Irradium (based on crux linux) SpacemiT Banana Pi BPI-F3 K1 riscv64
installation README.TXT
kernel 6.6.50
update v2.0
added the ability to overclock the CPU to 1.8 GHz, for this in the file /boot/uEnv.txt you need to remove the # symbol before [email protected], it should turn out [email protected]
irradium-3.7-riscv64-core-banana_pi_f3-6.6.50-build-20241023.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.6.50-build-20241023.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.50-build-20241023.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.50-build-20241023.img.zst.sha256
kernel 6.6.50
update v2.0.1
irradium-3.7-riscv64-core-banana_pi_f3-6.6.50-build-20241102.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.6.50-build-20241102.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.50-build-20241102.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.50-build-20241102.img.zst.sha256
kernel 6.6.50
update v2.0.2
mirror 1, mirror 2, mirror 3
irradium-3.7-riscv64-core-banana_pi_f3-6.6.50-build-20241114.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.6.50-build-20241114.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.50-build-20241114.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.50-build-20241114.img.zst.sha256
kernel 6.6.63
update v2.0.2
irradium-3.7-riscv64-core-banana_pi_f3-6.6.63-build-20241123.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.6.63-build-20241123.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.63-build-20241123.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.63-build-20241123.img.zst.sha256
new testing of qt5 5.15.16 build with overclocked 1.8ghz processor on the board
lichee pi 3a spacemit k1
real    487m5.748s
user    3327m40.223s
sys     191m46.915s
lichee pi 4a thead th1520
real    631m13.474s
user    2200m37.014s
sys     174m29.583s
kernel 6.6.65
update v2.0.4
for overclocking 1.8ghz you need to enable boost:
echo 1 > /sys/devices/system/cpu/cpufreq/boost
irradium-3.7-riscv64-core-banana_pi_f3-6.6.65-build-20241214.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.6.65-build-20241214.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.65-build-20241214.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.65-build-20241214.img.zst.sha256
kernel 6.6.72
update v2.0.4
for overclocking 1.8ghz you need to enable boost: echo 1 > /sys/devices/system/cpu/cpufreq/boost
irradium-3.7-riscv64-core-banana_pi_f3-6.6.72-build-20250118.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.6.72-build-20250118.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.72-build-20250118.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.6.72-build-20250118.img.zst.sha256
kernel 6.13.0-rc7
echo userspace > /sys/devices/system/cpu/cpufreq/policy0/scaling_governor
echo 1800000 > /sys/devices/system/cpu/cpufreq/policy0/scaling_setspeed
irradium-3.7-riscv64-core-banana_pi_f3-6.13.0-rc7-build-20250119.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.13.0-rc7-build-20250119.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.13.0-rc7-build-20250119.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.13.0-rc7-build-20250119.img.zst.sha256
[    0.000000] Linux version 6.13.0-rc7+ (root@firefly-rk3399) (riscv64-unknown-linux-gnu-gcc (g2ee5e430018) 12.2.0, GNU ld (GNU Binutils) 2.40.0.20230214) #1 SMP PREEMPT Sun Jan 19 10:11:03 EET 2025
[    0.000000] Machine model: BananaPi BPI-F3
[    0.000000] SBI specification v1.0 detected
[    0.000000] SBI implementation ID=0x1 Version=0x10003
[    0.000000] SBI IPI extension detected
[    0.000000] SBI RFENCE extension detected
[    0.000000] earlycon: sbi0 at I/O port 0x0 (options '')
[    0.000000] printk: legacy bootconsole [sbi0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000065600000, size 384 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000065600000..0x000000007d5fffff (393216 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x000000007f000000..0x000000007fffffff (16384 KiB) map non-reusable framebuffer@7f000000
[    0.000000] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable mmode_resv0@0
[    0.000000] OF: reserved mem: 0x00000000c0800000..0x00000000c083ffff (256 KiB) nomap non-reusable mem@c0800000
[    0.000000] OF: reserved mem: 0x0000000030000000..0x00000000301fffff (2048 KiB) nomap non-reusable mem@30000000
[    0.000000] OF: reserved mem: 0x0000000030200000..0x0000000030202fff (12 KiB) nomap non-reusable vdev0vring0@30200000
[    0.000000] OF: reserved mem: 0x0000000030203000..0x0000000030205fff (12 KiB) nomap non-reusable vdev0vring1@30203000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000030206000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@30206000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000030206000..0x00000000302fbfff (984 KiB) nomap non-reusable vdev0buffer@30206000
[    0.000000] OF: reserved mem: 0x00000000302fc000..0x00000000302fffff (16 KiB) nomap non-reusable rsc_table@302fc000
[    0.000000] OF: reserved mem: 0x0000000030300000..0x000000003033ffff (256 KiB) nomap non-reusable rcpu_mem_snapshots@30300000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000002ff40000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node dpu_reserved@2ff40000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000002ff40000..0x000000002fffffff (768 KiB) nomap non-reusable dpu_reserved@2ff40000
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000017fffffff]
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
[    0.000000]   node   0: [mem 0x0000000000080000-0x000000002ff3ffff]
[    0.000000]   node   0: [mem 0x000000002ff40000-0x000000003033ffff]
[    0.000000]   node   0: [mem 0x0000000030340000-0x000000007fffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000017fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000017fffffff]
[    0.000000] On node 0, zone Normal: 524288 pages in unavailable ranges
[    0.000000] SBI HSM extension detected
[    0.000000] riscv: base ISA extensions acdfimv
[    0.000000] riscv: ELF capabilities acdfimv
[    0.000000] Ticket spinlock: enabled
[    0.000000] percpu: Embedded 31 pages/cpu s86040 r8192 d32744 u126976
[    0.000000] pcpu-alloc: s86040 r8192 d32744 u126976 alloc=31*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Kernel command line: earlycon=sbi earlyprintk console=tty1 console=ttyS0,115200 loglevel=8 clk_ignore_unused swiotlb=65536 rdinit=/init root=/dev/mmcblk0p2 rootwait rootfstype=ext4 board=bpi-f3
[    0.000000] Unknown kernel command line parameters "board=bpi-f3", will be passed to user space.
[    0.000000] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1048576
[    0.000000] software IO TLB: area num 8.
[    0.000000] software IO TLB: mapped [mem 0x000000005d600000-0x0000000065600000] (128MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.000000] riscv-intc: 64 local interrupts mapped
[    0.000000] riscv-plic: interrupt-controller@e0000000: mapped 159 interrupts with 8 handlers for 16 contexts.
[    0.000000] riscv: providing IPIs using SBI IPI extension
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] riscv-timer: Timer interrupt in S-mode is available via sstc extension
[    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008496] Console: colour dummy device 80x25
[    0.012635] printk: legacy console [tty1] enabled
[    0.018023] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.027709] pid_max: default: 32768 minimum: 301
[    0.032575] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.039877] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.060047] riscv: ELF compat mode unsupported
[    0.060083] ASID allocator using 16 bits (65536 entries)
[    0.067191] rcu: Hierarchical SRCU implementation.
[    0.071933] rcu: 	Max phase no-delay instances is 1000.
[    0.077439] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.085869] EFI services will not be available.
[    0.090504] smp: Bringing up secondary CPUs ...
[    0.099850] smp: Brought up 1 node, 8 CPUs
[    0.102280] Memory: 3490764K/4194304K available (17608K kernel code, 6940K rwdata, 8192K rodata, 2394K init, 563K bss, 302972K reserved, 393216K cma-reserved)
[    0.117365] devtmpfs: initialized
[    0.131559] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.138514] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.150529] pinctrl core: initialized pinctrl subsystem
[    0.153722] DMI not present or invalid.
[    0.157327] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.163951] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.170329] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.178452] display class register
[    0.181726] thermal_sys: Registered thermal governor 'step_wise'
[    0.181768] cpuidle: using governor menu
[    0.219699] cpu1: Ratio of byte access time to unaligned word access is 2.05, unaligned accesses are fast
[    0.219699] cpu3: Ratio of byte access time to unaligned word access is 2.40, unaligned accesses are fast
[    0.219699] cpu2: Ratio of byte access time to unaligned word access is 2.27, unaligned accesses are fast
[    0.219702] cpu4: Ratio of byte access time to unaligned word access is 1.54, unaligned accesses are fast
[    0.219702] cpu6: Ratio of byte access time to unaligned word access is 1.57, unaligned accesses are fast
[    0.219702] cpu7: Ratio of byte access time to unaligned word access is 1.51, unaligned accesses are fast
[    0.219702] cpu5: Ratio of byte access time to unaligned word access is 1.71, unaligned accesses are fast
[    0.307775] cpu0: Ratio of byte access time to unaligned word access is 10.12, unaligned accesses are fast
[    0.314617] The real ratio of byte access time to unaligned word access should refer to the value of CPU0
[    0.324233] Cpu0 unaligned access is more efficient than nonboot cores, because of system bandwidth preemption.
[    0.334380] Nonboot cpus' unaligned access ratio measured simultaneously, but cpu0's measure is separately
[    0.351216] /soc: Fixed dependency cycle(s) with /soc/hdmi@C0400500
[    0.356856] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc
[    0.361011] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc/pinctrl@d401e000/hdmi_0_grp
[    0.369766] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc/power-management@0/power-controller
[    0.379227] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc/reset-controller@d4050000
[    0.387821] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc/clock-controller@d4050000
[    0.396421] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc/interrupt-controller@e0000000
[    0.406949] /soc/pinctrl@d401e000: Fixed dependency cycle(s) with /soc/interrupt-controller@e0000000
[    0.414581] /soc/pinctrl@d401e000: Fixed dependency cycle(s) with /soc/reset-controller@d4050000
[    0.423421] /soc/pinctrl@d401e000: Fixed dependency cycle(s) with /soc/clock-controller@d4050000
[    0.433921] pinctrl-single d401e000.pinctrl: 148 pins, size 592
[    0.445881] /soc/pcie@ca400000: Fixed dependency cycle(s) with /soc/pcie@ca400000/interrupt-controller@0
[    0.452937] /soc/pcie@ca800000: Fixed dependency cycle(s) with /soc/pcie@ca800000/interrupt-controller@0
[    0.464546] /soc: Fixed dependency cycle(s) with /soc/hdmi@C0400500
[    0.468516] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc
[    0.474849] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc/reset-controller@d4050000
[    0.483365] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc/clock-controller@d4050000
[    0.491957] /soc/hdmi@C0400500: Fixed dependency cycle(s) with /soc/interrupt-controller@e0000000
[    0.506306] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.510295] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.516598] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.523449] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.529784] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.536641] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.610883] raid6: int64x8  gen()  1031 MB/s
[    0.678932] raid6: int64x4  gen()  1574 MB/s
[    0.746995] raid6: int64x2  gen()  1653 MB/s
[    0.815035] raid6: int64x1  gen()  1371 MB/s
[    0.816455] raid6: using algorithm int64x2 gen() 1653 MB/s
[    0.887084] raid6: .... xor() 838 MB/s, rmw enabled
[    0.889102] raid6: using intx1 recovery algorithm
[    0.894469] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.906025] mmp-pdma d4000000.pdma: PM domain power-domain@SPT_PD_BUS will not be powered off
[    0.912360] SCSI subsystem initialized
[    0.915795] libata version 3.00 loaded.
[    0.919600] usbcore: registered new interface driver usbfs
[    0.925025] usbcore: registered new interface driver hub
[    0.930412] usbcore: registered new device driver usb
[    0.937823] /soc/i2c@d401d800/spm8821@41: Fixed dependency cycle(s) with /soc/i2c@d401d800/spm8821@41/regulators/DCDC_REG5
[    0.962769] spacemit-regulator spacemit-regulator@spm8821: DMA mask not set
[    1.014572] /soc/i2c@d401d800/spm8821@41: Fixed dependency cycle(s) with /soc/i2c@d401d800/spm8821@41/regulators
[    1.022975] mc: Linux media interface: v0.10
[    1.026357] videodev: Linux video capture interface: v2.00
[    1.031861] pps_core: LinuxPPS API ver. 1 registered
[    1.036862] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    1.046081] PTP clock support registered
[    1.050789] Advanced Linux Sound Architecture Driver Initialized.
[    1.056808] Bluetooth: Core ver 2.22
[    1.059881] NET: Registered PF_BLUETOOTH protocol family
[    1.065248] Bluetooth: HCI device and connection manager initialized
[    1.071666] Bluetooth: HCI socket layer initialized
[    1.076615] Bluetooth: L2CAP socket layer initialized
[    1.081739] Bluetooth: SCO socket layer initialized
[    1.087036] vgaarb: loaded
[    1.089977] clocksource: Switched to clocksource riscv_clocksource
[    1.096156] VFS: Disk quotas dquot_6.6.0
[    1.099769] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.117321] NET: Registered PF_INET protocol family
[    1.119596] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.131042] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.136781] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.144564] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.152690] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    1.161064] TCP: Hash tables configured (established 32768 bind 32768)
[    1.166776] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    1.173572] UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    1.181015] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.187079] RPC: Registered named UNIX socket transport module.
[    1.192475] RPC: Registered udp transport module.
[    1.197233] RPC: Registered tcp transport module.
[    1.202006] RPC: Registered tcp-with-tls transport module.
[    1.207561] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.215033] PCI: CLS 0 bytes, default 64
[    1.218733] Unpacking initramfs...
[    1.222901] Initialise system trusted keyrings
[    1.226427] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.233405] NFS: Registering the id_resolver key type
[    1.237765] Key type id_resolver registered
[    1.241974] Key type id_legacy registered
[    1.246106] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.252838] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.261888] Key type cifs.idmap registered
[    1.264503] ntfs3: Enabled Linux POSIX ACLs support
[    1.269410] ntfs3: Read-only LZX/Xpress compression included
[    1.275190] fuse: init (API version 7.41)
[    1.279787] SGI XFS with ACLs, security attributes, quota, no debug enabled
[    1.349926] NET: Registered PF_ALG protocol family
[    1.351952] xor: measuring software checksum speed
[    1.357501]    8regs           :  4716 MB/sec
[    1.361939]    32regs          :  4532 MB/sec
[    1.366234]    rvv             :  5501 MB/sec
[    1.370057] xor: using function: rvv (5501 MB/sec)
[    1.374929] async_tx: api initialized (async)
[    1.379351] Key type asymmetric registered
[    1.383523] Asymmetric key parser 'x509' registered
[    1.388924] io scheduler mq-deadline registered
[    1.393120] io scheduler kyber registered
[    1.395190] Freeing initrd memory: 6288K
[    1.397188] io scheduler bfq registered
[    1.408404] spacemit-pmic-pinctrl spacemit-pinctrl@spm8821: DMA mask not set
[    1.419751] ledtrig-cpu: registered to indicate activity on CPUs
[    1.423661] k1x-dwc-pcie ca400000.pcie: has no power on gpio.
[    1.431000] k1x-dwc-pcie ca400000.pcie: host bridge /soc/pcie@ca400000 ranges:
[    1.436074] k1x-dwc-pcie ca400000.pcie:       IO 0x009f002000..0x009f101fff -> 0x009f002000
[    1.444489] k1x-dwc-pcie ca400000.pcie:      MEM 0x0090000000..0x009effffff -> 0x0090000000
[    1.552994] k1x-dwc-pcie ca400000.pcie: iATU: unroll T, 8 ob, 8 ib, align 4K, limit 4G
[    2.517984] k1x-dwc-pcie ca400000.pcie: Phy link never came up
[    2.521483] k1x-dwc-pcie ca400000.pcie: PCI host bridge to bus 0001:00
[    2.527626] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.533127] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x9f002000-0x9f101fff])
[    2.542770] pci_bus 0001:00: root bus resource [mem 0x90000000-0x9effffff]
[    2.549798] pci 0001:00:00.0: [201f:0001] type 01 class 0x060400 PCIe Root Port
[    2.557100] pci 0001:00:00.0: BAR 0 [mem 0x00000000-0x000fffff]
[    2.563073] pci 0001:00:00.0: BAR 1 [mem 0x00000000-0x000fffff]
[    2.569062] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    2.574371] pci 0001:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.580522] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.587381] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    2.595247] pci 0001:00:00.0: supports D1
[    2.599268] pci 0001:00:00.0: PME# supported from D0 D1 D3hot D3cold
[    2.610300] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    2.614146] pci 0001:00:00.0: BAR 0 [mem 0x90000000-0x900fffff]: assigned
[    2.620952] pci 0001:00:00.0: BAR 1 [mem 0x90100000-0x901fffff]: assigned
[    2.627806] pci 0001:00:00.0: PCI bridge to [bus 01]
[    2.632844] pci_bus 0001:00: resource 4 [io  0x0000-0xfffff]
[    2.638562] pci_bus 0001:00: resource 5 [mem 0x90000000-0x9effffff]
[    2.647081] pcieport 0001:00:00.0: PME: Signaling with IRQ 65
[    2.651145] pcieport 0001:00:00.0: AER: enabled with IRQ 65
[    2.657096] k1x-dwc-pcie ca800000.pcie: has no power on gpio.
[    2.664443] k1x-dwc-pcie ca800000.pcie: host bridge /soc/pcie@ca800000 ranges:
[    2.669498] k1x-dwc-pcie ca800000.pcie:       IO 0x00b7002000..0x00b7101fff -> 0x00b7002000
[    2.677921] k1x-dwc-pcie ca800000.pcie:      MEM 0x00a0000000..0x00afffffff -> 0x00a0000000
[    2.686335] k1x-dwc-pcie ca800000.pcie:      MEM 0x00b0000000..0x00b6ffffff -> 0x00b0000000
[    2.794832] k1x-dwc-pcie ca800000.pcie: iATU: unroll T, 8 ob, 8 ib, align 4K, limit 4G
[    3.757982] k1x-dwc-pcie ca800000.pcie: Phy link never came up
[    3.761121] k1x-dwc-pcie ca800000.pcie: PCI host bridge to bus 0002:00
[    3.767590] pci_bus 0002:00: root bus resource [bus 00-ff]
[    3.773125] pci_bus 0002:00: root bus resource [io  0x100000-0x1fffff] (bus address [0xb7002000-0xb7101fff])
[    3.783022] pci_bus 0002:00: root bus resource [mem 0xa0000000-0xafffffff pref]
[    3.790398] pci_bus 0002:00: root bus resource [mem 0xb0000000-0xb6ffffff]
[    3.797429] pci 0002:00:00.0: [201f:0001] type 01 class 0x060400 PCIe Root Port
[    3.804735] pci 0002:00:00.0: BAR 0 [mem 0x00000000-0x000fffff]
[    3.810710] pci 0002:00:00.0: BAR 1 [mem 0x00000000-0x000fffff]
[    3.816700] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
[    3.821995] pci 0002:00:00.0:   bridge window [io  0x0000-0x0fff]
[    3.828156] pci 0002:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    3.835017] pci 0002:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    3.842884] pci 0002:00:00.0: supports D1
[    3.846906] pci 0002:00:00.0: PME# supported from D0 D1 D3hot D3cold
[    3.857947] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[    3.861811] pci 0002:00:00.0: BAR 0 [mem 0xb0000000-0xb00fffff]: assigned
[    3.868642] pci 0002:00:00.0: BAR 1 [mem 0xb0100000-0xb01fffff]: assigned
[    3.875502] pci 0002:00:00.0: PCI bridge to [bus 01]
[    3.880532] pci_bus 0002:00: resource 4 [io  0x100000-0x1fffff]
[    3.886582] pci_bus 0002:00: resource 5 [mem 0xa0000000-0xafffffff pref]
[    3.893287] pci_bus 0002:00: resource 6 [mem 0xb0000000-0xb6ffffff]
[    3.901777] pcieport 0002:00:00.0: PME: Signaling with IRQ 69
[    3.905880] pcieport 0002:00:00.0: AER: enabled with IRQ 69
[    3.969695] d4017000.serial: ttyS0 at MMIO 0xd4017000 (irq = 73, base_baud = 921250) is a UART1
[    3.975763] printk: legacy console [ttyS0] enabled
[    3.985310] printk: legacy bootconsole [sbi0] disabled
[    3.999126] d4017100.uart: ttyS1 at MMIO 0xd4017100 (irq = 74, base_baud = 3600000) is a UART2
[    4.008171] serial serial0: tty port ttyS1 registered
[    4.033214] PVR_K:  1: Read BVNC 36.29.52.182 from HW device registers
[    4.040002] PVR_K:  1: RGX Device registered BVNC 36.29.52.182 with 1 core in the system
[    4.049137] [drm] Initialized pvr 24.2.6603887 for cac00000.imggpu on minor 0
[    4.064567] loop: module loaded
[    4.070501] Rounding down aligned max_sectors from 4294967295 to 4294967288
[    4.077829] db_root: cannot open: /etc/target
[    4.083708] k1x-qspi d420c000.spi: config mfp for cs:[0]
[    4.089324] k1x-qspi d420c000.spi: AHB buf size: 512
[    4.094937] spi-nor spi4.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[    4.101994] k1x-qspi d420c000.spi: Runtime PM usage count underflow!
[    4.109605] CAN device driver interface
[    4.364963] usbcore: registered new interface driver cdc_ether
[    4.370979] usbcore: registered new interface driver cdc_subset
[    4.377002] usbcore: registered new interface driver zaurus
[    4.384413] spacemit-k1x-combphy c0b10000.phy: USB3 PHY init.
[    4.392473] mv-ehci mv-ehci1: Spacemit EHCI
[    4.396810] mv-ehci mv-ehci1: new USB bus registered, assigned bus number 1
[    4.404055] mv-ehci mv-ehci1: irq 81, io mem 0xc0980100
[    4.417992] mv-ehci mv-ehci1: USB 2.0 started, EHCI 1.00
[    4.424249] hub 1-0:1.0: USB hub found
[    4.428120] hub 1-0:1.0: 1 port detected
[    4.433326] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.438979] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.446952] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6d hci version 0x110 quirks 0x0000808000000090
[    4.456964] xhci-hcd xhci-hcd.0.auto: irq 80, io mem 0xc0a00000
[    4.463158] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.468764] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[    4.476541] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    4.483802] hub 2-0:1.0: USB hub found
[    4.487661] hub 2-0:1.0: 1 port detected
[    4.492010] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.500713] hub 3-0:1.0: USB hub found
[    4.504560] hub 3-0:1.0: 1 port detected
[    4.509177] usbcore: registered new interface driver uas
[    4.514758] usbcore: registered new interface driver usb-storage
[    4.521110] spacemit-usb3-hub soc:usb3hub@0: v1.0.2
[    4.541983] spacemit-usb3-hub soc:usb3hub@0: onboard usb hub driver probed, hub configured
[    4.550933] K1X_UDC: mv_udc_probe enter ...
[    4.555579] mv-udc mv-udc:  use 32bit DMA mask
[    4.560119] mv_udc: dqh size = 0x800  udc->ep_dqh_dma = 0x280b000
[    4.566863] mv-udc mv-udc: successful probe UDC device without clock gating.
[    4.574402] f_tcm: UAS support multiple cmds
[    4.579234] spacemit-pmic-pwrkey spacemit-pwrkey@spm8821: DMA mask not set
[    4.638714] input: spacemit pwrkey as /devices/platform/soc/d401d800.i2c/i2c-8/8-0041/spacemit-pwrkey@spm8821/input/input0
[    4.651102] spacemit-pmic-rtc spacemit-rtc@spm8821: DMA mask not set
[    4.684768] spacemit-pmic-rtc spacemit-rtc@spm8821: registered as rtc0
[    4.696717] spacemit-pmic-rtc spacemit-rtc@spm8821: setting system clock to 2000-01-01T11:56:06 UTC (946727766)
[    4.707935] i2c_dev: i2c /dev entries driver
[    4.715233] MVX dev: Linlon v5276 identified. cores=2, nlsid=4, id=0, fuse=00000000, hw_id=00005276, hw_rev=00000050
[    4.727251] d420a000.csiphy begin to probe
[    4.731500] d420a000.csiphy probed
[    4.731616] d4206000.csiphy begin to probe
[    4.739258] d4206000.csiphy probed
[    4.740395] d420a000.ccic probed in k1x_ccic_probe
[    4.744747] d420a800.ccic probed in k1x_ccic_probe
[    4.750389] d4206000.ccic probed in k1x_ccic_probe
[    4.759543] acquire ccic0 ctrl dev succeed
[    4.768638] acquire ccic1 ctrl dev succeed
[    4.772803] acquire ccic2 ctrl dev succeed
[    4.783169] usbcore: registered new interface driver uvcvideo
[    4.793997] device-mapper: uevent: version 1.0.3
[    4.799032] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: [email protected]
[    4.808595] device-mapper: multipath round-robin: version 1.2.0 loaded
[    4.815250] device-mapper: multipath queue-length: version 0.2.0 loaded
[    4.821995] device-mapper: multipath service-time: version 0.3.0 loaded
[    4.828708] device-mapper: multipath historical-service-time: version 0.1.1 loaded
[    4.836468] Bluetooth: HCI UART driver ver 2.3
[    4.840998] Bluetooth: HCI UART protocol H4 registered
[    4.846286] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.857471] sdhci: Secure Digital Host Controller Interface driver
[    4.863768] sdhci: Copyright(c) Pierre Ossman
[    4.868152] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.874619] sdhci-spacemit d4280000.sdh: Got CD GPIO
[    4.916491] mmc0: SDHCI controller on d4280000.sdh [d4280000.sdh] using ADMA
[    4.950538] mmc1: SDHCI controller on d4280800.sdh [d4280800.sdh] using ADMA
[    4.957741] sdio: save sdio_host <- (____ptrval____)
[    4.995526] mmc0: set tx_delaycode: 95
[    5.000432] mmc0: pass window [0 20)
[    5.004196] mmc0: pass window [21 22)
[    5.014623] mmc0: pass window [79 243)
[    5.018584] mmc0: pass window [244 245)
[    5.022838] mmc0: pass window [255 256)
[    5.026817] mmc0: tuning done, use the firstly delay_code:160
[    5.033452] mmc0: new UHS-I speed SDR104 SDXC card at address 5048
[    5.040561] mmcblk0: mmc0:5048 SD64G 58.0 GiB
[    5.051361]  mmcblk0: p1 p2
[    5.088430] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[    5.095700] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[    5.102062] mmcblk2boot0: mmc2:0001 AJTD4R 4.00 MiB
[    5.108293] mmcblk2boot1: mmc2:0001 AJTD4R 4.00 MiB
[    5.114466] mmcblk2rpmb: mmc2:0001 AJTD4R 4.00 MiB, chardev (242:0)
[    5.120948] mmc2: SDHCI controller on d4281000.sdh [d4281000.sdh] using ADMA
[    5.130705] usbcore: registered new interface driver usbhid
[    5.136387] usbhid: USB HID core driver
[    5.141441] remoteproc remoteproc0: rcpu_rproc is available
[    5.150072] remoteproc remoteproc0: powering up rcpu_rproc
[    5.168067] remoteproc remoteproc0: Booting fw image esos.elf, size 562152
[    5.176661] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vdev0buffer@30206000
[    5.189567] virtio_rpmsg_bus virtio0: rpmsg host is online
[    5.195143] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
[    5.201998] remoteproc remoteproc0: remote processor rcpu_rproc is now up
[    5.209791] riscv-pmu-sbi: SBI PMU extension is available
[    5.215342] riscv-pmu-sbi: 16 firmware and 18 hardware counters
[    5.224157] es8326 2-0019: Can not read property hp-detect-gpio
[    5.230226] es8326 2-0019: Can not read property mic-detect-gpio
[    5.236321] es8326 2-0019: assuming static mclk
[    5.242239] xt_time: kernel timezone is -0000
[    5.246704] IPVS: Registered protocols (TCP, UDP)
[    5.251458] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[    5.259025] IPVS: ipvs loaded.
[    5.262136] IPVS: [rr] scheduler registered.
[    5.266585] Initializing XFRM netlink socket
[    5.271006] NET: Registered PF_INET6 protocol family
[    5.277295] Segment Routing with IPv6
[    5.281082] In-situ OAM (IOAM) with IPv6
[    5.285198] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    5.291869] NET: Registered PF_PACKET protocol family
[    5.297055] Bridge firewalling registered
[    5.301136] can: controller area network core
[    5.305579] NET: Registered PF_CAN protocol family
[    5.310443] can: raw protocol
[    5.313438] can: broadcast manager protocol
[    5.317694] can: netlink gateway - max_hops=1
[    5.322324] Bluetooth: RFCOMM TTY layer initialized
[    5.327284] Bluetooth: RFCOMM socket layer initialized
[    5.332490] Bluetooth: RFCOMM ver 1.11
[    5.336301] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.341679] Bluetooth: BNEP socket layer initialized
[    5.346719] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.352699] Bluetooth: HIDP socket layer initialized
[    5.357768] 8021q: 802.1Q VLAN Support v1.8
[    5.362091] Key type dns_resolver registered
[    5.377104] Loading compiled-in X.509 certificates
[    5.382040] usb 2-1: new high-speed USB device number 2 using xhci-hcd
[    5.390786] Btrfs loaded, zoned=no, fsverity=no
[    5.406244] suspend: SBI SUSP extension detected
[    5.413281] [drm] spacemit_dpu_bind()
[    5.417310] spacemit-dpu-drv soc:port@c0440000: assigned reserved memory node dpu_reserved@2ff40000
[    5.426953] [drm] dpu plane init ok
[    5.430509] spacemit-drm-drv c0440000.display-subsystem-hdmi: bound soc:port@c0440000 (ops dpu_component_ops)
[    5.440954] spacemit-drm-drv c0440000.display-subsystem-hdmi: bound c0400500.hdmi (ops spacemit_hdmi_ops)
[    5.450825] [drm] spacemit_hdmi_connector_detect() hdmi status connected
[    5.458145] [drm] Initialized spacemit 1.0.0 for c0440000.display-subsystem-hdmi on minor 1
[    5.466627] [drm] spacemit_hdmi_connector_detect() hdmi status connected
[    5.473413] [drm] spacemit_hdmi_get_edid_block() len 128
[    5.497928] [drm] spacemit_hdmi_get_edid_block() len 128
[    5.507750] [drm] spacemit_crtc_atomic_enable(power on)
[    5.507822] [drm] dpu_init
[    5.507857] [drm] spacemit_hdmi_encoder_enable()
[    5.507867] [drm] spacemit_hdmi_setup() id 0xa08501, hdmi 10bpc
[    5.508108] [drm] DPU type 0 id 2 Start!
[    5.524863] Console: switching to colour frame buffer device 240x67
[    5.571511] hub 2-1:1.0: USB hub found
[    5.573725] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] fb0: spacemitdrmfb frame buffer device
[    5.577755] hub 2-1:1.0: 5 ports detected
[    5.603121] spacemit-socinfo soc:socinfo@0: Spacemit: CPU[K1-6370] REV[A] DRO[127] Detected
[    5.612960] cam_inf:snr (cam_sensor_probe 1467): camera sensor begin to probed
[    5.621254] cam_inf:snr (cam_sensor_probe 1485): camera sensor0 probed
[    5.628564] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.643102] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.649707] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    5.657801] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    5.659300] clk: Not disabling unused clocks
[    5.666253] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[    5.677713] PM: genpd: Disabling unused power domains
[    5.682920] ALSA device list:
[    5.685954]   No soundcards found.
[    5.691244] Freeing unused kernel image (initmem) memory: 2392K
[    5.697367] Run /init as init process
[    5.701122]   with arguments:
[    5.704144]     /init
[    5.706469]   with environment:
[    5.709656]     HOME=/
[    5.712069]     TERM=linux
[    5.714825]     board=bpi-f3
[    5.811541] hub 3-1:1.0: USB hub found
[    5.817344] hub 3-1:1.0: 4 ports detected
[    5.865900] EXT4-fs (mmcblk0p2): mounted filesystem 32539e08-a5c0-4084-9f32-0932043d95e3 r/w without journal. Quota mode: none.
[    6.136391] udevd[218]: starting version 3.2.14
[    6.338024] usb 2-1.5: new high-speed USB device number 3 using xhci-hcd
[   11.682006] random: crng init done
[   11.716742] udevd[218]: specified group 'netdev' unknown
[   11.726460] udevd[221]: starting eudev-3.2.14
[   11.890508] cam clk[csi_func]: 624000000
[   11.890521] cam clk[csi_func]: 624000000
[   11.890609] cam clk[ccic4x_func]: 624000000
[   11.892122] cam clk[csi_func]: 624000000
[   11.892156] cam clk[ccic4x_func]: 624000000
[   11.892162] ccic1 clock enabled
[   11.892454] ccic1 clock disabled
[   11.895692] cam clk[ccic4x_func]: 624000000
[   11.903762] ccic2 clock enabled
[   11.907229] ccic0 clock enabled
[   11.911507] ccic2 clock disabled
[   11.915151] ccic0 clock disabled
[   12.261323] EXT4-fs: Remounting file system with no journal so ignoring journalled data option
[   12.313849] EXT4-fs (mmcblk0p2): re-mounted 32539e08-a5c0-4084-9f32-0932043d95e3 ro. Quota mode: none.
[   12.415086] EXT4-fs: Remounting file system with no journal so ignoring journalled data option
[   12.448663] EXT4-fs (mmcblk0p2): re-mounted 32539e08-a5c0-4084-9f32-0932043d95e3 r/w. Quota mode: none.
[   12.472529] EXT4-fs (mmcblk0p1): mounted filesystem 5c205338-1b02-4bc9-a396-dc0fe556357f r/w with ordered data mode. Quota mode: none.
[   15.195695] RTW: module init start
[   15.202451] RTW: rtl8852bs v1.19.7.1-91-gcb07686050.20240409
[   15.211390] RTW: build time: Jan 19 2025 03:00:20
[   15.219309] RTW:
[   15.224358] RTW: =======================================================
[   15.234287] RTW: ==== Launching Wi-Fi driver! (Powered by Spacemit) ====
[   15.244184] RTW: =======================================================
[   15.254081] RTW: Realtek rtl8852bs WiFi driver (Powered by Spacemit,Ver v1.19.7.1-91-gcb07686050.20240409) init.
[   15.267528] spacemit-rf-pwrseq rf-pwrseq: turn power on
[   15.276945] spacemit-rf-pwrseq rf-pwrseq: check voltage: 1800000
[   15.406235] RTW: module init ret=0
[   15.417996] sdhci-spacemit d4280800.sdh: card claims to support voltages below defined range
[   15.421405] udevd[221]: specified group 'netdev' unknown
Hi, The download links are not working (6.13.0-rc7-build-20250119). Could you please check?
Sorry, core has already been uploaded, xfce within half an hour.
It’s great to see you actively developing this system!
The links are now working, and I’ve successfully installed the 20250119 core version on my Banana Pi F3.
The command echo 1 > /sys/devices/system/cpu/cpufreq/boost works perfectly, but when I try to run
echo 1800000 > /sys/devices/system/cpu/cpufreq/policy0/scaling_setspeed, I get the error:
-bash: echo: write error: Invalid argument.
Running cat /sys/devices/system/cpu/cpufreq/policy0/scaling_available_frequencies returns:
614400 819000 1000000 1228800 1600000.
I’d like to set the CPU to 1.8 GHz. How can I achieve this?
so, I gave incomplete information, I’m correcting it
kernel 6.13.1
irradium-3.7-riscv64-core-banana_pi_f3-6.13.1-build-20250202.img.zst
irradium-3.7-riscv64-core-banana_pi_f3-6.13.1-build-20250202.img.zst.sha256
irradium-3.7-riscv64-xfce-banana_pi_f3-6.13.1-build-20250202.img.zst
irradium-3.7-riscv64-xfce-banana_pi_f3-6.13.1-build-20250202.img.zst.sha256
Just out of curiosity: Would it be possible to oveclock (in a similar way) a stock Bianbu installation?
yes, changing the kernel.
Fooo, nice :slight_smile: Can I please ask you to elaborate a bit more on the topic? Not sure how the boot process work on BPI-f3. Nor do I know which specific changes there are present between ‘your’ kernel and stock Bianbu kernel…
(Yes, yes, I’m aware that I could (and probably should) spend the next whole month studying the whole thing, but I’m pressed for other things too… :slight_smile: )
take kernel-k1#236.6.72-1.pkg.tar.gz unpack move /lib to /lib rename the files in the unpacked /boot folder similarly to the existing /boot and move them there.
You are awesome! It works very nicely, thank you :slight_smile: :clap:
Just a sidenote: There is no sound device present in the system. Would it be compliated to make it work? :thinking:
need to add module loading:
modprobe spacemit_card
modprobe spacemit_i2s
modprobe spacemit_pcm
modprobe snd_soc_es8323
cat /proc/asound/cards
Yesss – sound works again :blush: (Only jack output; no HDMI or BT headset output… but I think I can live with that… :smile: )
Thank you yet again!
