Thanks a lot for your reply.
Meanwhile I tried to connect USB2Serial interface, I had a u-boot shell, so i guess that board is working (and image on sd-card is bad):
*C1:80000000
C2
?_?
C3h
hwsetting size: 00000950
C4
f
5-5
Goto FSBL: 0x80008000
Welcome to FSBL …
REG32(VO_SW_SEC_1)=01C00000
[FSBL] Secure: 0x0000BEEE
[FSBL] DCache Enable: 0x00000000
[FSBL] SVP = N
********** FW_TYPE_BOOTCODE **********
FW Image to 0x00100000, size=0x00080BA0 (0x00180BA0)
FW Image fr 0x881313E8
kmcp_bypass copy audio bin
FSBL: plat_gic_setup
FSBL: plat_gic_setup_percpu
FSBL Jumps to LK
U-Boot 2015.07 (May 13 2020 - 17:12:53 +0800)
CPU : Cortex-A53 Quad Core - AARCH64
Board: Realtek QA Board
DRAM: 1 GiB
Watchdog: Disabled
mapping memory 0x20000000-0x40000000 non-cached
flushing dcache successfully.
nor flash id [0x00ef4018]
sector 256k en: 0
sector 64k en: 1
sector 32k en: 1
sector 4k en: 1
page_program : 1
max capacity : 0x01000000
spi type name : WINBOND_W325Q128BV_128Mbit
MMC: Initialize eMMC in traditional mmc flow.
RTD1395 eMMC: 0
rsp[0]=0x15010038,
rsp[1]=0x47544634,
rsp[2]=0x52064546,
rsp[3]=0x49abc8af
The cid_val is 15.
rsp[0]=0xd0270132,
rsp[1]=0x0f5903ff,
rsp[2]=0xf6dbffef,
rsp[3]=0x8e40400d
mmc->version=0x40000000
version=0x00000004
[LY] cardtype=57, mmc->card_caps=0f
[LY] freq = 00464388, clk diver = 00000080
[LY] speed up emmc at HS-200
[LY] HS-200 bus width=2
[LY] mmc->boot_caps = 20b
TEMP TX_WINDOW=0xfffffff3, TX_best=0x12
RX_WINDOW=0xffffe0ff, RX_best=0x1a
TX1_WINDOW=0xffffffe1, TX_best=0x12
[LY] hs200 : 0
[HC] ERASE Unit Size = 524288 bytes
[HC] WPG_SIZE = 8388608 bytes
Device: RTD1395 eMMC
Manufacturer ID: 15
OEM: 100
Tran Speed: 200000000
Rd Block Len: 512
MMC version 4.0
High Capacity: No
Capacity: 7.3 GiB
User Capacity: 7.3 GiB
Boot Capacity: 4 MiB
RPMB Capacity: 512 KiB
Bus Width: 8-bit
Speed: HS200
SD:
SD device index# 0
Factory: SD
------------can’t find tmp/factory/000BootParam.h
[ENV] read_env from factory failed
Using default environment
*** Warning - bad CRC, using default environment
[BPI] set dram dtb is 1GB
In: serial
Out: serial
Err: serial
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
get_partition_info_efi: *** ERROR: Invalid GPT ***
get_partition_info_efi: *** ERROR: Invalid Backup GPT ***
------------can’t find tmp/factory/hdmitx_format.bin
------------can’t find tmp/factory/video_rpc.bin
tv_system=25 mode=1
Net: Realtek PCIe GBE Family Controller mcfg = 0024
dev->name=r8168#0
Checking default environment
Hit Esc or Tab key to enter console mode or rescue linux: 0
------------can’t find tmp/factory/recovery
------------finished reboot_action
======== Checking into android recovery ====
==== start load bootcode from SD =====
SD: try to boot from SD
mmc->scr[0]=2b58000,mmc->scr[1]=0
SD: init done, no error
SD: capacity 7872512 sectors(0x782000), (3844 MB)
CMD[fatload sd 0:1 0x00030000 /bananapi/bpi-m4/linux/u-boot-bpi-m4.bin]
reading /bananapi/bpi-m4/linux/u-boot-bpi-m4.bin
** Unable to read file /bananapi/bpi-m4/linux/u-boot-bpi-m4.bin **
CMD[fatload sd 0:1 0x00030000 u-boot-bpi-m4.bin]
reading u-boot-bpi-m4.bin
** Unable to read file u-boot-bpi-m4.bin **
CMD[sd read 0x00030000 0x50 0x430]
SD read: dev# 0, block# 80, count# 1072 …
do sd_ops MMC_READ
1072 blocks read: OK
[WARNING] bootcode seem is not valid, first 4 bytes:
00 00 00 00
CMD[fatload mmc 0:1 0x00030000 /bananapi/bpi-m4/linux/u-boot-bpi-m4.bin]
** No partition table - mmc 0 **
*No partition table, try part 0 again!
*** Unrecognized filesystem type **
CMD[fatload mmc 0:1 0x00030000 u-boot-bpi-m4.bin]
CMD[rtkemmc read 0x00030000 0x50 0x430]
00 00 00 00
Enter console mode, disable watchdog …
BPI-M4(SPI)>*
The only things that I can not undestand is why if I connect first HDMI cable and than USB-C power cable the board won’t power up, if I connect power cable first and than HDMI the board power up normally.
