May 6, 2016, 9:37am
2016-05-05-debian-8-jessie-lite-bpi-m2p_beta-sd-emmc.img.zip
BPI-M2P kernel 3.4
username & password: pi/bananapi , root/bananapi
support HDMI 1080P & 720P(default)
support GMAC
support WIFI
support bpi-bootsel cmd can switch to (bpi-m3 & bpi-m2 & bpi-m2p)
support uEnv.txt to fatload script.bin & uImage
support uEnv.txt to set video 1080P & 720P & 480P …
fix rootmydevice issue
based on armbian rootfs, thanks for armbian
Google Drive:
https://drive.google.com/file/d/0B_YnvHgh2rwjQ1g5SG03bG9YYzg/view?usp=sharing
MD5: 09bc4970b824e1c938b1b0b53604633e
how to use “bootsel” commond let this image working on BPI-M3:
1,use bootsel :
2, run it on BPI-M3:
Thanks for the image!
Is there some documentation about how this image was created?
May 12, 2016, 4:09am
3
what are you want to do . or you want to add somethine ,just tell us , we can add for you. are you know how to build a image. or you just want change application or need to change kernel.
May 16, 2016, 7:15am
4
if you have add your function on this image . and want to build yourself image .it is easy to do this .
1, download Win32DiskImager and install to your PC.
download link: https://sourceforge.net/projects/win32diskimager/
2, use Win32DiskImager to read all from your SD.
3,change file name to : xxxxx .img , so you can burn to other SD or EMMC , if boot ok .success.
