Hello
I have a problem with 5 "screen. After connecting the power cable and HDMI displays only a white screen. Has anyone had a similar problem?
Hello
That looka a lot like what I get on my 7" LCD screen attached to the MIPI-DSI.
I found the solution here, http://linux-sunxi.org/Sinovoip_Banana_Pi_M3#HDMI_to_DVI_converters
By setting hdmi_cts_compatibility = 1 with sunxi-tools.
However, I cannot change display size to match my screen, 800x480.
Thank you for your answer.
Unfortunately, everything is unchanged.
I don’t sure, why you set screen0_output_mode to 10. For my 5" screen, it’s resolution is 800x480. Then, the nearest output mode should be 5 or 2. (I use 2) See the Flex Guide at http://linux-sunxi.org/Fex_Guide#disp_init_configuration
Where have you bought his screen? you can send me your file script.bin?
I bought it from 52Pi shop. https://www.aliexpress.com/item/5-Inch-800x480-HDMI-TFT-LCD-Touch-Screen-for-Raspberry-PI-3-2-Model-B-B/32664395270.html
Here is my script.bin script.bin (54.1 KB) and script.fex script.fex (27.2 KB)
My screen bought from this seller, we have the same screens. Do I need to change only script.bin?
Still it does not work on HDMI, even with your file script.bin :(. White screen with colored lines
Today, I got another display model. http://wiki.52pi.com/index.php/5-Inch-800x480-HDMI-TFT-LCD-Touch-Screen_SKU:Z-0053
When I replace the previouse work display, it show white screen like you.
First, I found that the HDMI connector is very hard to put in. So, the signal may not send or strong enough. I had put in to the deep end. Then, it show me some shadow of screen. I think, the signal was corrected. It work after reboot.
Second, I move it to another board and supply the power from the USB port on the board. When I switch on, it look like a short circuit, the screen still white. I think, the screen consume much power at the initial time, if the power is not enough, it cannot initialize and then, not work. So, I try to power it with external adapter. Then, it work.
How do I buy a power supply to the screen? what power?
Hi, Do you have experience with Waveshare 5inch HDMI (B) ver1.1 LCD? I have the similar white screen with the BPI M3. Is it possible to use them together? (And, of course, how?) Thanks.
Hi, i have the same problem, m3+official 7"screen, ubuntu or android, whit lines on black screen. Have anyone an idea, what todo? Thanks, daniel
Thanks for the script.bin
fixed my screen
