Banana Pi R3 Mini Issues
Hello everyone,
I’m opening this topic to report the current issues to @sinovoip .
Please list the problems here so they can verify and improve the product.
Here are some examples I have noticed:
  1. The case should be redesigned to reduce the temperatures of both the Banana Pi R3 Mini and a potential 5G module.
  2. The M.2 Key B slot has some issues—for example, certain modules stop being detected (such as the Fibocom FM160).
  3. After normal use of the board, some components stop working due to excessive heat generated between the board and the 5G module.
Please add any other issues you’ve encountered and provide detailed descriptions.
Thanks, SuperKali
Hello, I’ve been testing for some time the BPI-R3 mini, and I found some relevant issues regarding the thermal management of the board itself alongside the M.2 module.
  1. There is not enough space to put any kind of good heatsink (2mm aluminum ones painted in fake copper don’t count)
  2. The tiny fan is very loud: when using the BPI in a simple upload session to synchronize some files with my personal drive (with temps reaching 80C while the fan is screaming loudly at 100% speed)
  3. The bottom rubber pads are causing more harm than good, because by removing them and letting the bottom surface in contact with any kind of material other than just air you can greatly improve thermal dissipation (-20 C delta on average) by letting the case in contact with other surfaces (e.g. wooden table, travertine wall shelf, or even better: metal surface)
Since I use this board at my dorm room, I had to solve the fan noise issue first. I tried last month to remove the fan and install a bigger heatsink for the modem, in order for it to dissipate passively. Here are some pictures of what I did, the heatsink is 11mm high, 33x52 to cover the whole modem.
I had to bend a couple of fins in order for it to fit with the case above.
At first, temperatures seemed to be quite above average, with medium signal conditions:
So I continued to use it for a week, always monitoring temperatures closely:
ambient temperature was about 21 ˚C.
There were some 70˚C spikes when using it to download something (e.g. a lecture for university) but in idle the temperatures were not that bad.
Later on that week, I encountered the first problems, the modem was randomly crashing:
I thought maybe the modem was throttling or having issues with excessive heat, but it crashed way earlier than it could reach critical temperatures, leading me to think it was some kind of lack of power issue.
I’ve tried to swap the modem with another FM350-GL 5G, and the issue persisted. The board somehow stopped handling the modem correctly, as it was doing before.
Having tested all of this, case redesign is a must. Thicker metal surfaces, thermal pads for the modem to dissipate and slightly higher case will be helpful to mitigate these issues. Making it a little bit larger can help to have a lower RPM fan, prolonging its MTBF.
I had to purchase a second BananaPi-R3 mini, because the first board could not handle any modem anymore in a normal position. Maybe the plastic has deformed from the heat.
However, the same issue still applies, putting back the fan, with peaks to 81C
Heat seems to be a real problem with a radio module in the m2 slot, if the R3mini is placed into the original case. You could have a try with putting putty between module and pcb. And maybe try to find a heatsink with longer finns.
I do not like the case designs from Sinovoip in gegeral. Non of them seems to be very good. Because of that I did order the naked pcb and made my own silent case. But this is only possible because I do not use this router on travelling.
It has got a Noiseblocker XS-1 50mm fan (@5V from the fan header) at the bottom. Okay, there is no radio module, but I’m quiet shure temps would be much better.
Hi, same situation here!
I just can’t understand why in the designs they had to make the case so small even by limiting it to 6 holes… Are they designing it for 4G ? If you use a module 5G ? I think that you are also limited to using certain antennas instead of more powerful ones… Since it is an indoor product and it is inconvenient to use the larger ones to remove or put the LAN cables.
Let’s get to the point…
Before trying to make a 3D case with more appropriate measurements and make it truly fanless, I bought case to better understand what I really have to design to use it at 110%.
First of all, for 5G module I created two more holes, I distribute the antennas better. I chose to use 12dbm antenne and the cables that go to the module are better ordered.
I had a heatsink from old projects and I completely discarded 32x40x5. I use a noctua 40x10 directly but with USB power supply without closed the case.
something today … Speedtest di Ookla - Il test globale per la velocità della tua banda larga
Hi, I brought an BP-R3 mini and have multiple problems:
It’s a shame, with a noctua fan and and the new top the router is very quiet and it doesn’t make it bigger, so it should have been the solution from the beginning
Can’t debug anymore because the router is now at a friend in another country and runs without an ssd but is otherwise fine.
Edit: Added notice about m2 screws and insets, changed expired links to non expired gdrive links
Hi bprfh,
This looks like fantastic work and exactly what I’m looking for also. Unfortunately the fan encolusre file link doesn’t work anymore. Would you be able to upload it again?
Thank you!
I have also had similar problems with modem instability when using a Quectel RM520N, where the modem would sometimes not show up at all/lose connection randomly etc. Initially everything seemed to work ok and the connection was relatively stable, but after a few weeks of continuous use it got worse and worse. I have even made a thread in these forums to try to track down the issue: BPI R3 Mini with disappearing Quectel RM520N-GLAA
I initially assumed that the modem module itself might have had some issues, but after placing the same modem in this adapter Dual-Q 5G2PHY Quectel 5Gnr Ethernet PHY adapter design for RM520N RM50 – 4G discount it has been working flawlessly for months. It should be noted that I’ve had a 60 mm Noctua fan strapped to the top of the R3 Mini case via a 3d printed adapter since day one, so I’m not sure how much more I could have improved the cooling. To me it seems like the R3 Mini might not have the power delivery necessary for prolonged use together with a 5G modem. Using the RM520N + 5G2PHY adapter I’ve observed continuous power usage of up to 9 W.
This seems very strange to me, also because the schematic states 3.3V at a maximum of 8A.
The RM520N requires at the very least 3,135 V in order to run, preferably around 3,7 V according to Quectel’s own hardware design documents: https://forums.quectel.com/uploads/short-url/1zkjPRnxF5BZ2woox386baCZx4g.pdf
Is it the same for the Fibocom modules that you have been using? It should be noted that I have not measured the actual VCC in the M2 B slot of my R3 Mini, so take my speculations below with a grain of salt.
To my (untrained) eyes it just seems like some part of the hardware is degrading at a very rapid pace, which in turn affects the stability of any modem modules connected via the M2 B slot. Everything worked as expected for me for the first week of use or so, after that the modem started to lose connection randomly. As time progressed the disconnections got more frequent and sometimes the module would not show up at all in OpenWRT, requiring me to reboot the whole system for the module to show up again. After a month or so it was basically unusable. Moving the same modem to a different setup, having tested both modem in USB enclosure and modem in ETH adapter, the modem runs flawlessly. If I move the modem back to the R3 Mini it starts acting up again.
Same heating issue here. This is how I fixed it. They have been working flawlessly for months now…
anyupdate or goodnews here? i have same problem i cant detect my modem rm520n
This is cool, 3d printed?
Yes. And a Noctua NF-A6x15 5V PWM is in there. The FM350-GL modem has an heatsink like this:
the temperatures never reach or rise 50 C˙
can you share the model so I. can print? And what fan are you using?
Thanks
Dear Community!
I have upload the file that i get from @SuperKali. The model is that on the pictures previous is my own modified version, and it isn’t public. The attached files are great guides to start to make you own house :slight_smile:
BPI R3 Mini Lid with Noctua A6x25 mount.stl (93.1 KB)
Hi @yodee13,
Thank you so much for sharing the base STL file! It’s incredibly helpful as a starting point.
I know you mentioned that your modified version with the honeycomb top isn’t public, but I just had to ask—is there any chance you would be willing to share the STL for that top lid? It looks absolutely amazing and incredibly clean.
If you prefer to keep it private, I completely understand and respect that! Either way, fantastic work on the design, and thanks again for sharing the base guide.
Here is the files, that i got from SuperKali too. I hope you can use it. Because of the size, i can share it via Gdrive
https://drive.google.com/file/d/1GENcx-Hbga55BL9kukJNG1RjSnfdVM8b/view?usp=sharing
Please let me know, if it’s okay.
yodee13,
Can you share the stl file you created for the Noctua NF-AF6? If you’re going to post a picture, you should share the idea.
Also, which 5g antennas are you using in your picture? Thanks!
E
