Hi, I find old banana pi r2 board. I would like to use it. Unfortunately, many of the sources for the software not work or are not unpatched. I found ubuntu mate but the last update is from the first half of 2018r which is a very long time ago. I would like a minimum of something based on ubuntu 18.04 and on some newer kernel. Can I find somewhere some newer software that can run on this hardware without any problem? Is anyone able to help me? I have tried many OS but nothing but the old one works properly.
I tried to upload an image to the mmc memory of the device - and it was rather successful but despite many attempts without an inserted SD card the OS does not boot. When I have the SD card inserted and changed, for example, the indication in fstab and uEnv.txt then the system boots and the path for ‘/’ points to emmc memory. When I remove the card and reboot the device nothing happens.
I’m new and just getting started
