Setting up the Banana Pi R3 Mini as a 5G router with the Quectel RM520N-GL turned out to be a lot more complicated than expected—firmware quirks, modem power issues, fan noise, and case limitations all got in the way. After a lot of trial and error (and help from others in the community), I put together a guide to hopefully make this process easier for anyone else.
I decided to document my journey, which covers hardware assembly, ImmortalWRT installation, Wi-Fi band steering, package setup, fan control, and recovery (still work in progress). There’s also a 3D-printable STL for a Noctua A6x25 (60mm) fan lid, with notes on materials and assembly.
I can’t remember exactly what didn’t work for me, but I think I had issues at the flashing stage already. This could have certainly been a mistake from my end.
Are you able to test it from your end with a 5G module? Happy to adjsut the guide and mention that OpenWRT should work as well. Let me know your thoughts.
Sorry, but I have no 5G module to test. Maybe in a few years, when they are affordable.
Flashing the BPI-R3 mini to OpenWRT shouldn’t be a problem at all. The device is supported officially.
There are people having active RM520N modules on OpenWRT and it does not look like there are any issues to activate it since the drivers are added to the kernel.
I have read about heat and power problems, but this should be a general thing with the R3 mini.
Thanks, I appreciate the feedback. I’ll change the wording in the guide to say while everything was tested on immortalWRT, openWRT will likely work as well.
using bananwrt image on my device (which maybe the custom firmware) but still facing 5g problems, the module disappear most of times and thats really annoying, if you got any tips please provide for me
