I use Ubuntu 15.10 (20151203) and will use a SSD on SATA-Port. In syslog was found: Mar 6 22:01:55 bananapi kernel: [ 6.012499] scsi 0:0:0:0: Direct-Access INTENSO SSD 128GB 0016 PQ: 0 ANSI: 4 Mar 6 22:01:55 bananapi kernel: [ 6.013909] usb 1-1.3.4: New USB device found, idVendor=13ba, idProduct=0017 Mar 6 22:01:55 bananapi kernel: [ 6.013917] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0 Mar 6 22:01:55 bananapi kernel: [ 6.013924] usb 1-1.3.4: Product: Generic USB K/B Mar 6 22:01:55 bananapi kernel: [ 6.018119] generic-usb 0003:13BA:0017.0001: input,hidraw0: USB HID v1.10 Keyboard [Generic USB K/B] on usb-sunxi-ehci-1.3.4/input0 Mar 6 22:01:55 bananapi kernel: [ 6.075015] sd 0:0:0:0: Attached scsi generic sg0 type 0 Mar 6 22:01:55 bananapi kernel: [ 6.075707] sd 0:0:0:0: [sda] 250069676 512-byte logical blocks: (128 GB/119 GiB) Mar 6 22:01:55 bananapi kernel: [ 6.076700] sd 0:0:0:0: [sda] Write Protect is off Mar 6 22:01:55 bananapi kernel: [ 6.076708] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00 Mar 6 22:01:55 bananapi kernel: [ 6.077699] sd 0:0:0:0: [sda] No Caching mode page present Mar 6 22:01:55 bananapi kernel: [ 6.077706] sd 0:0:0:0: [sda] Assuming drive cache: write through Mar 6 22:01:55 bananapi kernel: [ 6.080947] sd 0:0:0:0: [sda] No Caching mode page present Mar 6 22:01:55 bananapi kernel: [ 6.080953] sd 0:0:0:0: [sda] Assuming drive cache: write through Mar 6 22:01:55 bananapi kernel: [ 6.084063] sda: sda1 sda2 sda3 < sda5 > Mar 6 22:01:55 bananapi kernel: [ 6.087677] sd 0:0:0:0: [sda] No Caching mode page present Mar 6 22:01:55 bananapi kernel: [ 6.087685] sd 0:0:0:0: [sda] Assuming drive cache: write through Mar 6 22:01:55 bananapi kernel: [ 6.087693] sd 0:0:0:0: [sda] Attached SCSI disk Mar 6 22:01:55 bananapi kernel: [ 6.120604] generic-usb 0003:13BA:0017.0002: input,hidraw1: USB HID v1.10 Mouse [Generic USB K/B] on usb-sunxi-ehci-1.3.4/input1 Mar 6 22:01:55 bananapi kernel: [ 7.099134] [DISP] disp_hdmi_set_detect,line:404:hdmi1ās mgr is NULL Mar 6 22:01:55 bananapi kernel: [ 7.111170] rtc_gettime(333): read time 1970-1-1 1:0:14 Mar 6 22:01:55 bananapi kernel: [ 7.120863] rtc0 rtc0: setting system clock to 1970-01-01 01:00:14 UTC (3614) Mar 6 22:01:55 bananapi kernel: [ 7.133615] sunxi_get_soc_bin: slow chip Mar 6 22:01:55 bananapi kernel: [ 7.142444] CPU Budget:Register notifier Mar 6 22:01:55 bananapi kernel: [ 7.150725] CPU Budget:register Success
but I cannot mount it.
If it connect with a USB-Controller then was the SSD also found
----- with use a USB to ATA/ATAPI bridge the INTENSO SSD 128GB was correct found and install Mar 9 09:30:22 bananapi kernel: [ 415.572025] usb 1-1.3.3: New USB device found, idVendor=152d, idProduct=2338 Mar 9 09:30:22 bananapi kernel: [ 415.572067] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=5 Mar 9 09:30:22 bananapi kernel: [ 415.572098] usb 1-1.3.3: Product: USB to ATA/ATAPI bridge Mar 9 09:30:22 bananapi kernel: [ 415.572124] usb 1-1.3.3: Manufacturer: JMicron Mar 9 09:30:22 bananapi kernel: [ 415.572148] usb 1-1.3.3: SerialNumber: F52628003801 Mar 9 09:30:22 bananapi kernel: [ 415.574871] scsi1 : usb-storage 1-1.3.3:1.0 Mar 9 09:30:22 bananapi mtp-probe: checking bus 1, device 6: ā/sys/devices/platform/sunxi-ehci.1/usb1/1-1/1-1.3/1-1.3.3ā Mar 9 09:30:22 bananapi mtp-probe: bus: 1, device: 6 was not an MTP device Mar 9 09:30:22 bananapi mtp-probe: checking bus 1, device 6: ā/sys/devices/platform/sunxi-ehci.1/usb1/1-1/1-1.3/1-1.3.3ā Mar 9 09:30:22 bananapi mtp-probe: bus: 1, device: 6 was not an MTP device Mar 9 09:30:23 bananapi kernel: [ 416.572709] scsi 1:0:0:0: Direct-Access INTENSO SSD 128GB PQ: 0 ANSI: 5 Mar 9 09:30:23 bananapi kernel: [ 416.579427] sd 1:0:0:0: Attached scsi generic sg1 type 0 Mar 9 09:30:23 bananapi kernel: [ 416.580140] sd 1:0:0:0: [sdb] 250069680 512-byte logical blocks: (128 GB/119 GiB) Mar 9 09:30:23 bananapi kernel: [ 416.581555] sd 1:0:0:0: [sdb] Write Protect is off Mar 9 09:30:23 bananapi kernel: [ 416.581608] sd 1:0:0:0: [sdb] Mode Sense: 28 00 00 00 Mar 9 09:30:23 bananapi kernel: [ 416.582873] sd 1:0:0:0: [sdb] No Caching mode page present Mar 9 09:30:23 bananapi kernel: [ 416.589062] sd 1:0:0:0: [sdb] Assuming drive cache: write through Mar 9 09:30:23 bananapi kernel: [ 416.599478] sd 1:0:0:0: [sdb] No Caching mode page present Mar 9 09:30:23 bananapi kernel: [ 416.605630] sd 1:0:0:0: [sdb] Assuming drive cache: write through Mar 9 09:30:23 bananapi kernel: [ 416.614261] sdb: sdb1 sdb2 sdb3 < sdb5 > Mar 9 09:30:23 bananapi kernel: [ 416.619766] sd 1:0:0:0: [sdb] No Caching mode page present Mar 9 09:30:23 bananapi kernel: [ 416.626044] sd 1:0:0:0: [sdb] Assuming drive cache: write through Mar 9 09:30:23 bananapi kernel: [ 416.632896] sd 1:0:0:0: [sdb] Attached SCSI disk Mar 9 09:30:23 bananapi kernel: [ 416.917977] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null) Mar 9 09:30:23 bananapi udisksd[914]: Mounted /dev/sdb1 at /media/pi/48051e4d-3629-489f-be52-30bbf7e2b725 on behalf of uid 1000 Mar 9 09:30:24 bananapi kernel: [ 417.042865] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null) Mar 9 09:30:24 bananapi udisksd[914]: Mounted /dev/sdb2 at /media/pi/fd5cb260-7ad2-427c-9f71-df575de15ca8 on behalf of uid 1000 Mar 9 09:34:30 bananapi udisksd[914]: Error performing housekeeping for drive /org/freedesktop/UDisks2/drives/INTENSO_SSD_128GB_F52628R03801: Error updating SMART data: sk_disk_smart_read_data: Operation not supported (udisks-error-quark, 0)
and I can work with the SSD.
What is to do for using SSD on SATA-Port???
Thanks
