My initial thought was that I could dodge the need for another micro sd card if the below would work:
1 write an image to a USB 3.0 flash drive
2 extend the partition to 16 or 32gb
3 copy an image to burn to the eMMC, placing it on same partion from step 1 & 2
4 boot from USB 3.0
5 use the same instructions to dd an image on the flash drive to eMMC?
Yes I know the BPI-M2+ only has USB 2.0 I meant booting from a 3.0 flash drive in a 2.0 port Would this work? I do intend to use the eMMC for booting, but don’t you have to boot via USB or SD first and dd the image to eMMC?
I will probably only need a server for the project that I am working on.
