Bananapi P2 Zero and M2 Zero Armbian_bookworm
P2 Zero
08a93491b269194d9774d6d23ed8874
M2 Zero
fee7d44e2eb27d31ff49382ef51cce7
Graphical interface
P2 Zero
e9352734288905710e1353f33faff18
M2 Zero
About this version
Link: Baidu Wangpan https://pan.baidu.com/s/1KbRHtHlLo0VLl6--WrSsVg?pwd=8888 code: 8888
Launch Video
Banana Pi BPI-M2 Zero/BPI-P2 Zero Armbian bookworm image configuration video
Did you tryed to boot from the emmc memory?
Yes, you can start from EMMC.
Advice: I recommend not using this image. Testing is indicative of being less than complete. For one, there is a malformed block device configuration.
/var/log.hdd: The mmcblk0p1 partition, which was previously mounted as the root directory (/), has been remounted at /var/log.hdd.
zram2: A new zram device, labeled as zram2, has appeared in the output. This new device has a size of 0 bytes, which seems unusual as zram devices are typically allocated with a specific size for swap or temporary storage."
Just tested the image. It boots ok. I wanted to use the MIPI port for video capture but ffmpeg returns ‘Not a video capture device’.
v4l2-ctl returns /dev/video0 as a capture device.
I can provide more log if requested.
BR.
— EDIT — Ok. Digged a bit more. PE12/PE13 aren’t enabled by default and need enabling with some overlay. Added overlays=i2c2 to activate the I2C bus for the MIPI CSI port in /boot/armbianEnv.txt
The I2C bus shows up after a reboot in /dev. All fine.
i2dectect -l |i2c-3|i2c |DesignWare HDMI |I2C adapter| |i2c-2|i2c |mv64xxx_i2c adapter |I2C adapter|
Checked the I2C bus with i2cdetect -y 2 but got some errors in dmesg:
[ 272.563591] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0
Side note: I had this camera working with an old Raspbian image.
Progressing a bit to get this OV5640 camera up and running but the I2C driver is likely failing sadly.
