Bpi m2 zero armbian works with max screen resolution and have glitches on the screen.
How cat I fix it ?
I now that I can change screen resolution to 720p and it must fix, but how change screen resolution on bpi m2 zero with latest armbian?
Instruction from wiki not working.
Nobody can help you as description of your problem contains no useful information. Try this way: https://www.armbian.com/bugs
main question is how to change kernel resolution to 1280x720p ? no need to check hdmi monitor resolution, need to set 1280x720p.
To change kernel resulotion, add
video=1280x720@60
To the cmdline parameters of the kernel
thanks, thats work!
need to add this parameter to /boot/armbianEnv.txt
extraargs=video=1280x720@60
