Hello al I bought BPI R2 Pro (RK3568) Where I can found manual how burn image? eatcher doesn’t work In wiki also nothing
Any manual for build own openwrt use off git?
At first time that you run “build.sh” script, you may pick up your target board for openwrt.
then you can use “build.sh” for openwrt build.
./build.sh help
when I put any image to sd card, I receive same log seems like system hasn’t start image and start default OS. What I do wrong?
Also, when I try use Emma image, my PC can’t see BRI R2 PRO in device tree
