BPI-F3 not booting
Hi, I have just received a new BPI-F3 and I tried to follow the instructions to flash it.
First, I used “dd” on Linux to write the bianbu*.img image to the SD card, then I’ve put the card into the reader and restarted the board. I’m also connected to the serial and all I see is:
  sys: 0x2
  try sd...
  bm:3
  j...
  U-Boot SPL 2022.10spacemit (May 25 2024 - 04:01:33 +0000)
The red and green LEDs are on and there is no signal on HDMI.
Then I tried to flash the eMMC via Titantools using the bianbu-23.10-nas-k1-v1.0rc3-release-20240525131412.zip image. I’ve put the board in flashing mode by pressing the FDL button at startup. The tool seems to work initial, but then it times out with error:
  [info] ---》开始刷机
  [info] 执行 fastboot getvar version-brom
  [info] 1.0
  [info] 执行 fastboot stage factory/FSBL.bin
  [info] 002cae0
  [info] 执行 fastboot continue
  [info] 执行 fastboot stage u-boot.itb
  [info] 刷机失败!
  [error] 【错误码】 20007
  [error] 【错误原因】Fastboot执行失败
  [error] 【详细原因】Fastboot Exception Could not send data to [5, 2, 1, 3] (timeout 30000ms): LIBUSB_ERROR_TIMEOUT [-7]
The serial shows:
  fastboot_handle_command: version-brom
  usb_tx_bytes : len= 65 pBuf= 0xc083fe88
  usb_rx_bytes : len= 4096 pBuf= 0xc0838720
  SETUP: 0x80 0x6 0x300
  SETUP: 0x80 0x6 0x30a
  fastboot_handle_command: 0002cae0
  Starting download of 183008 bytes
  usb_rx_bytes : len= 183008 pBuf= 0xc0800000
  fastboot_handle_command: continue
  j...
Anybody knows what is the problem?
Have you another SD card ?
I’ve had different results burning images. Try using Balena Etcher and let it do the verify after write.
Had a lot of issues with SD cards, they were really my fault they were so old they were on their way out. I bough some new ones and have not had a problem.
Also had issues burning with the raspberry pi imager compared to Balena. With my new SD cards I don’t have issues now.
Franco
Beside checking the sd card is not corrupted, maybe make sure you are powering the board with 12V. I used many SD and never had problems, but I’m using a 18W and 30W PD hub/charger.
I tried two different SD cards, one of which is new, and I get the same result with both.
About the power, I’ve tried both with a 12V/2A power supply and with a USB cable connected to the docking station. I’ll try to see if I can find something better.
BTW, I noticed that the “Getting started” page has a section “Solution for 2G DDR version unable to start” where it suggests to update the “ddr_cs_num” value to 1 in the eeprom via titantools. Mine is a 2GB version and so probably it needs the change. However, I haven’t been able to set the value until now, as the tool always reports a timeout.
Hi, When you do your DD command do you put a status=progress at the end? Have you tried with Balena Etcher?
Franco
Thanks to all for the suggestions, I have made some progress finally.
I’ve used a real Windows 11 machine (instead of a Windows VM on Linux with USB passthrough) and I was able to change the “ddr_cs_num” eeprom value to 1 via titan tools (as my board has only 2GB of RAM). I was also able to flash the bianbu image on the eMMC and now it boots properly.
I’m still not able to boot from the SD, as u-boot reports that no card is inserted (I tried two different cards):
=> mmc info
MMC: no card present
mmc_init: -123, time 1
I tried flashing both with Balena Etcher and dd (with status=progress), but it seems the board isn’t even detecting the card. I will investigate more.
What you could try since you have access to the debug console is to boot via TFTP. I already have the commands written out so you can just copy and paste them in to your console.
Change the IP addresses obviously for your system.
setenv ipaddr 192.168.0.5 setenv serverip 192.168.0.2 setenv gatewayip 192.168.0.1 setenv netmask 255.255.252.0 tftpboot uImage bootm 0x80600000 bootm 0x80200000 0x82200000 0x82200000 setenv ipaddr 10.196.157.189 setenv serverip 10.11.143.218 setenv gatewayip 10.196.156.1 setenv netmask 255.255.252.0 enx4865ee115d98 sudo screen -L /dev/ttyUSB1 115200
You can find more info on my github here. BPI-F3/notes/ubootcommands at main · rcman/BPI-F3 · GitHub
Franco
here is the finished bootloader boot-20240727.tar.xz and here is the recording.
Also env_k1-x.txt
Okay let’s step back. Where are you downloading the image and which image are you issuing?
You should be downloading it from the link below.
Once you burn it to micro sd card it should boot. Make sure you download the name with img in the name.
Franco
there is a ready-made image with everything configured. there is a build system
here are the settings: one, two
Hi, after all the suggestion, the SD is not working yet. I am going to send the board back because it seems a HW problem.
Hi, Sorry to hear that, stupid question. When you insert the Micro SD card is does click when pushed in and bounce back from the spring?
Sorry I have to ask that question. Franco
Hello, I’m having a similar problem with my BPI-F3. While trying to write the emmc with the titanflash utility on Windows, I accidentally erased the eeprom. Now it will only boot an armbian image. With all other images, the green led remains lit and no activity. How could I recover the board? I tried to write the emmc with utility again, and after decompressing the image, the utility states missing files: fastboot.yaml, partition_universal.json and some other, for which I have no template. Any help would be appreciated.
you can try to boot from armbian or irradium download the bootloader boot-20241214.tar.xz and write it to eMMC:
dd if=u-boot-bpi-f3-header-sd-0k.img of=/dev/mmcblk2 bs=512 status=noxfer
dd if=FSBL.bin of=/dev/mmcblk2 bs=512 seek=512 status=noxfer
dd if=fw_dynamic.itb of=/dev/mmcblk2 bs=512 seek=1280 status=noxfer
dd if=u-boot.itb of=/dev/mmcblk2 bs=512 seek=2048 status=noxfer
or write bianbu image to eMMC
right now it’s not booting at all. I will try to get a uart->usb adapter tomorrow to see the debug output. The armbian image halts during boot so I have no access to a console.
you can simply switch to boot from the SDcard
I am trying to boot from sdcard. I have 4 different cards which I tried.
try the irradium image
tried it, does not boot. Maybe you could help with a compressed directory structure like this:
so I can try and flash it with titantools. I wrote 2 irradium images:
irradium-3.7-riscv64-core-banana_pi_f3-6.6.65-build-20241214.img.zst and irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.65-build-20241214.img.zst, extracted with zstd and written to SD with balenaEtcher.
The boot switches are set as factory default to boot from SD (all off).
Thanks for your help.
LE: Bianbu 2.0.4 desktop and cli boot successfully from emmc, not SD card but there is no 5V for USB and peripherals after kernel loading. Armbian “2024-06-14-Armbian-bpi-SpacemiT_24.5.0-trunk_Bananapif3_sid_legacy_6.1.15.img” boots from sd card and displays: ldo5: disabling and halts. Still no 5V for usb. Could it be a faulty board? The usb’s worked when I first started it with Fedora and Armbian.
