So there seems to be a problem with some r3 boards not detecting the SD Card correctly when booting. The issues also seems to occur on reboot. The problem seems to be known already . So I tried to narrow it down a little bit. I have r3’s from different batches, and one batch seems to fail to boot way more often. I tried with two different SD Cards. I tested on multiple Banana Pi R3 v1.1 batch 2311 boards and multiple Bananapi R3 v1.1 batch 2347 boards.
td;dr: the boards from batch 2347 fail with the same SD Cards, which boot fine on batch 2311, so I suspect some hardware design issue combined with manufacturing tolerences?
I’ve documented in depth, including more details and complete boot logs in this pad > Banana Pi R3 SD Card boot issue documentation debugging - HedgeDoc
Do you have any ideas how I could narrow this down some more?
Which batches of boards are more prone to failure? Maybe @Itay has some input here on which batch you have issues with?
Any more data points would be welcome, maybe we can help figuring this out.
