ok i tried:
ip link set eth0 up
ip link add name br0 type bridge
ip link set br0 up
ip link set lan0 master br0
ip link set lan0 up
ip addr add 192.168.2.33/24 broadcast 192.168.2.255 dev br0
ip route add 192.168.2.0/24 dev br0
ip route add default via 192.168.2.1
The R2 is getting an IP from the Router and i can connect to it.
But it get’s a new IP after every reboot, cause the MAC-Adress is changing every time. I also tried
ip link set lan0 address 0A:94:C3:AC:DA:57 up
instead of
ip link set lan0 up
but it hasn’t used this MAC.
Also other devices on the LAN-Ports can’t connect to the Router (in both cases).
Second try was:
brctl addbr br0
brctl addif br0 lan0
brctl addif br0 lan1
brctl addif br0 lan2
brctl addif br0 lan3
ip addr add 192.168.2.10/24 dev br0
ip link set br0 address 0A:94:C3:AC:DA:57 up
i don’t have any connection in this case.
“ip a” says:
inet6 ::1/128 scope host
link/ether 32:65:fe:3e:cd:a2 brd ff:ff:ff:ff:ff:ff
3: wan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether ce:1a:37:d6:27:66 brd ff:ff:ff:ff:ff:ff
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
5: lan0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet6 fe80::1786:4f3a:de4a:9f05/64 scope link noprefixroute
6: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
7: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
8: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
9: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:08:22:20:d5:fb brd ff:ff:ff:ff:ff:ff
10: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:b7:83:0f:a7 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 scope global docker0
