BPI-M3 new image:Ubuntu Mate 15.10 for BPI-M3 GPU PowerVR SGX544MP (20160317)
  1. BPI-M3 kernel 3.4
  2. pi/bananapi , root/bananapi , bpi/bananapi
  3. support HDMI 1080P & 720P(default)
  4. support eMMC
  5. support GMAC
  6. support WIFI
  7. support SATA
  8. support bpi-bootsel cmd to switch mode
  9. support uEnv.txt to fatload script.bin & uImage
  10. support uEnv.txt to set video 1080P & 720P & 480P …
  11. support power max. up to 2.5A ~ for DC-IN.
  12. support GPU PowerVR SGX544MP
  13. with glmark2-es2 gpu demo
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjbFBDZUFHS25QV2s/view?usp=sharing
MD5: 108c15cad8edb59ae78255642d99dac7
Just tried this image, it is still suffering from the problem with a basic load around 1 (https://github.com/BPI-SINOVOIP/BPI-M3-bsp/issues/3).
How it’s installed ? Of sd or Directly on EMMC ?
both is support. you can burn to SD card or burn it to emmc.
could you provide a http link to dow? sth wrong you know it.
There is an incompatible JNA native library installed on this system:pensive:
how do i fix it.:sob:
How do I change the resolution? I need any standard non TV resolution 1280x1024 would be the best way. Changing modes in uEnv.txt does not help.
Any suggestions?
Best regards Frank
So to be clear, this has Power SGX544MP drivers available? Since the older versions all seem to have Broadcom drivers.
LOL! ‘To be clear’…
They included the OpenGLES drivers they got from Imagination and the only bundled application that can benefit from is glmark2-es2 (not so surprisingly). Don’t forget to adjust HDMI resolution to the lowest possible value otherwise benchmark scores don’t look that good any more. And feel free to post your experiences when you try out ‘chromium-browser --use-gl=egl’ for example (every result is valid, either the error messages you get or missing acceleration)
Hey, and think positive!
Thats all I needed to know, I don’t use bundled applications I write my own, all I need are the drivers
See, you can be helpful sometimes!
How can I burn it to EMMC?
Normally the vendor would provide an image that can be flashed using PhoenixSuit over USB to the eMMC (or with Phoenix Card to SD card). But guess what: You bought a product that receives zero support so you have to flash the image first to SD card and then booting from the card you flash the image a second time to eMMC.
More details? What? How? Please.
http://forum.banana-pi.org/search?q=burn%20to%20emmc
And please don’t ask me how I created the URL above. Like in every other forum on this planet there’s a search functionality provided. Why not using it?
here you find a step by step how to
I can confirm a glmark2 of ~250 (720 & 1080P) :slight_smile: as expected from berryboot-image. glxgears runs with ~30 fps as seen before.
Could not easily change resolution to 1080P, neither with uEnv.txt nor there is a working image for 1080P for bpi-bootsel.:grimacing: Instead same procedure as it is every year: build bsp from github and patch…
(headphone sound issue also still there)
not use glxgears,use es2gears from mesa-utils-extra package and get 400fps
Thx, I can get ~500 fps with this benchmark:
It does work but you have to fix uEnv.txt first. Close to unbelievable but they simply refuse to fix their mistakes. They spend time on trying to improve things, they provide packages, they do NOT test anything, write wrong documentation. Time wasted on the vendor’s side just to again waste time on the customer’s side since it’s not working as expected.
Good news: All you need is a single letter ‘t’: BPI-M3 new image:bpi-m3 Ubuntu 16.04 Beta Mate
