Hey, looking for some help on a statistic problem that I have on my Banana PI R3:
have a Banana Pi R3 with self-compiled firmware flashed to the SD card.
The firmware I am using is a self-compiled openwrt in which I add all of the programs I want (e.g. Docker, Wireguard, Adblock)
I noticed that if the device loses power there is about 50% chance that it will be stuck while rebooting.
If you look at the LEDs when booting, when “a good boot” happens there is a green LED that is blinking (I think that it means that it is reading from the SD, not sure).
In case there is a problem, after a few seconds that the red on, the green is turned on for a fraction of a second, and almost immediately turns off. Then there is a blue LED that is turned on, and the device is stuck.
I tried a few times to understand what happens when I am connected with an FTDI serial adapter, but when I do the problem never occurs again.
I asked about it in openwrt forum in December and someone answered that the only way to fix it is to move from SD card to EMMC:
Still didn’t do that, but will be glad to hear if there is any other workaround because 8GB of emmc isn’t enough for my usage, and as far as I understand I can’t use the SD card when emmc is enabled.
In case you want me to provide logs, let me know. I can get logs from openwrt or from the bootloader by using serial. just let me know which commands to run.
Important to mention: I’ve never caught the problem while connected with serial adapter, but it seems like something statistic / a race condition that could be affected by that.
Any ideas?
