I got 2 BPI-M2-Zero boards, both with the same problem. I can’t get a keyboard to work. Lights never even flash, no capslock etc.
No power to the mouse either. Both boards boot fine but I can’t go anywhere from there.
I’ve tried 3 different keyboards. All of which work on my raspberry pi zero w.
I’ve tried the latest armbians:
Armbian_23.5.2_Bananapim2zero_jammy_current_6.1.30.img
Armbian_23.5.2_Bananapim2zero_bookworm_current_6.1.30.img
No your boards are not bad.
I had the same problem with the same image versions. Apperently USB is not working of this armbian version.
I ended up using the UBUNTU variant as seen on the wiki-pages: https://wiki.banana-pi.org/Banana_Pi_BPI-M2_ZERO#Armbian
armbian disable microusb host mode since 5.17, you can apply this patch m2zero_armbian_6.x_enable_otg_host.patch (5.0 KB) and build armbian image by yourself to enable otg host mode.
I’m going to reply just in case someone else hits this.The bana-pi’s usb is kind of sensitive.
I had a micro usb to usb-C adaptor and a usb-C to standard to plug in the keyboard. (aka 2 daisy-chained adaptors)
This setup worked on my pc and the raspberry pi zero w but NOT the banana-pi. I think it’s not as fault tolerant. I even did a self-made adaptor that worked everywhere but the banana-pi.
It’s only 6$ for two of the single adaptors so if anyone is having trouble, it’s well worth it.
Sorry i just dont understand so the BP m2 zero worked only with the adapters you linked and you didnt have to change OS or anything else??
Thanks in advance.
Yes, exactly. I had other adaptors that worked with the R-pie but not the M2-zero.
I was shocked when the one I listed worked. I used the two mainline distros I listed above and they both worked.
