Hi guys, I have a problem, i have an eGalax tcap touch + display, the display is connected to the lvds connector and it work, but the i2c not work
i connected the SDA and the SCL on the gpio
SDA : Pin 3 SCL : Pin 4
i installed the eGalax i2c driver,
lsmod:
Module Size Used by egalax_i2c 14737 0 disp_ump 850 0 sunxi_cedar_mod 10332 0 mali_drm 2638 2 drm 214490 3 mali_drm mali 114863 0 ump 58359 4 mali,disp_ump cpufreq_stats 5908 0 cpufreq_conservative 5712 0 cpufreq_userspace 3612 0 cpufreq_powersave 1282 0 spidev 6382 0 bnep 14710 2 8021q 19345 0 garp 6160 1 8021q stp 2032 1 garp llc 5449 2 stp,garp spi_sun7i 19657 0 bonding 111713 0 hidp 17720 0 rfcomm 58982 0 bluetooth 264849 11 bnep,hidp,rfcomm
dmesg:
[ 63.208471] [egalax_i2c]: Driver init done! [ 63.214080] i2c-core: driver [egalax_i2c] using legacy suspend method [ 63.222481] i2c-core: driver [egalax_i2c] using legacy resume method
but its not work, tell me if need some others informations…
hope you can help, Thank you so much! Best Regards
