How should I know that specific question without a research? You are the one who needs this and you will need to investigate. Best chance is not a copy / paste operation.
Support goes this way:
First question is hw related. Yes, I2C works, but to drive a specific LCD … second question is partially hw Debian is compatible with Debian. But if wireless works simultaneously … not OOB. You need to patch a driver. And no, I can’t help you get it done.
Hi again. So I have got the Bpi M2 Zero running with Armbian and Armbian itself looks very good so far!
I have a custom overlay for my touch screen which worked with the Rpi, which you can see below. I have added the “compatible” strings.
Presumably, I will need to get the drivers also and add them to the device? This would include: the Goodix driver; i2c-gpio; polytouch?; (rpi_backlight I don’t actually need as I will control it from Python); what about dpi18?
How straightforward is moving everything over (of course, everything is easy when you know ;)? Is it a case of tweaking a few things or will it require full driver re-writes? Thanks
