I do not see your br0 in “ip a”, and lan-ports are not mapped to bridge…
mac address changing has to be done for br0 and br0 has to be down before (so drop the br0 up in the middle).
You can use ip to configure the bridge instead of brctl,but set bridge up with the mac-change at the end
ip link set eth0 up
ip link add name br0 type bridge
ip link set lan0 master br0
#lan1,2,3,maybe need to set lanX up,but not yet the bridge
ip addr add 192.168.2.10/24 dev br0
ip link set br0 address 0A:94:C3:AC:DA:57 up
ip a
ip link set eth0 up
ip a
ip addr add 192.168.2.33/24 broadcast 192.168.2.255 dev br0
ip route add 192.168.2.0/24 dev br0
ip route add default via 192.168.2.1
i can connect to the R2, but no fixed MAC-Address and network switch is also not working. “ip a” says:
inet6 ::1/128 scope host
link/ether 92:38:8f:6b:85:f3 brd ff:ff:ff:ff:ff:ff
3: wan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 02:42:9d:f5:06:a1 brd ff:ff:ff:ff:ff:ff
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
5: lan0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
6: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
7: lan2@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
8: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
9: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:08:22:2a:da:fb brd ff:ff:ff:ff:ff:ff
10: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:cf:37:e3:e6 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 scope global docker0
i can’t see the BR0 - should i setup BR0 anywhere else?
It depends on which init is used…my images till buster use /etc/network/interfaces for permanant setting. I wanted to test is via ip command if the behaviour is as expected before doing a permanent solution. But yes,these settings get lost on reboot
@ericwoud: i used /etc/network/interfaces only for now. I always did a reboot before testing.
I tried your post (using “/etc/systemd/network”) and it’s working now!
All 4 Ports are linked - just the WAN-Port is not working as a switch. But for my case it doesn’t matter.
i made the “/etc/network/interfaces” empty, removed ifupdown, enabled systemd-networkd
