Produce Overview: The module makes Banana Pi compatible with Arduino Uno and many Arduino Shields. There is an ATmega328 chip on the board so the module can compatible Arduino Uno code and peripheral. This board is a combination of high operation performance of the banana pie and Arduino flexible control performance, the combination of peripheral greatly expand the banana pie access ability and the abundance of accessories.
Produce Features: ATmega328 chip on module Compatible with Arduino Uno Switch 5V or 3.3V GPIO Compatible with Processing code Expand SPI of Banana Pi
Port: Banana Pi connection port Banana Pi cascade port Arduino Uno GPIO Electric level switch jumper SPI ICSP port
Product Parameters: Working voltage: 3.3V-4.5V GPIO voltage: 3.3V或5.5 8 channel 10bit high resolution ADC Power-down Mode: 0.1µA 32K ROM 2K RAM −40°C to +85°C operation
Typical Application: Automatic control Arduino learning Sensor control 3D printer controller Laser cutter controller Robot controller Smart home
How to use: Just insert the module to Banana Pi, like the below picture:
