:38:00] [Debug] Client released
[25 Oct 2023, 20:38:00] [Debug] Closed
Thanks Mikew for opening this topic, and thanks frank-w for support!
It looks for my, that i have the same problem like mikew. → I also came to the conclusion, that the problem is located between SIM-card and modem.
My setup is the Quectel EC25-EUX modem, direct connected with mini PCI-E slot. And I’m using the SIM-slot of BPI-R3. I have two nano-SIM Cards (Vodafone and O2). Because of nano-SIM, I use a SIM-Card holder:
I’m working the last four days on this topic. But I’m still new at openwrt!
Because of the question, “Matches the pinning of the EC25 with BPI-R3”? It shoudl:
The Pin 44 worked too (for Card detection hot-plug)! (It has to be activeted, but is no “game changer”)
My first trys starts after installing the packages of QMI, MBIM and modem manager from the nown help sites. I used them in LUCI:
→ All of this programms telling me, in its unique way, that i have a problem with the Sim detection. I tried both cards with activated and deactivetad SIM-Pins. Also “0000”. It did not work!
After that i read much about this kind of problems. First of all is the Modem installed (dmesg)? Should be: grafik
Than i worked with shell commands to get my information like mikew and get same results
→ mmcli -m 0
It is not difficult to understand! Everthing okay (?), but SIM is missing.
!!! During this four days (sim in, sim out …), i get randomly two or three times a “present” SIM CARD !!! (not reproducible)
In this context, can someone tell me what “Application [1] and [2]” is???
After that i work deeper and use AT Commands. After I find out how to do that (I use picocom with putty W-Lan connection and fist AT and than AT+ATE1 “to see” my inputs) i tryed some thinks out.
For example:
→ turn on “LTE ony” connection (worked)
→ I changed the Voltage from 1.8 to 3 and auto mode (no effect)
→ turn on SIM detection (working), sim precence is not detected after “put in” but it is detected, that there is no SIM after pull out (some things are working)
→ reboot modem (no effect)
→ List of currently available networks (worked)
grafik
→ Everything what i’m doing shows me, that I have a good connection to the modem. And the modem worked.
→ The only comments which are not working are the USIM comments!
Mikew shared a link of Questel-forum with shows the same problems of other users. Im not sure what can it be.
→ Is the signal relly polluted with noise? (Questel Modem Problem)
→ Incompatibelity (wrong capacitors)
→ Simcard holder problem.
→ software problem? Something switched after boot?
Because I do not know, I’m not sure what my next steps:
→ soldering sim card holder on the backside of EC25
grafik
→ buying an Quectel Modem with simcard holder on the backside:
→ Adapter Card:
→ buying a new modem from other producer? Sierra Wireless AirPrime MC7455 → good modem?
@Lorem_amicus thanks for your reply and quite interesting that occasionally you got the SIM detected. Did you check dmesg around when you got the positive SIM recognition?
It also seems you are suing modemmanager. I guess it comes with it’s own bundled driver which might explain the behavior. OpenWrt “interviews” the device, gets some basic drivers, then maybe other drivers intervene. Just guess work, though.
Maybe one rather important aspect to add. I have read that the SIM is only checked for / detected upon boot but not after OpenWRT started already. I could not verify this due to the apparent reasons. As you, I am stuck with AT commands as well.
No, I do not check dmesg.
I delated the LUCI interfaces after my fist try’s.
And after working into AT commads I used: AT+CIMI for checking SIM card.
Something nice I found today: gcom -d /dev/cdc-wdm0
For my unterstanding the SIM card should recognized by the Modem. I buyed the modem last year because of chat recommendation, and its also on the Wiki side:
grafik
I will go forward …
I was looking for new 4G modems. I found this interesting ones:
→ Sierra Air Prime MC7455 → SIMCOM SIM7600G-H-PCIE
After comparing the pinning of these two Modems, it becomes more clear, that the BPI-R3 PCB design looks made for Quectels EC25. The most Pin’s (MC 7455 and SIM7600) matching, but for example the 44 which is for USIM_Presense did not match (i think its not nessesary to work). But I’m also not sure about other Pins.
The interesting part of my journey were the technical advices of the Sierra Air Prime MC7455:
It is just a speculation (becase I have no measurements) but after reading this text, it becomes more clear how difficult it can be to invent a working design.
On the SIMCOM SIM7600G-H-PCIE Datasheet i found this:
grafik
Today I sold this Adapter:
There is a more advanced one (?) on Aliexpress:
This Adapter will arrive me within the next week. I will check …
Got an update. Magically, after updating some packages today (might be unrelated!) and restarting the 4G modem started to work as expected. No, at least intentional, change to the configuration … as follows my log in case anyone spots the difference compared to previously shared logs.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    0.000000] Linux version 5.15.134 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.3.0 r23497-6637af95aa) 12.3.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Mon Oct 9 21:45:35 2023
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Machine model: Bananapi BPI-R3
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Zone ranges:
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000]   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000]   DMA32    empty
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000]   Normal   empty
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Movable zone start for each node
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Early memory node ranges
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000043000000-0x000000004302ffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000043030000-0x000000004fbfffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x000000004fc00000-0x000000004ffbffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x000000004ffc0000-0x00000000bfffffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] psci: probing for conduit method from DT.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] psci: PSCIv1.1 detected in firmware.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] psci: Using standard PSCI v0.2 function IDs
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] psci: SMC Calling Convention v1.4
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] percpu: Embedded 17 pages/cpu s30040 r8192 d31400 u69632
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    0.000000] pcpu-alloc: s30040 r8192 d31400 u69632 alloc=17*4096
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Detected VIPT I-cache on CPU0
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] CPU features: detected: GIC system register CPU interface
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    0.000000] Kernel command line: root=/dev/mmcblk0p65
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Memory: 2040968K/2097152K available (8384K kernel code, 912K rwdata, 1472K rodata, 448K init, 303K bss, 56184K reserved, 0K cma-reserved)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] rcu: Hierarchical RCU implementation.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] GICv3: 640 SPIs implemented
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] GICv3: 0 Extended SPIs implemented
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] GICv3: Distributor has no Range Selector support
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] Root IRQ handler: 0xffffffc008421f74
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] GICv3: 16 PPIs implemented
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] arch_timer: cp15 timer(s) running at 13.00MHz (phys).
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000123] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000131] pid_max: default: 32768 minimum: 301
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000338] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.000350] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.001378] rcu: Hierarchical SRCU implementation.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.001670] smp: Bringing up secondary CPUs ...
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.001928] Detected VIPT I-cache on CPU1
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.001950] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.001975] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002238] Detected VIPT I-cache on CPU2
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002250] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002261] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002496] Detected VIPT I-cache on CPU3
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002506] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002514] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002540] smp: Brought up 1 node, 4 CPUs
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002553] SMP: Total of 4 processors activated.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002556] CPU features: detected: 32-bit EL0 Support
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002559] CPU features: detected: CRC32 instructions
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002582] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002635] CPU: All CPU(s) started at EL2
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.002645] alternatives: patching kernel code
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.005536] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.005559] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.005703] pinctrl core: initialized pinctrl subsystem
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.006329] NET: Registered PF_NETLINK/PF_ROUTE protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.006576] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.006606] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.006631] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.006877] thermal_sys: Registered thermal governor 'fair_share'
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.006880] thermal_sys: Registered thermal governor 'bang_bang'
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.006883] thermal_sys: Registered thermal governor 'step_wise'
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.006886] thermal_sys: Registered thermal governor 'user_space'
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.007080] ASID allocator initialised with 65536 entries
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.007399] pstore: Registered ramoops as persistent store backend
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.007402] ramoops: using 0x10000@0x42ff0000, ecc: 0
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.017106] cryptd: max_cpu_qlen set to 1000
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.018699] 1.8vd: supplied by 12vd
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.018862] 3.3vd: supplied by 12vd
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    0.019112] SCSI subsystem initialized
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    0.019198] libata version 3.00 loaded.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.020080] clocksource: Switched to clocksource arch_sys_counter
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.020532] NET: Registered PF_INET protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.020637] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021304] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021323] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021331] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021398] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021571] TCP: Hash tables configured (established 16384 bind 16384)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021645] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021673] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021800] NET: Registered PF_UNIX/PF_LOCAL protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.021820] PCI: CLS 0 bytes, default 64
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.023880] workingset: timestamp_bits=46 max_order=19 bucket_order=0
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.026522] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.026534] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.048494] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Mon Nov 13 10:07:44 2023 kern.err kernel: [    0.049560] pwm-mediatek 10048000.pwm: clock: top fail: -517
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.049827] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    0.049844] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.049852] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
Mon Nov 13 10:07:44 2023 kern.err kernel: [    0.049923] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
Mon Nov 13 10:07:44 2023 kern.err kernel: [    0.049931] mtk-pcie-gen3 11280000.pcie: failed to get clocks
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.052735] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.054089] printk: console [ttyS0] disabled
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.074235] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.761823] printk: console [ttyS0] enabled
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.786594] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.816318] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 124, base_baud = 1625000) is a ST16650V2
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.826148] mtk_rng 1020f000.rng: registered RNG driver
Mon Nov 13 10:07:44 2023 kern.warn kernel: [    0.826207] hwrng: no data available
Mon Nov 13 10:07:44 2023 kern.warn kernel: [    0.831645] cacheinfo: Unable to detect cache hierarchy for CPU 0
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.843105] loop: module loaded
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.846254] Loading iSCSI transport class v2.0-870.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.852567] spi-nand spi0.0: Winbond SPI NAND was found.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    0.857874] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    0.866120] 4 fixed-partitions partitions found on MTD device spi0.0
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    0.872463] Creating 4 MTD partitions on "spi0.0":
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    0.877236] 0x000000580000-0x000008000000 : "ubi"
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    1.009214] 0x000000380000-0x000000580000 : "fip"
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    1.016320] 0x000000080000-0x000000380000 : "reserved"
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    1.024888] 0x000000000000-0x000000080000 : "bl2"
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.163217] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009680000, irq 136
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.173011] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009680000, irq 136
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.182543] i2c_dev: i2c /dev entries driver
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.188297] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.196823] NET: Registered PF_INET6 protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.202433] Segment Routing with IPv6
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.206105] In-situ OAM (IOAM) with IPv6
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.210068] NET: Registered PF_PACKET protocol family
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.215128] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.228297] 8021q: 802.1Q VLAN Support v1.8
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.233317] pstore: Using crash dump compression: deflate
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.244395] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.251734] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.257987] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
Mon Nov 13 10:07:44 2023 kern.warn kernel: [    1.274628] mmc0: host does not support reading read-only switch, assuming write-enable
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.285458] mmc0: new high speed SDXC card at address aaaa
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.291721] mmcblk0: mmc0:aaaa SC256 238 GiB
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.303140] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.312183] FIT:           kernel sub-image 0x00001000..0x004ed1ae "kernel-1" (ARM64 OpenWrt Linux-5.15.134)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.322082] FIT:          flat_dt sub-image 0x004ee000..0x004f5b66 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.333282] FIT:          flat_dt sub-image 0x004f6000..0x004f61dc "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.349597] FIT:          flat_dt sub-image 0x004f7000..0x004f7390 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.365915] FIT:          flat_dt sub-image 0x004f8000..0x004f838f "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.382061] FIT:          flat_dt sub-image 0x004f9000..0x004f9146 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.398025] FIT:       filesystem sub-image 0x004fa000..0x00a4dfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    1.408612] FIT: selecting configured loadable "rootfs-1" to be root filesystem
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.415905]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p65(rootfs-1) p66(rootfs_data)
Mon Nov 13 10:07:44 2023 kern.err kernel: [    1.482067] mtk-pcie-gen3 11280000.pcie: PCIe link down, ltssm reg val: 0x1000001
Mon Nov 13 10:07:44 2023 kern.warn kernel: [    1.489564] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.518397] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.527447] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.536134] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=144)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.556471] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=145)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.576495] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=146)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.596495] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=147)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.616482] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=148)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    1.627587] DSA: tree 0 setup
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    1.632721] UBI: auto-attach mtd0
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    1.636034] ubi0: default fastmap pool size: 45
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    1.640555] ubi0: default fastmap WL pool size: 22
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    1.645329] ubi0: attaching mtd0
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.249357] ubi0: scanning is finished
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.294294] ubi0: attached mtd0 (name "ubi", size 122 MiB)
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.299774] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.306635] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.313404] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.320347] ubi0: good PEBs: 980, bad PEBs: 0, corrupted PEBs: 0
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.326332] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.333533] ubi0: max/mean erase counter: 3/0, WL threshold: 4096, image sequence number: 1642748947
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.342641] ubi0: available PEBs: 465, total reserved PEBs: 515, PEBs reserved for bad PEB handling: 20
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    5.352015] ubi0: background thread "ubi_bgt0d" started, PID 556
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.358072] block ubiblock0_1: created from ubi0:1(rootfs)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.372452] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.379721] Freeing unused kernel memory: 448K
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.410102] Run /sbin/init as init process
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    5.414182]   with arguments:
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    5.417132]     /sbin/init
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    5.419823]   with environment:
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    5.422952]     HOME=/
Mon Nov 13 10:07:44 2023 kern.debug kernel: [    5.425296]     TERM=linux
Mon Nov 13 10:07:44 2023 user.info kernel: [    5.550314] init: Console is alive
Mon Nov 13 10:07:44 2023 user.info kernel: [    5.553805] init: - watchdog -
Mon Nov 13 10:07:44 2023 user.info kernel: [    5.813749] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.836017] usbcore: registered new interface driver usbfs
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.841550] usbcore: registered new interface driver hub
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.846874] usbcore: registered new device driver usb
Mon Nov 13 10:07:44 2023 kern.warn kernel: [    5.855237] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
Mon Nov 13 10:07:44 2023 kern.warn kernel: [    5.862644] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.870787] xhci-mtk 11200000.usb: xHCI Host Controller
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.876016] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.886467] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.895617] xhci-mtk 11200000.usb: irq 128, io mem 0x11200000
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.901447] xhci-mtk 11200000.usb: xHCI Host Controller
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.906657] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.914041] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.921422] hub 1-0:1.0: USB hub found
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.925175] hub 1-0:1.0: 2 ports detected
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.929409] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.937748] hub 2-0:1.0: USB hub found
Mon Nov 13 10:07:44 2023 kern.info kernel: [    5.941510] hub 2-0:1.0: 1 port detected
Mon Nov 13 10:07:44 2023 user.info kernel: [    5.947768] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Mon Nov 13 10:07:44 2023 user.info kernel: [    5.961779] init: - preinit -
Mon Nov 13 10:07:44 2023 kern.info kernel: [    6.163018] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Mon Nov 13 10:07:44 2023 kern.info kernel: [    6.171488] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:44 2023 kern.info kernel: [    6.179661] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
Mon Nov 13 10:07:44 2023 kern.info kernel: [    6.410054] usb 1-1: new high-speed USB device number 2 using xhci-mtk
Mon Nov 13 10:07:44 2023 kern.info kernel: [    6.590725] hub 1-1:1.0: USB hub found
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    6.591641] random: procd: uninitialized urandom read (4 bytes read)
Mon Nov 13 10:07:44 2023 kern.info kernel: [    6.594505] hub 1-1:1.0: 4 ports detected
Mon Nov 13 10:07:44 2023 kern.info kernel: [    7.020054] usb 1-1.1: new high-speed USB device number 3 using xhci-mtk
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    9.221164] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = 1ae19688
Mon Nov 13 10:07:44 2023 user.info kernel: [    9.231665] mount_root: switching to f2fs overlay
Mon Nov 13 10:07:44 2023 kern.warn kernel: [    9.238323] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
Mon Nov 13 10:07:44 2023 user.debug kernel: [    9.254304] urandom-seed: Seeding with /etc/urandom.seed
Mon Nov 13 10:07:44 2023 user.info kernel: [    9.292463] procd: - early -
Mon Nov 13 10:07:44 2023 user.info kernel: [    9.295388] procd: - watchdog -
Mon Nov 13 10:07:44 2023 user.info kernel: [    9.825166] procd: - watchdog -
Mon Nov 13 10:07:44 2023 user.info kernel: [    9.829298] procd: - ubus -
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    9.854044] random: ubusd: uninitialized urandom read (4 bytes read)
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    9.881425] random: ubusd: uninitialized urandom read (4 bytes read)
Mon Nov 13 10:07:44 2023 kern.notice kernel: [    9.890596] random: ubusd: uninitialized urandom read (4 bytes read)
Mon Nov 13 10:07:44 2023 user.info kernel: [    9.899354] procd: - init -
Mon Nov 13 10:07:44 2023 user.info kernel: [   10.120309] kmodloader: loading kernel modules from /etc/modules.d/*
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.132418] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.139035] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.148240] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.162818] usbcore: registered new interface driver cdc_wdm
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.168737] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.176220] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.186663] sfp sfp-1: Host maximum power 3.0W
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.191917] sfp sfp-2: Host maximum power 3.0W
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.198843] usbcore: registered new interface driver usbserial_generic
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.205443] usbserial: USB Serial support registered for generic
Mon Nov 13 10:07:44 2023 user.info kernel: [   10.243052] urngd: v1.0.2 started.
Mon Nov 13 10:07:44 2023 kern.notice kernel: [   10.347471] random: crng init done
Mon Nov 13 10:07:44 2023 kern.notice kernel: [   10.350872] random: 28 urandom warning(s) missed due to ratelimiting
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.683497] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20221012174743a
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.810241] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20221012174805
Mon Nov 13 10:07:44 2023 kern.info kernel: [   10.887300] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20221012174937
Mon Nov 13 10:07:44 2023 kern.info kernel: [   13.656961] PPP generic driver version 2.4.2
Mon Nov 13 10:07:44 2023 kern.info kernel: [   13.661941] NET: Registered PF_PPPOX protocol family
Mon Nov 13 10:07:44 2023 kern.err kernel: [   13.667824] xhci-mtk 11200000.usb: drop_ep_quirk high-speed ep9in intr, mpkt:8, interval:9/32ms
Mon Nov 13 10:07:44 2023 kern.info kernel: [   13.677368] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Mon Nov 13 10:07:44 2023 kern.info kernel: [   13.683666] qmi_wwan 1-1.1:1.4 wwan0: register 'qmi_wwan' at usb-11200000.usb-1.1, WWAN/QMI device, 12:ae:6f:c1:87:d7
Mon Nov 13 10:07:44 2023 kern.info kernel: [   13.694424] usbcore: registered new interface driver qmi_wwan
Mon Nov 13 10:07:44 2023 kern.info kernel: [   13.704604] usbcore: registered new interface driver qcserial
Mon Nov 13 10:07:44 2023 kern.info kernel: [   13.710422] usbserial: USB Serial support registered for Qualcomm USB modem
Mon Nov 13 10:07:44 2023 user.info kernel: [   13.717631] kmodloader: done loading kernel modules from /etc/modules.d/*
Mon Nov 13 10:07:45 2023 daemon.notice procd: /etc/rc.d/S13openssl: Generating engines.cnf
Mon Nov 13 10:07:45 2023 daemon.notice procd: /etc/rc.d/S13openssl: Generating providers.cnf
Mon Nov 13 10:07:45 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mon Nov 13 10:07:45 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: DNS service limited to local subnets
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:07:45 2023 daemon.warn dnsmasq[1]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:07:45 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 6 names
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: bonding
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: 8021ad
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: 8021q
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: macvlan
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: veth
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: bridge
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: Network device
Mon Nov 13 10:07:45 2023 user.notice : Added device handler type: tunnel
Mon Nov 13 10:07:45 2023 daemon.notice procd: /etc/rc.d/S25packet_steering: uci: Entry not found
Mon Nov 13 10:07:45 2023 daemon.notice wpa_supplicant[1778]: Successfully initialized wpa_supplicant
Mon Nov 13 10:07:45 2023 cron.err crond[2030]: crond (busybox 1.36.1) started, log level 5
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: configfile: stat (/etc/collectd/conf.d/*.conf) failed: No such file or directory
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "cpu" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "interface" successfully loaded.
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/network
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/wireless
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "iwinfo" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "load" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "memory" successfully loaded.
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/luci-splash reload dependency on /etc/config/firewall
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/qos reload dependency on /etc/config/firewall
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/miniupnpd reload dependency on /etc/config/firewall
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "rrdtool" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: rrdtool plugin: RRASingle = true: creating only AVERAGE RRAs
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: plugin_load: plugin "sensors" successfully loaded.
Mon Nov 13 10:07:46 2023 daemon.err collectd[2221]: Initialization complete, entering read-loop.
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.358508] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/odhcpd reload dependency on /etc/config/dhcp
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.370704] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.379136] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.383354] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.397767] br-lan: port 1(lan1) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.403061] br-lan: port 1(lan1) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.409716] device lan1 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.414450] device eth0 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.421492] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'lan' is enabled
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'lan' is setting up now
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'lan' is now up
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.437772] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.447664] br-lan: port 2(lan2) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.452936] br-lan: port 2(lan2) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.459913] device lan2 entered promiscuous mode
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.472088] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.481951] br-lan: port 3(lan3) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.487178] br-lan: port 3(lan3) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.494447] device lan3 entered promiscuous mode
Mon Nov 13 10:07:46 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/luci_statistics reload dependency on /etc/config/system
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.506490] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.516405] br-lan: port 4(lan4) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.521680] br-lan: port 4(lan4) entered disabled state
Mon Nov 13 10:07:46 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/system
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.528937] device lan4 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.538083] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.547805] br-lan: port 5(sfp2) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.553097] br-lan: port 5(sfp2) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.560572] device sfp2 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.569227] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.579780] br-wan: port 1(eth1) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.585128] br-wan: port 1(eth1) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.590616] device eth1 entered promiscuous mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.596845] br-wan: port 1(eth1) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.602117] br-wan: port 1(eth1) entered forwarding state
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' is enabled
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan6' is enabled
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.612477] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.622245] br-wan: port 2(wan) entered blocking state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.627395] br-wan: port 2(wan) entered disabled state
Mon Nov 13 10:07:46 2023 kern.info kernel: [   15.634129] device wan entered promiscuous mode
Mon Nov 13 10:07:46 2023 daemon.notice netifd: bridge 'br-wan' link is up
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' has link connectivity
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' is setting up now
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan6' has link connectivity
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'loopback' is enabled
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'loopback' is setting up now
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'loopback' is now up
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'qmi_wwan' is setting up now
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Network device 'eth0' link is up
Mon Nov 13 10:07:46 2023 daemon.notice netifd: bridge 'br-wan' link is down
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' has link connectivity loss
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Network device 'lo' link is up
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'loopback' has link connectivity
Mon Nov 13 10:07:46 2023 daemon.notice netifd: radio1 (2595): WARNING: Variable 'data' does not exist or is not an array/object
Mon Nov 13 10:07:46 2023 daemon.notice netifd: qmi_wwan (2592): Waiting for SIM initialization
Mon Nov 13 10:07:46 2023 daemon.notice netifd: radio0 (2594): WARNING: Variable 'data' does not exist or is not an array/object
Mon Nov 13 10:07:46 2023 daemon.notice netifd: Interface 'wan' is now down
Mon Nov 13 10:07:46 2023 daemon.info pppd[2676]: Plugin pppoe.so loaded.
Mon Nov 13 10:07:46 2023 daemon.info pppd[2676]: PPPoE plugin from pppd 2.4.9
Mon Nov 13 10:07:46 2023 daemon.notice pppd[2676]: pppd 2.4.9 started by root, uid 0
Mon Nov 13 10:07:46 2023 daemon.info procd: - init complete -
Mon Nov 13 10:07:47 2023 daemon.notice netifd: qmi_wwan (2592): Failed to parse message data
Mon Nov 13 10:07:47 2023 daemon.notice netifd: qmi_wwan (2592): PIN already verified
Mon Nov 13 10:07:47 2023 kern.info kernel: [   16.400938] br-wan: port 1(eth1) entered disabled state
Mon Nov 13 10:07:47 2023 authpriv.warn dropbear[2944]: Failed listening on '2101': Error listening: Address not available
Mon Nov 13 10:07:47 2023 authpriv.info dropbear[2944]: Not backgrounding
Mon Nov 13 10:07:47 2023 daemon.notice netifd: qmi_wwan (2592): Device does not support 802.3 mode. Informing driver of raw-ip only for wwan0 ..
Mon Nov 13 10:07:47 2023 daemon.notice hostapd: Set new config for phy phy1:
Mon Nov 13 10:07:47 2023 daemon.notice wpa_supplicant[1778]: Set new config for phy phy1
Mon Nov 13 10:07:47 2023 daemon.notice hostapd: Set new config for phy phy0:
Mon Nov 13 10:07:47 2023 daemon.notice wpa_supplicant[1778]: Set new config for phy phy0
Mon Nov 13 10:07:47 2023 daemon.notice netifd: qmi_wwan (2592): Waiting for network registration
Mon Nov 13 10:07:47 2023 daemon.notice netifd: radio0 (2594): sh: acs_survey: out of range
Mon Nov 13 10:07:48 2023 daemon.notice netifd: radio0 (2594): sh: acs_survey: out of range
Mon Nov 13 10:07:48 2023 daemon.notice wpa_supplicant[1778]: Set new config for phy phy1
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Set new config for phy phy1: /var/run/hostapd-phy1.conf
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Restart interface for phy phy1
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=DE ieee80211d=1 ieee80211h=1 hw_mode=a beacon_int=100 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935] ieee80211ac=1 vht_oper_chwidth=2 vht_oper_centr_freq_seg0_idx=acs_survey vht_capab=[RXLDPC][SHORT-GI-80][SHORT-GI-160][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-4][BF-ANTENNA-4][VHT160][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7] ieee80211ax=1 he_oper_chwidth=2 he_oper_centr_freq_seg0_idx=acs_survey he_su_beamformer=1 he_su_beamformee=1 he_mu_beamformer=1 he_bss_color=128 he_spr_sr_control=3 he_default_pe_duration=4 he_rts_threshold=1023 he_mu_edca_qos_info_param_count=0 he_mu_edca_qos_info_q_ack=0 he_mu_edca_qos_info_queue_request=0 he_mu_edca_qos_in
Mon Nov 13 10:07:48 2023 daemon.notice wpa_supplicant[1778]: Set new config for phy phy0
Mon Nov 13 10:07:48 2023 kern.info kernel: [   17.145873] br-lan: port 6(phy1-ap0) entered blocking state
Mon Nov 13 10:07:48 2023 kern.info kernel: [   17.151537] br-lan: port 6(phy1-ap0) entered disabled state
Mon Nov 13 10:07:48 2023 kern.info kernel: [   17.157328] device phy1-ap0 entered promiscuous mode
Mon Nov 13 10:07:48 2023 kern.info kernel: [   17.711831] br-lan: port 6(phy1-ap0) entered blocking state
Mon Nov 13 10:07:48 2023 kern.info kernel: [   17.717410] br-lan: port 6(phy1-ap0) entered forwarding state
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: phy1-ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Mon Nov 13 10:07:48 2023 kern.info kernel: [   17.725960] device phy1-ap0 left promiscuous mode
Mon Nov 13 10:07:48 2023 kern.info kernel: [   17.730785] br-lan: port 6(phy1-ap0) entered disabled state
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: phy1-ap0: interface state COUNTRY_UPDATE->ACS
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: phy1-ap0: ACS-STARTED
Mon Nov 13 10:07:48 2023 daemon.notice netifd: bridge 'br-wan' link is down
Mon Nov 13 10:07:48 2023 daemon.notice netifd: Interface 'wan' has link connectivity loss
Mon Nov 13 10:07:48 2023 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Restart interface for phy phy0
Mon Nov 13 10:07:48 2023 daemon.err pppd[2676]: select (waitForPADO): Interrupted system call
Mon Nov 13 10:07:48 2023 daemon.warn pppd[2676]: Timeout waiting for PADO packets
Mon Nov 13 10:07:48 2023 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=DE ieee80211d=1 hw_mode=g supported_rates=60 90 120 180 240 360 480 540 basic_rates=60 120 240 beacon_int=100 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935] channel=acs_survey  interface=phy0-ap0 bssid=9a:ab:b8:68:ce:3c ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 disassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_advertisement_enabled=1 utf8_ssid=1 multi_ap=0 sae_require_mfp=1 sae_pwe=2 wpa_passphrase=19Triathlon#85unsernest wpa_psk_file=/var/run/hostapd-phy0-ap0.psk auth_algs=1 wpa=2 wpa_pairwise=CCMP ssid=unsernest bridge=br-lan wds_bridge= snoop_iface=br-lan wpa_disable_eapol_key_retries=0 wpa_key_mgmt=WPA-PSK WPA-PSK-SHA256 SAE okc=1 ieee80211w=1 group_mgmt_cipher=AES
Mon Nov 13 10:07:48 2023 daemon.err pppd[2676]: Unable to complete PPPoE Discovery
Mon Nov 13 10:07:48 2023 daemon.info pppd[2676]: Exit.
Mon Nov 13 10:07:48 2023 kern.info kernel: [   18.001428] mt7530-mdio mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.338813] br-lan: port 6(phy0-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.344415] br-lan: port 6(phy0-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.350129] device phy0-ap0 entered promiscuous mode
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.355201] br-lan: port 6(phy0-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.360785] br-lan: port 6(phy0-ap0) entered forwarding state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.366592] br-wan: port 2(wan) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.371723] br-wan: port 2(wan) entered forwarding state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.377106] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Mon Nov 13 10:07:49 2023 daemon.notice hostapd: phy0-ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'wan' is now down
Mon Nov 13 10:07:49 2023 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Mon Nov 13 10:07:49 2023 daemon.notice hostapd: phy0-ap0: interface state COUNTRY_UPDATE->ACS
Mon Nov 13 10:07:49 2023 daemon.notice hostapd: phy0-ap0: ACS-STARTED
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.386072] device phy0-ap0 left promiscuous mode
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.390952] br-lan: port 6(phy0-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan' is now up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Wireless device 'radio1' is now up
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.454780] br-lan: port 6(phy1-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.460417] br-lan: port 6(phy1-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.466252] device phy1-ap0 entered promiscuous mode
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan (2592): Starting network qmi_wwan
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan (2592): Setting up wwan0
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Network device 'wan' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: bridge 'br-lan' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'lan' has link connectivity
Mon Nov 13 10:07:49 2023 daemon.notice netifd: bridge 'br-wan' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'wan' has link connectivity
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'wan' is setting up now
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'wan6' has link connectivity
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Network device 'wwan0' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Wireless device 'radio0' is now up
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.526255] br-lan: port 7(phy0-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.531890] br-lan: port 7(phy0-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.537648] device phy0-ap0 entered promiscuous mode
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.542813] br-lan: port 7(phy0-ap0) entered blocking state
Mon Nov 13 10:07:49 2023 user.notice firewall: Reloading firewall due to ifup of qmi_wwan (wwan0)
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.548384] br-lan: port 7(phy0-ap0) entered forwarding state
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::aaaa#53
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::bbbb#53
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: Plugin pppoe.so loaded.
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: PPPoE plugin from pppd 2.4.9
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Network alias 'wwan0' link is up
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan_4' is enabled
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan_4' has link connectivity
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan_4' is setting up now
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 6 names
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c.2946 - 6 names
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 0 names
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: started, v1.36.1
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: broadcasting discover
Mon Nov 13 10:07:49 2023 daemon.notice pppd[3508]: pppd 2.4.9 started by root, uid 0
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: broadcasting select for 10.240.160.174, server 10.240.160.173
Mon Nov 13 10:07:49 2023 daemon.notice netifd: bridge 'br-lan' link is down
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'lan' has link connectivity loss
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.800176] br-lan: port 7(phy0-ap0) entered disabled state
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: PPP session is 11
Mon Nov 13 10:07:49 2023 user.notice firewall: Reloading firewall due to ifupdate of qmi_wwan (wwan0)
Mon Nov 13 10:07:49 2023 daemon.warn pppd[3508]: Connected to f4:cc:55:8f:d6:e7 via interface br-wan
Mon Nov 13 10:07:49 2023 kern.info kernel: [   18.900806] pppoe-wan: renamed from ppp0
Mon Nov 13 10:07:49 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: lease of 10.240.160.174 obtained from 10.240.160.173, lease time 7200
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: Renamed interface ppp0 to pppoe-wan
Mon Nov 13 10:07:49 2023 daemon.info pppd[3508]: Using interface pppoe-wan
Mon Nov 13 10:07:49 2023 daemon.notice pppd[3508]: Connect: pppoe-wan <--> br-wan
Mon Nov 13 10:07:49 2023 daemon.notice netifd: Interface 'qmi_wwan_4' is now up
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.17#53
Mon Nov 13 10:07:49 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.18#53
Mon Nov 13 10:07:50 2023 user.notice firewall: Reloading firewall due to ifup of qmi_wwan_4 (wwan0)
Mon Nov 13 10:07:50 2023 kern.info kernel: [   19.432716] mt7530-mdio mdio-bus:1f lan4: Link is Up - 1Gbps/Full - flow control rx/tx
Mon Nov 13 10:07:50 2023 kern.info kernel: [   19.440666] br-lan: port 4(lan4) entered blocking state
Mon Nov 13 10:07:50 2023 kern.info kernel: [   19.445876] br-lan: port 4(lan4) entered forwarding state
Mon Nov 13 10:07:50 2023 daemon.notice netifd: Network device 'lan4' link is up
Mon Nov 13 10:07:50 2023 daemon.notice netifd: bridge 'br-lan' link is up
Mon Nov 13 10:07:50 2023 daemon.notice netifd: Interface 'lan' has link connectivity
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: started, version 2.89 cachesize 1000
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: DNS service limited to local subnets
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::aaaa#53
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::bbbb#53
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.17#53
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.18#53
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 0 names
Mon Nov 13 10:07:50 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:07:51 2023 authpriv.info dropbear[2944]: Early exit: Terminated by signal
Mon Nov 13 10:07:51 2023 authpriv.info dropbear[3843]: Not backgrounding
Mon Nov 13 10:07:51 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:07:51 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:07:51 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 0 names
Mon Nov 13 10:07:51 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:35:32 2023 daemon.info pppd[3508]: Remote message: Accepted.
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: PAP authentication succeeded
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: peer from calling number F4:CC:55:8F:D6:E7 authorized
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: local  LL address fe80::d816:ec54:508e:6fe0
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: remote LL address fe80::da49:0bff:feb7:37b5
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: local  IP address 77.185.111.30
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: remote IP address 62.52.200.219
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: primary   DNS address 62.109.121.1
Mon Nov 13 10:35:32 2023 daemon.notice pppd[3508]: secondary DNS address 62.109.121.2
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Network device 'pppoe-wan' link is up
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Interface 'wan' is now up
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::aaaa#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::bbbb#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.17#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.18#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.1#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.2#53
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:35:32 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Network alias 'pppoe-wan' link is up
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Interface 'wan_6' is enabled
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Interface 'wan_6' has link connectivity
Mon Nov 13 10:35:32 2023 daemon.notice netifd: Interface 'wan_6' is setting up now
Mon Nov 13 10:35:32 2023 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Mon Nov 13 10:35:32 2023 user.notice firewall: Reloading firewall due to ifupdate of wan (pppoe-wan)
Mon Nov 13 10:35:32 2023 user.notice ddns-scripts[4234]: myddns_ipv4: PID '4234' started at 2023-11-13 10:35
Mon Nov 13 10:35:32 2023 user.warn ddns-scripts[4234]: myddns_ipv4: Service section disabled! - TERMINATE
Mon Nov 13 10:35:32 2023 user.warn ddns-scripts[4234]: myddns_ipv4: PID '4234' exit WITH ERROR '1' at 2023-11-13 10:35
Mon Nov 13 10:35:33 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:35:33 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:35:33 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 4 names
Mon Nov 13 10:35:33 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:35:36 2023 daemon.notice netifd: Interface 'wan_6' is now up
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::aaaa#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 2a02:3018:0:40ff::bbbb#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.17#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.18#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.1#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 62.109.121.2#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 2a01:c30::530#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using nameserver 2a01:c30::531#53
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 6 names
Mon Nov 13 10:35:36 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:35:36 2023 user.notice firewall: Reloading firewall due to ifup of wan_6 (pppoe-wan)
Mon Nov 13 10:35:39 2023 daemon.notice hostapd: ACS: Survey for freq 2412 is missing noise floor
Mon Nov 13 10:35:39 2023 daemon.notice hostapd: phy0-ap0: ACS-COMPLETED freq=2412 channel=1
Mon Nov 13 10:35:39 2023 daemon.notice hostapd: phy0-ap0: interface state ACS->HT_SCAN
Mon Nov 13 10:35:41 2023 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=1 sec=5 based on overlapping BSSes
Mon Nov 13 10:35:41 2023 daemon.notice hostapd: Fallback to 20 MHz
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.605414] IPv6: ADDRCONF(NETDEV_CHANGE): phy0-ap0: link becomes ready
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.612161] br-lan: port 7(phy0-ap0) entered blocking state
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.617723] br-lan: port 7(phy0-ap0) entered forwarding state
Mon Nov 13 10:35:41 2023 daemon.notice netifd: Network device 'phy0-ap0' link is up
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.751654] br-lan: port 8(phy0-ap1) entered blocking state
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.757238] br-lan: port 8(phy0-ap1) entered disabled state
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.763068] device phy0-ap1 entered promiscuous mode
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.769079] br-lan: port 8(phy0-ap1) entered blocking state
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.774665] br-lan: port 8(phy0-ap1) entered forwarding state
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.780807] device phy0-ap1 left promiscuous mode
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.785556] br-lan: port 8(phy0-ap1) entered disabled state
Mon Nov 13 10:35:41 2023 kern.info kernel: [   31.858584] IPv6: ADDRCONF(NETDEV_CHANGE): phy0-ap1: link becomes ready
Mon Nov 13 10:35:42 2023 daemon.notice hostapd: phy0-ap0: interface state HT_SCAN->ENABLED
Mon Nov 13 10:35:42 2023 daemon.notice hostapd: phy0-ap0: AP-ENABLED
Mon Nov 13 10:35:44 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.1.123 e4:5f:01:66:6a:d9
Mon Nov 13 10:35:44 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.123 e4:5f:01:66:6a:d9
Mon Nov 13 10:35:44 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.123 e4:5f:01:66:6a:d9
Mon Nov 13 10:35:44 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.123 e4:5f:01:66:6a:d9 nest-assistent
Mon Nov 13 10:35:46 2023 daemon.info hostapd: phy0-ap0: STA 48:55:19:15:0f:bb IEEE 802.11: authenticated
Mon Nov 13 10:35:46 2023 daemon.info hostapd: phy0-ap0: STA 48:55:19:15:0f:bb IEEE 802.11: associated (aid 1)
Mon Nov 13 10:35:46 2023 daemon.notice hostapd: phy0-ap0: AP-STA-CONNECTED 48:55:19:15:0f:bb auth_alg=open
Mon Nov 13 10:35:46 2023 daemon.info hostapd: phy0-ap0: STA 48:55:19:15:0f:bb WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:35:46 2023 daemon.notice hostapd: phy0-ap0: EAPOL-4WAY-HS-COMPLETED 48:55:19:15:0f:bb
Mon Nov 13 10:35:47 2023 daemon.info hostapd: phy0-ap0: STA 70:91:8f:28:7e:d6 IEEE 802.11: authenticated
Mon Nov 13 10:35:48 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 48:55:19:15:0f:bb
Mon Nov 13 10:35:48 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.131 48:55:19:15:0f:bb
Mon Nov 13 10:35:48 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.131 48:55:19:15:0f:bb
Mon Nov 13 10:35:48 2023 daemon.warn dnsmasq-dhcp[1]: Ignoring domain mikeg.de for DHCP host name nest-therm
Mon Nov 13 10:35:48 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.131 48:55:19:15:0f:bb nest-therm
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: phy1-ap0: ACS-COMPLETED freq=5520 channel=104
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: phy1-ap0: interface state ACS->HT_SCAN
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: Switch own primary and secondary channel to get secondary channel with no Beacons from other BSSes
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: phy1-ap0: interface state HT_SCAN->DFS
Mon Nov 13 10:35:49 2023 daemon.notice hostapd: phy1-ap0: DFS-CAC-START freq=5500 chan=100 sec_chan=1, width=2, seg0=114, seg1=0, cac_time=60s
Mon Nov 13 10:35:51 2023 daemon.info hostapd: phy0-ap0: STA 70:91:8f:28:7e:d6 IEEE 802.11: associated (aid 2)
Mon Nov 13 10:35:51 2023 daemon.notice hostapd: phy0-ap0: AP-STA-CONNECTED 70:91:8f:28:7e:d6 auth_alg=sae
Mon Nov 13 10:35:51 2023 daemon.info hostapd: phy0-ap0: STA 70:91:8f:28:7e:d6 WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:35:51 2023 daemon.notice hostapd: phy0-ap0: EAPOL-4WAY-HS-COMPLETED 70:91:8f:28:7e:d6
Mon Nov 13 10:35:55 2023 daemon.err collectd[2221]: Sleeping only 2s because the next interval is 1629.102 seconds in the past!
Mon Nov 13 10:35:56 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 70:91:8f:28:7e:d6
Mon Nov 13 10:35:56 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.118 70:91:8f:28:7e:d6
Mon Nov 13 10:35:56 2023 daemon.err collectd[2221]: rrdtool plugin: rrd_update_r failed: /tmp/rrd/NestRouter/cpu-1/percent-interrupt.rrd: opening '/tmp/rrd/NestRouter/cpu-1/percent-interrupt.rrd': No such file or directory
Mon Nov 13 10:35:56 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.118 70:91:8f:28:7e:d6
Mon Nov 13 10:35:56 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.118 70:91:8f:28:7e:d6
Mon Nov 13 10:36:43 2023 daemon.info hostapd: phy0-ap0: STA 84:78:8b:7b:be:6f IEEE 802.11: authenticated
Mon Nov 13 10:36:43 2023 daemon.info hostapd: phy0-ap0: STA 84:78:8b:7b:be:6f IEEE 802.11: associated (aid 3)
Mon Nov 13 10:36:43 2023 daemon.notice hostapd: phy0-ap0: AP-STA-CONNECTED 84:78:8b:7b:be:6f auth_alg=open
Mon Nov 13 10:36:43 2023 daemon.info hostapd: phy0-ap0: STA 84:78:8b:7b:be:6f WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:36:43 2023 daemon.notice hostapd: phy0-ap0: EAPOL-4WAY-HS-COMPLETED 84:78:8b:7b:be:6f
Mon Nov 13 10:36:43 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.141 84:78:8b:7b:be:6f
Mon Nov 13 10:36:43 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.141 84:78:8b:7b:be:6f iPad-von-Mina
Mon Nov 13 10:36:50 2023 daemon.notice hostapd: phy1-ap0: DFS-CAC-COMPLETED success=1 freq=5500 ht_enabled=0 chan_offset=0 chan_width=5 cf1=5570 cf2=0
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.018073] IPv6: ADDRCONF(NETDEV_CHANGE): phy1-ap0: link becomes ready
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.024824] br-lan: port 6(phy1-ap0) entered blocking state
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.030395] br-lan: port 6(phy1-ap0) entered forwarding state
Mon Nov 13 10:36:51 2023 daemon.notice netifd: Network device 'phy1-ap0' link is up
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.141614] br-lan: port 8(phy1-ap1) entered blocking state
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.147200] br-lan: port 8(phy1-ap1) entered disabled state
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.153069] device phy1-ap1 entered promiscuous mode
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.160126] br-lan: port 8(phy1-ap1) entered blocking state
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.165694] br-lan: port 8(phy1-ap1) entered forwarding state
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.171855] device phy1-ap1 left promiscuous mode
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.176607] br-lan: port 8(phy1-ap1) entered disabled state
Mon Nov 13 10:36:51 2023 kern.info kernel: [  101.246383] IPv6: ADDRCONF(NETDEV_CHANGE): phy1-ap1: link becomes ready
Mon Nov 13 10:36:51 2023 daemon.notice hostapd: phy1-ap0: interface state DFS->ENABLED
Mon Nov 13 10:36:51 2023 daemon.notice hostapd: phy1-ap0: AP-ENABLED
Mon Nov 13 10:37:15 2023 daemon.info hostapd: phy1-ap0: STA 60:e9:aa:5d:c9:2d IEEE 802.11: associated (aid 1)
Mon Nov 13 10:37:15 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED 60:e9:aa:5d:c9:2d auth_alg=sae
Mon Nov 13 10:37:15 2023 daemon.info hostapd: phy1-ap0: STA 60:e9:aa:5d:c9:2d WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:37:15 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED 60:e9:aa:5d:c9:2d
Mon Nov 13 10:37:16 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:37:16 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:37:16 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 12 names
Mon Nov 13 10:37:16 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:37:18 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.206 60:e9:aa:5d:c9:2d
Mon Nov 13 10:37:18 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.206 60:e9:aa:5d:c9:2d Dose
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA e4:5f:01:66:6a:da IEEE 802.11: authenticated
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA e4:5f:01:66:6a:da IEEE 802.11: associated (aid 2)
Mon Nov 13 10:37:33 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED e4:5f:01:66:6a:da auth_alg=open
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA e4:5f:01:66:6a:da WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:37:33 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED e4:5f:01:66:6a:da
Mon Nov 13 10:37:33 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.124 e4:5f:01:66:6a:da
Mon Nov 13 10:37:33 2023 daemon.warn dnsmasq-dhcp[1]: Ignoring domain mikeg.de for DHCP host name nest-assistent
Mon Nov 13 10:37:33 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.124 e4:5f:01:66:6a:da nest-assistent
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA 72:85:aa:b1:62:01 IEEE 802.11: associated (aid 3)
Mon Nov 13 10:37:33 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED 72:85:aa:b1:62:01 auth_alg=sae
Mon Nov 13 10:37:33 2023 daemon.info hostapd: phy1-ap0: STA 72:85:aa:b1:62:01 WPA: pairwise key handshake completed (RSN)
Mon Nov 13 10:37:33 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED 72:85:aa:b1:62:01
Mon Nov 13 10:37:33 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.243 72:85:aa:b1:62:01
Mon Nov 13 10:37:33 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.243 72:85:aa:b1:62:01
Mon Nov 13 10:37:35 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 10:37:35 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 10:37:35 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 18 names
Mon Nov 13 10:37:35 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 10:37:52 2023 daemon.err uhttpd[2100]: [info] luci: accepted login on / for root from 192.168.1.206
Mon Nov 13 10:40:23 2023 daemon.warn dnsmasq[1]: possible DNS-rebind attack detected: dns.msftncsi.com
Mon Nov 13 11:02:55 2023 daemon.notice hostapd: phy1-ap0: AP-STA-POLL-OK e4:5f:01:66:6a:da
Mon Nov 13 11:14:59 2023 daemon.notice hostapd: phy1-ap0: AP-STA-POLL-OK e4:5f:01:66:6a:da
Mon Nov 13 11:18:43 2023 daemon.info hostapd: phy1-ap1: STA f4:7b:09:d3:1b:f2 IEEE 802.11: associated (aid 1)
Mon Nov 13 11:18:44 2023 daemon.notice hostapd: phy1-ap1: AP-STA-CONNECTED f4:7b:09:d3:1b:f2 auth_alg=sae
Mon Nov 13 11:18:44 2023 daemon.info hostapd: phy1-ap1: STA f4:7b:09:d3:1b:f2 WPA: pairwise key handshake completed (RSN)
Mon Nov 13 11:18:44 2023 daemon.notice hostapd: phy1-ap1: EAPOL-4WAY-HS-COMPLETED f4:7b:09:d3:1b:f2
Mon Nov 13 11:25:24 2023 daemon.notice hostapd: phy1-ap0: AP-STA-POLL-OK e4:5f:01:66:6a:da
Mon Nov 13 11:35:29 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: sending renew to server 10.240.160.173
Mon Nov 13 11:35:29 2023 daemon.notice netifd: qmi_wwan_4 (3525): udhcpc: lease of 10.240.160.174 obtained from 10.240.160.173, lease time 7200
Mon Nov 13 11:58:45 2023 kern.info kernel: [ 5010.206970] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
Mon Nov 13 11:58:45 2023 kern.info kernel: [ 5010.214907] br-lan: port 1(lan1) entered blocking state
Mon Nov 13 11:58:45 2023 kern.info kernel: [ 5010.220129] br-lan: port 1(lan1) entered forwarding state
Mon Nov 13 11:58:45 2023 daemon.notice netifd: Network device 'lan1' link is up
Mon Nov 13 11:58:47 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.164 04:7c:16:bf:96:df
Mon Nov 13 11:58:47 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.164 04:7c:16:bf:96:df Dose
Mon Nov 13 11:58:48 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Mon Nov 13 11:58:48 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Mon Nov 13 11:58:48 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 24 names
Mon Nov 13 11:58:48 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Mon Nov 13 11:59:16 2023 daemon.notice hostapd: phy1-ap0: AP-STA-DISCONNECTED 60:e9:aa:5d:c9:2d
Mon Nov 13 11:59:16 2023 daemon.info hostapd: phy1-ap0: STA 60:e9:aa:5d:c9:2d IEEE 802.11: disassociated
Mon Nov 13 11:59:17 2023 daemon.info hostapd: phy1-ap0: STA 60:e9:aa:5d:c9:2d IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon Nov 13 12:12:23 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e IEEE 802.11: authenticated
Mon Nov 13 12:12:23 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e IEEE 802.11: associated (aid 2)
Mon Nov 13 12:12:23 2023 daemon.notice hostapd: phy1-ap1: AP-STA-CONNECTED b4:0e:de:2b:de:1e auth_alg=open
Mon Nov 13 12:12:23 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e WPA: pairwise key handshake completed (RSN)
Mon Nov 13 12:12:23 2023 daemon.notice hostapd: phy1-ap1: EAPOL-4WAY-HS-COMPLETED b4:0e:de:2b:de:1e
Mon Nov 13 12:12:31 2023 daemon.notice hostapd: phy1-ap1: AP-STA-DISCONNECTED b4:0e:de:2b:de:1e
Mon Nov 13 12:17:28 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e IEEE 802.11: authenticated
Mon Nov 13 12:17:28 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e IEEE 802.11: associated (aid 2)
Mon Nov 13 12:17:28 2023 daemon.notice hostapd: phy1-ap1: AP-STA-CONNECTED b4:0e:de:2b:de:1e auth_alg=open
Mon Nov 13 12:17:28 2023 daemon.info hostapd: phy1-ap1: STA b4:0e:de:2b:de:1e WPA: pairwise key handshake completed (RSN)
Mon Nov 13 12:17:28 2023 daemon.notice hostapd: phy1-ap1: EAPOL-4WAY-HS-COMPLETED b4:0e:de:2b:de:1e
Mon Nov 13 12:17:40 2023 daemon.notice hostapd: phy1-ap1: AP-STA-DISCONNECTED b4:0e:de:2b:de:1e
Mon Nov 13 12:19:00 2023 daemon.err uhttpd[2100]: [info] luci: accepted login on /admin/status/logs for root from 192.168.1.164
Your Setup was: → Quectel Modem is inside mini PCI-E slot of BPI-R3 and Sim card is also inside SimSlot of BPI-R3?
Today, I also worked on the SIM card detection problem:
My new setup:
With SIM card inside the adapter card, now I have a present SIM card on the first time. I also rebooted, it is a stable recognition without any Sim card detection problems:
But for today is enough! Next time i will try to establith an internet connection.
Any updates to this thread? I would like to try Quectel 5G RM521F-GL, or RM520N-GL modem in the US.
Do you have a purchase link for this adapter? This is the one that works?
First of all the modems RM521F-GL and RM520N-GL are M2 form Factor? My Adapter should be wrong for your Modems!
My Adapter ist Mini PCI-E to Mini PCI-E for Quectel EC25. What you are looking for is a Mini PCI-E to M2 adapter. But I have no experiance with that! These Mini PCI-E of BPI-R3 is connected via USB2.
If you want to use faster Modems it is my a better idea to use the USB3 Port. But these requires an other adapter.
There are the Links for MY Adapter: https://www.aliexpress.us/item/3256801512657619.html?search_direct=true&spm=a2g0o.productlist.0.0&gatewayAdapt=glo2usa4itemAdapt
But I buyed my Adapter Card from Amazon Germany. I looked for you (US): https://www.amazon.com/SUPERPLUS-Mini-Adapter-Self-Elastic-Holder/dp/B07T33NQPF?th=1
Thanks for this valuable information! I think I will wait for the BPI-R4, hopefully it can fully utilize these modems that I am wanting to use.
Just as a reference. I bought this one and it works. Though, I have not fully setup things to use it as a fail over in case the dial up fails.
