BPI-M3 Detailed tecnical data
Hello everybody!
I’m looking for detailed data sheets what to expect from the hardware. I have to compare the Banana Pi M3 to the Raspberry Pi 3 for a topic at work.
The usual “GPIO compatible to Raspberry Pi 2B” is not good enough, but I can’t find anything specific about the technical data anywhere. I want to know:
  • How many SPI interfaces, how many CS on these SPI interfaces?
  • Is CAN still supported or just on the Banana Pi M1
  • How many UART interfaces can be used
  • Exact Pinout with alternate functions
  • and everything else I can get…
Further I would like to know the best OS system.
Thanks in advance for all the answers. :slight_smile: I need to be sure that all the things I need are supported before I order a bunch of devices… :wink:
Ephi
read these three threads first…
all spec:
https://bananapi.gitbooks.io/bpi-m3/content/index.html
CAN not support on BPI-M3
Not as detailed as I hoped, but it will have to do. Thanks!
Yes, it’s obvious that you can’t support BPI-M3 and none of your other products. :frowning:
Was a bit funny, but not your fault.
CAN = CAN-Bus (Controller Area Network)
