Banana Pi BPI-R4 Wifi 7 router board with MediaTek MT7988A (Filogic 880),4G RAM and 8G eMMC
It was pretending. It wasn’t actually offloading because of flow-offloading with nftables being broken in general. That was fixed now, restoring flow-offloading capabilities on all SoC starting from MT7621: [net] netfilter: nf_tables: fix bidirectional offload regression - Patchwork
However, now that the flow offloading entries actually match both directions of traffic, for some not yet clear reason this now results in blocked/dropped packets if using 4 GiB of RAM.
Maybe a dumb question, but how is the 3-pin Fan Header supposed to work with pwm? I’ve never seen a 3 pin fan that supports pwm
You are right that pwm fans normal have 4 pins because the 3rd pin is sense to read speed. But this is not used on r3/r4 and maybe can connected to a gpio.
I have tried 3rd party pwm fan on r3 and it does not work. I guess problem was that it was a 5v pwm and r3 supplied only 3v3 on pwm…so only bananapi fans work here
i solved it on ubuntu 20.04
Has anyone been able to get a T99W175 5g modem working in this board? I’ve got one plugged into the B-key slot and I’m not seeing it show up with lspci or lsusb:
bpi-r4# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux 6.1.79 xhci-hcd xHCI Host Controller
Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc.          USB2.0 Hub
Bus 001 Device 003: ID 0cf3:e600
Bus 001 Device 005: ID 2109:8822 VIA Labs, Inc.          USB Billboard Device
Bus 002 Device 001: ID 1d6b:0003 Linux 6.1.79 xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc.          USB3.1 Hub
bpi-r4# lspci
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01)
0001:01:00.0 Network controller: Qualcomm Technologies, Inc QCNFA765 Wireless Network Adapter (rev 01)
Curious if anyone’s had luck with this modem. Per the docs and above thread, it looks like PCI modems are supported?
No luck either. I tried as well. I think they will work down the road but not yet. It’s too new.
I was considering getting an mPCIe to B key adapter and seeing if it works in another slot. The fact that nothing is showing up on the PCI bus is concerning though. I have board revision 1.1 and I did some some discussion from this summer about revisions for better PCI support in the B key slot.
Does anyone from sinovoip have any insight?
You can use the stock firmware from the getting started BPI r4 page. It will see your card. Issue for me was I was unable to add the correct modules needed because they don’t exist, because they weren’t built.
Interesting, I am able to confirm! On the bpi firmware, I see
0003:01:00.0 Unassigned class [ff00]: Qualcomm Device 0306
	Subsystem: Qualcomm Device 010c
	Flags: fast devsel
	Memory at 20200000 (64-bit, non-prefetchable) [disabled] [size=4K]
	Memory at 20201000 (64-bit, non-prefetchable) [disabled] [size=4K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [148] Secondary PCI Express
	Capabilities: [168] Physical Layer 16.0 GT/s <?>
	Capabilities: [18c] Lane Margining at the Receiver <?>
	Capabilities: [19c] Transaction Processing Hints
	Capabilities: [228] Latency Tolerance Reporting
	Capabilities: [230] L1 PM Substates
	Capabilities: [240] Data Link Feature <?>
in lspci - that’s the x55 modem.
Daniel says it can be caused by a clock…can you print the clk_summary from bpi image?
cat /sys/kernel/debug/clk/clk_summary
I’ve tried to go into that direction but the clk driver in MTK SDK is completely different (many 1:1 factors used as aliases, result is that it looks like there are many more gated clocks than there are in reality; plus the clk-bringup.c which just enabled practically everything…)
root@OpenWrt:~# cat /sys/kernel/debug/clk/clk_summary
                                 enable  prepare  protect                                duty
   clock                          count    count    count        rate   accuracy phase  cycle
 pcf8563-clkout                       0        0        0       32768          0     0  50000
 clkxtal                             25       25        0    40000000          0     0  50000
    msdcpll                           1        1        0   400000000          0     0  50000
       cb_msdc_400m                   1        1        0   400000000          0     0  50000
          emmc_400m_sel               1        1        0   400000000          0     0  50000
             emmc_400m                1        1        0   400000000          0     0  50000
                infra_fmsdc400_o       1        1        0   400000000          0     0  50000
                   infra_f_fmsdc400       1        1        0   400000000          0     0  50000
    usxgmiipll                        0        0        0   644531250          0     0  50000
    ccipll2_b                         1        1        0   900000000          0     0  50000
       mcu_bus_div_sel                1        1        0   900000000          0     0  50000
    arm_b                             1        1        0  1500000000          0     0  50000
       mcu_arm_div_sel                1        1        0  1500000000          0     0  50000
    sgmpll                            1        1        0   325000000          0     0  50000
       cb_sgm_325m                    2        2        0   325000000          0     0  50000
          macsec_sel                  0        0        0   325000000          0     0  50000
          sgm_1_sel                   1        1        0   325000000          0     0  50000
          sgm_0_sel                   1        1        0   325000000          0     0  50000
    wedmcupll                         0        0        0   208000000          0     0  50000
       cb_wedmcu_208m                 0        0        0   208000000          0     0  50000
    net2pll                           7        7        0   800000000          0     0  50000
       cb_net2_800m                   2        2        0   800000000          0     0  50000
          ck_npu_sel_cm_tops_sel       0        0        0   800000000          0     0  50000
          npu_tops_sel                0        0        0   800000000          0     0  50000
          netsys_mcu_sel              1        1        0   800000000          0     0  50000
             netsys_wed_mcu           3        3        0   800000000          0     0  50000
                ethwarp_wocpu2_en       1        1        0   800000000          0     0  50000
                ethwarp_wocpu1_en       1        1        0   800000000          0     0  50000
                ethwarp_wocpu0_en       1        1        0   800000000          0     0  50000
          netsys_2x_sel               1        1        0   800000000          0     0  50000
             netsys_2x                1        1        0   800000000          0     0  50000
                ethdma_fe_en          1        1        0   800000000          0     0  50000
       cb_net2_d2                     2        2        0   400000000          0     0  50000
          netsys_warp_sel             1        1        0   400000000          0     0  50000
          netsys_tops_400m_sel        0        0        0   400000000          0     0  50000
          netsys_sel                  1        1        0   400000000          0     0  50000
       cb_net2_d4                     1        1        0   200000000          0     0  50000
          eth_sys_200m_sel            1        1        0   200000000          0     0  50000
       net2_d4_d4                     1        1        0    50000000          0     0  50000
          eth_refck_50m_sel           1        1        0    50000000          0     0  50000
       net2_d4_d8                     1        1        0    25000000          0     0  50000
          eth_mii_sel                 1        1        0    25000000          0     0  50000
       cb_net2_d6                     3        3        0   133333333          0     0  50000
          pextp_tl_ck_p3_sel          1        1        0   133333333          0     0  50000
             infra_pcie_ck_occ_p3       1        1        0   133333333          0     0  50000
                infra_pcie_gfmux_tl_o_p3_sel       1        1        0   133333333          0     0  50000
                   infra_pcie_gfmux_tl_ck_p3       1        1        0   133333333          0     0  50000
          pextp_tl_ck_p2_sel          0        0        0   133333333          0     0  50000
             infra_pcie_ck_occ_p2       0        0        0   133333333          0     0  50000
                infra_pcie_gfmux_tl_o_p2_sel       0        0        0   133333333          0     0  50000
                   infra_pcie_gfmux_tl_ck_p2       0        0        0   133333333          0     0  50000
          pextp_tl_ck_p1_sel          1        1        0   133333333          0     0  50000
             infra_pcie_ck_occ_p1       1        1        0   133333333          0     0  50000
                infra_pcie_gfmux_tl_o_p1_sel       1        1        0   133333333          0     0  50000
                   infra_pcie_gfmux_tl_ck_p1       1        1        0   133333333          0     0  50000
          pextp_tl_ck_sel             1        1        0   133333333          0     0  50000
             infra_pcie_ck_occ_p0       1        1        0   133333333          0     0  50000
                infra_pcie_gfmux_tl_o_p0_sel       1        1        0   133333333          0     0  50000
                   infra_pcie_gfmux_tl_ck_p0       1        1        0   133333333          0     0  50000
       cb_net2_d8                     0        0        0   100000000          0     0  50000
          da_xtp_glb_p3_sel           0        0        0   100000000          0     0  50000
          da_xtp_glb_p2_sel           0        0        0   100000000          0     0  50000
          da_xtp_glb_p1_sel           0        0        0   100000000          0     0  50000
          da_xtp_glb_p0_sel           0        0        0   100000000          0     0  50000
    net1pll                           7        7        0  2500000000          0     0  50000
       cb_net1_d4                     2        2        0   625000000          0     0  50000
          mcusys_backup_625m_sel       1        1        0   625000000          0     0  50000
          netsys_gsw_sel              1        1        0   625000000          0     0  50000
             netsys_gsw               1        1        0   625000000          0     0  50000
                ethdma_esw_en         1        1        0   625000000          0     0  50000
       cb_net1_d5                     1        1        0   500000000          0     0  50000
          bus_tops_sel                0        0        0   500000000          0     0  50000
          netsys_500m_sel             1        1        0   500000000          0     0  50000
       net1_d5_d2                     4        4        0   250000000          0     0  50000
          netsys_ppefb_250m_sel       1        1        0   250000000          0     0  50000
          netsys_sync_250m_sel        1        1        0   250000000          0     0  50000
          eth_sys_sel                 1        1        0   250000000          0     0  50000
          pcie_mbist_250m_sel         0        0        0   250000000          0     0  50000
          emmc_250m_sel               1        1        0   250000000          0     0  50000
             emmc_250m                1        1        0   250000000          0     0  50000
                infra_fmsdc2_hck_occ       1        1        0   250000000          0     0  50000
                   infra_f_fmsdc2_hck       1        1        0   250000000          0     0  50000
       net1_d5_d4                     3        3        0   125000000          0     0  50000
          usb_xhci_p1_sel             1        1        0   125000000          0     0  50000
             usb_xhci_p1              1        1        0   125000000          0     0  50000
                infra_usb_xhci_o_p1       1        1        0   125000000          0     0  50000
                   infra_usb_xhci_ck_p1       1        1        0   125000000          0     0  50000
          usb_xhci_sel                0        0        0   125000000          0     0  50000
             usb_xhci                 0        0        0   125000000          0     0  50000
                infra_usb_xhci_o       0        0        0   125000000          0     0  50000
                   infra_usb_xhci       0        0        0   125000000          0     0  50000
          usb_sys_p1_sel              1        1        0   125000000          0     0  50000
             usb_sys_p1               1        1        0   125000000          0     0  50000
                infra_usb_sys_o_p1       1        1        0   125000000          0     0  50000
                   infra_usb_sys_ck_p1       1        1        0   125000000          0     0  50000
          usb_sys_sel                 0        0        0   125000000          0     0  50000
             usb_sys                  0        0        0   125000000          0     0  50000
                infra_usb_sys_o       0        0        0   125000000          0     0  50000
                   infra_usb_sys       0        0        0   125000000          0     0  50000
          i2c_sel                     0        0        0   125000000          0     0  50000
             i2c_bck                  0        0        0   125000000          0     0  50000
                infra_i2c_o           0        0        0   125000000          0     0  50000
                   infra_i2c_bck       0        0        0   125000000          0     0  50000
          spinfi_sel                  0        0        0   125000000          0     0  50000
             spinfi_bck               0        0        0   125000000          0     0  50000
                infra_spinfi_o        0        0        0   125000000          0     0  50000
                   infra_f_fspinfi       0        0        0   125000000          0     0  50000
          eth_gmii_sel                1        1        0   125000000          0     0  50000
       cb_net1_d8                     0        0        0   312500000          0     0  50000
       net1_d8_d2                     1        1        0   156250000          0     0  50000
          sysaxi_sel                  2        2        0   156250000          0     0  50000
             sysaxi                   4        4        0   156250000          0     0  50000
                infra_133m_hck        2        2        0   156250000          0     0  50000
                   infra_66m_phck       2        2        0   156250000          0     0  50000
                      infra_66m_aud_slv_bck       0        0        0   156250000          0     0  50000
                      infra_66m_msdc_0_hck       1        1        0   156250000          0     0  50000
                      infra_hf_i2c_x16w_pck_ck_p1       0        0        0   156250000          0     0  50000
                      infra_66m_usb_hck       0        0        0   156250000          0     0  50000
                      infra_66m_usb_hck_ck_p1       1        1        0   156250000          0     0  50000
                   infra_133m_phck       4        4        0   156250000          0     0  50000
                      infra_133m_usb_hck       0        0        0   156250000          0     0  50000
                      infra_133m_usb_hck_ck_p1       1        1        0   156250000          0     0  50000
                      infra_133m_pcie_ck_p0       1        1        0   156250000          0     0  50000
                      infra_133m_pcie_ck_p1       1        1        0   156250000          0     0  50000
                      infra_133m_pcie_ck_p2       0        0        0   156250000          0     0  50000
                      infra_133m_pcie_ck_p3       1        1        0   156250000          0     0  50000
                infra_peri_133m       1        1        0   156250000          0     0  50000
                   infra_hf_133m_msdc_0_hck       1        1        0   156250000          0     0  50000
                infra_133m_mck        1        1        0   156250000          0     0  50000
                   infra_hf_133m_cqdma_bck       0        0        0   156250000          0     0  50000
                   infra_hf_133m_dbg_ackm       1        1        0   156250000          0     0  50000
                   infra_hf_133m_cpum_bck       0        0        0   156250000          0     0  50000
                   infra_hf_i2c_x16w_mck_ck_p1       0        0        0   156250000          0     0  50000
                infra_66m_mck         1        1        0   156250000          0     0  50000
                   infra_hf_66m_gpt_bck       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_hck       0        0        0   156250000          0     0  50000
                   infra_66m_ap_dma_bck       0        0        0   156250000          0     0  50000
                   infra_hf_66m_sej_bck       0        0        0   156250000          0     0  50000
                   infra_hf_66m_nfi_hck       1        1        0   156250000          0     0  50000
                   infra_hf_66m_spi0_hck       0        0        0   156250000          0     0  50000
                   infra_hf_66m_spi1_hck       0        0        0   156250000          0     0  50000
                   infra_hf_66m_spi2_hck       0        0        0   156250000          0     0  50000
                   infra_hf_66m_flashif_axi       0        0        0   156250000          0     0  50000
                infra_peri_66m_o       0        0        0   156250000          0     0  50000
          pwm_sel                     0        0        0   156250000          0     0  50000
             infra_pwm_o              0        0        0   156250000          0     0  50000
                infra_pwm_sel         0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_bck       0        0        0   156250000          0     0  50000
                infra_pwm_ck1_sel       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_ck1       0        0        0   156250000          0     0  50000
                infra_pwm_ck2_sel       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_ck2       0        0        0   156250000          0     0  50000
                infra_pwm_ck3_sel       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_ck3       0        0        0   156250000          0     0  50000
                infra_pwm_ck4_sel       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_ck4       0        0        0   156250000          0     0  50000
                infra_pwm_ck5_sel       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_ck5       0        0        0   156250000          0     0  50000
                infra_pwm_ck6_sel       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_ck6       0        0        0   156250000          0     0  50000
                infra_pwm_ck7_sel       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_ck7       0        0        0   156250000          0     0  50000
                infra_pwm_ck8_sel       0        0        0   156250000          0     0  50000
                   infra_hf_66m_pwm_ck8       0        0        0   156250000          0     0  50000
          axi_infra_sel               0        0        0   156250000          0     0  50000
       net1_d8_d4                     4        4        0    78125000          0     0  50000
          sgm_sbus_1_sel              1        1        0    78125000          0     0  50000
          sgm_sbus_0_sel              1        1        0    78125000          0     0  50000
          usxgmii_sbus_1_sel          1        1        0    78125000          0     0  50000
          usxgmii_sbus_0_sel          1        1        0    78125000          0     0  50000
       net1_d8_d8                     1        1        0    39062500          0     0  50000
          eth_xgmii_sel               1        1        0    39062500          0     0  50000
       net1_d8_d16                    0        0        0    19531250          0     0  50000
    apll2                             0        0        0   196608000          0     0  50000
       cb_apll2_196m                  0        0        0   196608000          0     0  50000
          aud_l_sel                   0        0        0   196608000          0     0  50000
             aud_l                    0        0        0   196608000          0     0  50000
                infra_faud_l_o        0        0        0   196608000          0     0  50000
                   infra_f_faud_l       0        0        0   196608000          0     0  50000
          aud_sel                     0        0        0   196608000          0     0  50000
             aud                      0        0        0   196608000          0     0  50000
                aud_i2s_m             0        0        0    24576000          0     0  50000
       cb_apll2_d4                    0        0        0    49152000          0     0  50000
          a_tuner_sel                 0        0        0    49152000          0     0  50000
             a_tuner                  0        0        0    49152000          0     0  50000
                infra_faud_eg2_o       0        0        0    49152000          0     0  50000
                   infra_f_faud_eg2       0        0        0    49152000          0     0  50000
          a1sys_sel                   0        0        0    49152000          0     0  50000
             a1sys                    0        0        0    49152000          0     0  50000
                infra_faud_aud_o       0        0        0    49152000          0     0  50000
                   infra_f_aud_aud       0        0        0    49152000          0     0  50000
    mmpll                             2        2        0   720000000          0     0  50000
       cb_mm_720m                     1        1        0   720000000          0     0  50000
          netsys_pao_2x_sel           1        1        0   720000000          0     0  50000
       cb_mm_d2                       0        0        0   360000000          0     0  50000
       cb_mm_d3_d5                    2        2        0    48000000          0     0  50000
          usb_frmcnt_p1_sel           1        1        0    48000000          0     0  50000
             usb_frmcnt_p1            1        1        0    48000000          0     0  50000
                infra_usb_frmcnt_o_p1       1        1        0    48000000          0     0  50000
                   infra_usb_frmcnt_ck_p1       1        1        0    48000000          0     0  50000
          usb_frmcnt_sel              1        1        0    48000000          0     0  50000
             usb_frmcnt               1        1        0    48000000          0     0  50000
                infra_usb_frmcnt_o       1        1        0    48000000          0     0  50000
                   infra_usb_frmcnt       1        1        0    48000000          0     0  50000
       cb_mm_d4                       0        0        0   180000000          0     0  50000
          nfi1x_sel                   0        0        0   180000000          0     0  50000
             nfi1x                    0        0        0   180000000          0     0  50000
                infra_nfi_o           0        0        0   180000000          0     0  50000
                   infra_f_fnfi       0        0        0   180000000          0     0  50000
                   infra_hf_fbist2fpc       0        0        0   180000000          0     0  50000
       mm_d6_d2                       0        0        0    60000000          0     0  50000
       cb_mm_d8                       0        0        0    90000000          0     0  50000
    mpll                              3        3        0   416000000          0     0  50000
       cb_m_416m                      0        0        0   416000000          0     0  50000
       cb_m_d2                        1        1        0   208000000          0     0  50000
          dramc_md32_sel              1        1        0   208000000          0     0  50000
          spim_mst_sel                0        0        0   208000000          0     0  50000
             spim_mst                 0        0        0   208000000          0     0  50000
                infra_spi1_o          0        0        0   208000000          0     0  50000
                   infra_mux_spi1_sel       0        0        0   208000000          0     0  50000
                      infra_hf_104m_spi1       0        0        0   208000000          0     0  50000
          spi_sel                     0        0        0   208000000          0     0  50000
             spi                      0        0        0   208000000          0     0  50000
                infra_spi0_o          0        0        0   208000000          0     0  50000
                   infra_mux_spi0_sel       0        0        0   208000000          0     0  50000
                      infra_hf_104m_spi0       0        0        0   208000000          0     0  50000
                   infra_mux_spi2_sel       0        0        0   208000000          0     0  50000
                      infra_hf_104m_spi2_bck       0        0        0   208000000          0     0  50000
       m_d3_d2                        1        1        0   208000000          0     0  50000
          sysapb_sel                  1        1        0   208000000          0     0  50000
       cb_m_d4                        0        0        0   104000000          0     0  50000
       cb_m_d8                        0        0        0    52000000          0     0  50000
       m_d8_d2                        9        9        0    26000000          0     0  50000
          tops_p2_26m_sel             0        0        0    26000000          0     0  50000
          pextp_p3_sel                1        1        0    26000000          0     0  50000
          pextp_p2_sel                1        1        0    26000000          0     0  50000
          pextp_p1_sel                1        1        0    26000000          0     0  50000
          pextp_p0_sel                1        1        0    26000000          0     0  50000
          csw_infra_f26m_sel          3        3        0    26000000          0     0  50000
             infra_ck_f26m            1        1        0    26000000          0     0  50000
                infra_f_faud_26m       0        0        0    26000000          0     0  50000
                infra_dramc_f26m       0        0        0    26000000          0     0  50000
                infra_pre_ck_sej_f13m       0        0        0    26000000          0     0  50000
                infra_hf_26m_therm_system       1        1        0    26000000          0     0  50000
             csw_infra_f26m           1        1        0    26000000          0     0  50000
                infra_f26m_o0         3        3        0    26000000          0     0  50000
                   infra_pcie_peri_ck_26m_ck_p0       1        1        0    26000000          0     0  50000
                   infra_pcie_peri_ck_26m_ck_p1       1        1        0    26000000          0     0  50000
                   infra_pcie_peri_ck_26m_ck_p2       0        0        0    26000000          0     0  50000
                   infra_pcie_peri_ck_26m_ck_p3       2        2        0    26000000          0     0  50000
                infra_f26m_o1         0        0        0    26000000          0     0  50000
                   infra_f_26m_adc_bck       0        0        0    26000000          0     0  50000
                      infra_f_frc_adc       0        0        0    26000000          0     0  50000
          dramc_sel                   1        1        0    26000000          0     0  50000
          xfi_phy_1_xtal_sel          1        1        0    26000000          0     0  50000
          xfi_phy_0_xtal_sel          1        1        0    26000000          0     0  50000
          usb_phy_sel                 1        1        0    26000000          0     0  50000
             infra_usb_pipe_o_p1       1        1        0    26000000          0     0  50000
                infra_usb_pipe_ck_p1       1        1        0    26000000          0     0  50000
          sspxtp_sel                  0        0        0    26000000          0     0  50000
             infra_usb_pipe_o         0        0        0    26000000          0     0  50000
                infra_usb_pipe        0        0        0    26000000          0     0  50000
    netsyspll                         1        1        0   850000000          0     0  50000
       cb_netsys_850m                 1        1        0   850000000          0     0  50000
          eip197_sel                  1        1        0   850000000          0     0  50000
             eip197                   1        1        0   850000000          0     0  50000
                ethdma_crypt0_en       1        1        0   850000000          0     0  50000
    cksq_src                          1        1        0    40000000          0     0  50000
       usb_ck_p1                      1        1        0    40000000          0     0  50000
          infra_usb_o_p1              1        1        0    40000000          0     0  50000
             infra_usb_ck_p1          1        1        0    40000000          0     0  50000
       usb_ref                        0        0        0    40000000          0     0  50000
          infra_usb_o                 0        0        0    40000000          0     0  50000
             infra_usb_ref            0        0        0    40000000          0     0  50000
    cb_cksq_40m                       2        2        0    40000000          0     0  50000
       uart_sel                       1        1        0    40000000          0     0  50000
          infra_uart_o0               1        1        0    40000000          0     0  50000
             infra_mux_uart0_sel       1        1        0    40000000          0     0  50000
                infra_f_52m_uart0       1        1        0    40000000          0     0  50000
          infra_uart_o1               0        0        0    40000000          0     0  50000
             infra_mux_uart1_sel       0        0        0    40000000          0     0  50000
                infra_f_52m_uart1       0        0        0    40000000          0     0  50000
          infra_uart_o2               0        0        0    40000000          0     0  50000
             infra_mux_uart2_sel       0        0        0    40000000          0     0  50000
                infra_f_52m_uart2       0        0        0    40000000          0     0  50000
       cb_rtc_32p7k                   0        0        0       32786          0     0  50000
          csw_infra_f32k              0        0        0       32786          0     0  50000
       cb_rtc_32k                     1        1        0       32000          0     0  50000
          infra_frtc                  1        1        0       32000          0     0  50000
             infra_lb_mux_frtc        1        1        0       32000          0     0  50000
                infra_f_frtc          1        1        0       32000          0     0  50000
       cksq_40m_d2                    0        0        0    20000000          0     0  50000
          pextp_sel                   0        0        0    20000000          0     0  50000
          da_selm_xtal_sel            0        0        0    20000000          0     0  50000
          ckm_sel                     0        0        0    20000000          0     0  50000
    infra_pcie_pipe_ck_occ_p3         1        1        0    40000000          0     0  50000
       infra_pcie_pipe_ck_p3          1        1        0    40000000          0     0  50000
    infra_pcie_pipe_ck_occ_p2         0        0        0    40000000          0     0  50000
       infra_pcie_pipe_ck_p2          0        0        0    40000000          0     0  50000
    infra_pcie_pipe_ck_occ_p1         1        1        0    40000000          0     0  50000
       infra_pcie_pipe_ck_p1          1        1        0    40000000          0     0  50000
    infra_pcie_pipe_ck_occ_p0         1        1        0    40000000          0     0  50000
       infra_pcie_pipe_ck_p0          1        1        0    40000000          0     0  50000
    infra_usb_utmi_o_p1               1        1        0    40000000          0     0  50000
       infra_usb_utmi_ck_p1           1        1        0    40000000          0     0  50000
    infra_usb_utmi_o                  0        0        0    40000000          0     0  50000
       infra_usb_utmi                 0        0        0    40000000          0     0  50000
    ethdma_xgp1_en                    1        1        0    40000000          0     0  50000
    ethdma_xgp2_en                    1        1        0    40000000          0     0  50000
    ethdma_xgp3_en                    1        1        0    40000000          0     0  50000
    ethdma_gp2_en                     1        1        0    40000000          0     0  50000
    ethdma_gp1_en                     1        1        0    40000000          0     0  50000
    ethdma_gp3_en                     1        1        0    40000000          0     0  50000
    sgm0_tx_en                        1        1        0    40000000          0     0  50000
    sgm0_rx_en                        1        1        0    40000000          0     0  50000
    sgm1_tx_en                        1        1        0    40000000          0     0  50000
    sgm1_rx_en                        1        1        0    40000000          0     0  50000
 dummy_system_clk                     0        0        0    40000000          0     0  50000
root@OpenWrt:~#
Are you sure key-b slot is working before you’ve done clk_summary? The pcie p2 clocks are unused in your output
Installed the card into the slot this time…
    msdcpll                           0        0        0   400000000          0     0  50000
       cb_msdc_400m                   0        0        0   400000000          0     0  50000
          emmc_400m_sel               0        0        0   400000000          0     0  50000
             emmc_400m                0        0        0   400000000          0     0  50000
                infra_fmsdc400_o       0        0        0   400000000          0     0  50000
                   infra_f_fmsdc400       0        0        0   400000000          0     0  50000
       cb_net2_d6                     4        4        0   133333333          0     0  50000
          pextp_tl_ck_p2_sel          1        1        0   133333333          0     0  50000
             infra_pcie_ck_occ_p2       1        1        0   133333333          0     0  50000
                infra_pcie_gfmux_tl_o_p2_sel       1        1        0   133333333          0     0  50000
                   infra_pcie_gfmux_tl_ck_p2       1        1        0   133333333          0     0  50000
       net1_d5_d2                     3        3        0   250000000          0     0  50000
          emmc_250m_sel               0        0        0   250000000          0     0  50000
             emmc_250m                0        0        0   250000000          0     0  50000
                infra_fmsdc2_hck_occ       0        0        0   250000000          0     0  50000
                   infra_f_fmsdc2_hck       0        0        0   250000000          0     0  50000
             sysaxi                   3        3        0   156250000          0     0  50000
                   infra_66m_phck       1        1        0   156250000          0     0  50000
                      infra_66m_msdc_0_hck       0        0        0   156250000          0     0  50000
                   infra_133m_phck       5        5        0   156250000          0     0  50000
                      infra_133m_pcie_ck_p2       1        1        0   156250000          0     0  50000
                infra_peri_133m       0        0        0   156250000          0     0  50000
                   infra_hf_133m_msdc_0_hck       0        0        0   156250000          0     0  50000
       m_d8_d2                       10       10        0    26000000          0     0  50000
                infra_f26m_o0         4        4        0    26000000          0     0  50000
                   infra_pcie_peri_ck_26m_ck_p2       1        1        0    26000000          0     0  50000
          sspxtp_sel                  1        1        0    26000000          0     0  50000
             infra_usb_pipe_o         1        1        0    26000000          0     0  50000
                infra_usb_pipe        1        1        0    26000000          0     0  50000
    infra_pcie_pipe_ck_occ_p2         1        1        0    40000000          0     0  50000
       infra_pcie_pipe_ck_p2          1        1        0    40000000          0     0  50000
root@OpenWrt:~# lspci -v
0000:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01) (prog-if 00 [Normal decode])
        Device tree node: /sys/firmware/devicetree/base/pcie@11300000/pcie@0,0
        Flags: fast devsel
        Memory at 30300000 (64-bit, non-prefetchable) [disabled] [size=32K]
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: [disabled] [32-bit]
        Memory behind bridge: 30200000-302fffff [size=1M] [32-bit]
        Prefetchable memory behind bridge: [disabled] [64-bit]
        Capabilities: [80] Express Root Port (Slot-), MSI 00
        Capabilities: [e0] MSI: Enable- Count=1/32 Maskable+ 64bit+
        Capabilities: [f8] Power Management version 3
        Capabilities: [100] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
        Capabilities: [110] L1 PM Substates
        Capabilities: [200] Advanced Error Reporting
        Capabilities: [300] Secondary PCI Express
lspci: Unable to load libkmod resources: error -12
0000:01:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
        Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
        Device tree node: /sys/firmware/devicetree/base/pcie@11300000/pcie@0,0/mt7996@0,0
        Flags: fast devsel
        Memory at 30200000 (64-bit, non-prefetchable) [disabled] [size=16K]
        Capabilities: [c8] Power Management version 3
        Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [40] Express Endpoint, MSI 00
        Capabilities: [80] MSI-X: Enable- Count=16 Masked-
        Capabilities: [14c] Latency Tolerance Reporting
        Capabilities: [154] L1 PM Substates
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01) (prog-if 00 [Normal decode])
        Device tree node: /sys/firmware/devicetree/base/pcie@11310000/pcie@0,0
        Flags: fast devsel
        Memory at 38500000 (64-bit, non-prefetchable) [disabled] [size=32K]
        Memory behind bridge: 38200000-382fffff [size=1M] [32-bit]
        Prefetchable memory behind bridge: 38300000-384fffff [size=2M] [32-bit]
0001:01:00.0 Network controller: MEDIATEK Corp. Device 7906
        Subsystem: MEDIATEK Corp. Device 7906
        Flags: fast devsel
        Memory at 38300000 (64-bit, prefetchable) [disabled] [size=1M]
        Memory at 38200000 (64-bit, non-prefetchable) [disabled] [size=32K]
        Memory at 38400000 (64-bit, prefetchable) [disabled] [size=4K]
        Capabilities: [80] Express Endpoint, MSI 00
        Capabilities: [108] Latency Tolerance Reporting
0002:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0
        Memory at 28300000 (64-bit, non-prefetchable) [size=32K]
        Memory behind bridge: 28200000-282fffff [size=1M] [32-bit]
0002:01:00.0 Non-Volatile memory controller: Device 1ed0:2283 (rev 01) (prog-if 02 [NVM Express])
        Subsystem: Device 1ed0:2283
        Flags: bus master, fast devsel, latency 0, IRQ 123
        Memory at 28210000 (64-bit, non-prefetchable) [size=16K]
        Expansion ROM at 28200000 [virtual] [disabled] [size=64K]
        Capabilities: [d0] MSI-X: Enable+ Count=9 Masked-
        Capabilities: [e0] MSI: Enable- Count=1/8 Maskable+ 64bit+
        Capabilities: [100] Latency Tolerance Reporting
        Capabilities: [140] Single Root I/O Virtualization (SR-IOV)
        Kernel driver in use: nvme
0003:00:00.0 PCI bridge: MEDIATEK Corp. Device 7988 (rev 01) (prog-if 00 [Normal decode])
        Flags: fast devsel
        Memory at 20300000 (64-bit, non-prefetchable) [disabled] [size=32K]
        Memory behind bridge: 20200000-202fffff [size=1M] [32-bit]
0003:01:00.0 Unassigned class [ff00]: Foxconn International, Inc. Device e0af
        Flags: fast devsel
0004:00:00.0 Unclassified device [0002]: MEDIATEK Corp. Device 7981 (prog-if 80)
        Subsystem: Device 7622:14c3
        Flags: bus master, fast devsel, latency 0, IRQ 117
        Memory at 18000000 (64-bit, non-prefetchable) [size=16M]
        Memory at <unassigned> (32-bit, non-prefetchable) [size=16]
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [78] Power Management version 3
I have similar issue with Intel BE200 (which is working normally on bpi-r64 according to the commit autor - linux-firmware: intel: add BE200 wifi firmware · openwrt/openwrt@a56292d · GitHub ) and Mini PCI-E to M.2 key E - it does not recognize the Intel card (dmesg/lspci - all is empty).
I will paste also the clk_summary (base on kernel 6.6), maybe it will help somehow:
root@BPI-R4:~# cat /sys/kernel/debug/clk/clk_summary
                                 enable  prepare  protect                                duty  hardware
   clock                          count    count    count        rate   accuracy phase  cycle    enable
 clkxtal                              9        9        0    40000000          0     0  50000         Y
    top_xtal                         16       16        0    40000000          0     0  50000         Y
       xfipll_pll                     1        1        0   156250000          0     0  50000         Y
          xfipll_pll_en               2        2        0   156250000          0     0  50000         Y
       ethdma_gp3_en                  1        1        0    40000000          0     0  50000         Y
       ethdma_gp1_en                  1        1        0    40000000          0     0  50000         Y
       ethdma_gp2_en                  1        1        0    40000000          0     0  50000         Y
       ethdma_xgp3_en                 1        1        0    40000000          0     0  50000         Y
       ethdma_xgp2_en                 1        1        0    40000000          0     0  50000         Y
       ethdma_xgp1_en                 1        1        0    40000000          0     0  50000         Y
       sgm1_rx_en                     0        0        0    40000000          0     0  50000         N
       sgm1_tx_en                     0        0        0    40000000          0     0  50000         N
       sgm0_rx_en                     1        1        0    40000000          0     0  50000         Y
       sgm0_tx_en                     1        1        0    40000000          0     0  50000         Y
       infra_pcie_pipe_ck_p3          0        0        0    40000000          0     0  50000         N
       infra_pcie_pipe_ck_p2          0        0        0    40000000          0     0  50000         N
       infra_pcie_pipe_ck_p1          1        1        0    40000000          0     0  50000         Y
       infra_pcie_pipe_ck_p0          1        1        0    40000000          0     0  50000         Y
       infra_usb_utmi_ck_p1           1        1        0    40000000          0     0  50000         Y
       infra_usb_utmi                 0        0        0    40000000          0     0  50000         N
       infra_usb_ck_p1                1        1        0    40000000          0     0  50000         Y
       infra_usb_ref                  0        0        0    40000000          0     0  50000         N
       uart_sel                       1        1        0    40000000          0     0  50000         Y
          infra_mux_uart2_sel         0        0        0    40000000          0     0  50000         Y
             infra_f_52m_uart2        0        0        0    40000000          0     0  50000         N
          infra_mux_uart1_sel         0        0        0    40000000          0     0  50000         Y
             infra_f_52m_uart1        0        0        0    40000000          0     0  50000         N
          infra_mux_uart0_sel         1        1        0    40000000          0     0  50000         Y
             infra_f_52m_uart0        1        1        0    40000000          0     0  50000         Y
       top_rtc_32p7k                  0        0        0       32786          0     0  50000         Y
       top_rtc_32k                    1        1        0       32000          0     0  50000         Y
          infra_f_frtc                1        1        0       32000          0     0  50000         Y
       top_xtal_d2                    0        0        0    20000000          0     0  50000         Y
          pextp_sel                   0        0        0    20000000          0     0  50000         N
          da_sel                      0        0        0    20000000          0     0  50000         N
          ckm_sel                     0        0        0    20000000          0     0  50000         N
    msdcpll                           0        0        0   400000000          0     0  50000         Y
       emmc_400m_sel                  0        0        0   400000000          0     0  50000         N
          infra_f_fmsdc400            0        0        0   400000000          0     0  50000         N
    usxgmiipll                        0        0        0   644531250          0     0  50000         Y
    ccipll2_b                         1        1        0   900000000          0     0  50000         Y
       mcu_bus_div_sel                1        1        0   900000000          0     0  50000         Y
    arm_b                             2        2        0   800000000          0     0  50000         Y
       mcu_arm_div_sel                2        2        0   800000000          0     0  50000         Y
    sgmpll                            2        2        0   325000000          0     0  50000         Y
       macsec_sel                     0        0        0   325000000          0     0  50000         N
       sgm_1_sel                      1        1        0   325000000          0     0  50000         Y
       sgm_0_sel                      1        1        0   325000000          0     0  50000         Y
    wedmcupll                         0        0        0   208000000          0     0  50000         Y
    net2pll                           8        8        0   800000000          0     0  50000         Y
       ck_npu_sel                     0        0        0   800000000          0     0  50000         N
       npu_tops_sel                   0        0        0   800000000          0     0  50000         N
       netsys_mcu_sel                 3        3        0   800000000          0     0  50000         Y
          ethwarp_wocpu0_en           1        1        0   800000000          0     0  50000         Y
          ethwarp_wocpu1_en           1        1        0   800000000          0     0  50000         Y
          ethwarp_wocpu2_en           1        1        0   800000000          0     0  50000         Y
       netsys_2x_sel                  1        1        0   800000000          0     0  50000         Y
          ethdma_fe_en                1        1        0   800000000          0     0  50000         Y
       net2pll_d8                     0        0        0   100000000          0     0  50000         Y
          da_xtp_glb_p3_sel           0        0        0   100000000          0     0  50000         N
          da_xtp_glb_p2_sel           0        0        0   100000000          0     0  50000         N
          da_xtp_glb_p1_sel           0        0        0   100000000          0     0  50000         N
          da_xtp_glb_p0_sel           0        0        0   100000000          0     0  50000         N
       net2pll_d6                     2        2        0   133333333          0     0  50000         Y
          pextp_tl_p3_sel             0        0        0   133333333          0     0  50000         N
             infra_pcie_gfmux_tl_o_p3_sel       0        0        0   133333333          0     0  50000         Y
                infra_pcie_gfmux_tl_ck_p3       0        0        0   133333333          0     0  50000         N
          pextp_tl_p2_sel             0        0        0   133333333          0     0  50000         N
             infra_pcie_gfmux_tl_o_p2_sel       0        0        0   133333333          0     0  50000         Y
                infra_pcie_gfmux_tl_ck_p2       0        0        0   133333333          0     0  50000         N
          pextp_tl_p1_sel             1        1        0   133333333          0     0  50000         Y
             infra_pcie_gfmux_tl_o_p1_sel       1        1        0   133333333          0     0  50000         Y
                infra_pcie_gfmux_tl_ck_p1       1        1        0   133333333          0     0  50000         Y
          pextp_tl_sel                1        1        0   133333333          0     0  50000         Y
             infra_pcie_gfmux_tl_o_p0_sel       1        1        0   133333333          0     0  50000         Y
                infra_pcie_gfmux_tl_ck_p0       1        1        0   133333333          0     0  50000         Y
       net2pll_d4_d8                  1        1        0    25000000          0     0  50000         Y
          eth_mii_sel                 1        1        0    25000000          0     0  50000         Y
       net2pll_d4_d4                  1        1        0    50000000          0     0  50000         Y
          eth_refck_50m_sel           1        1        0    50000000          0     0  50000         Y
       net2pll_d4                     1        1        0   200000000          0     0  50000         Y
          eth_sys_200m_sel            1        1        0   200000000          0     0  50000         Y
       net2pll_d2                     2        2        0   400000000          0     0  50000         Y
          netsys_warp_sel             1        1        0   400000000          0     0  50000         Y
          netsys_tops_400m_sel        0        0        0   400000000          0     0  50000         N
          netsys_sel                  1        1        0   400000000          0     0  50000         Y
    net1pll                           7        7        0  2500000000          0     0  50000         Y
       net1pll_d8_d16                 0        0        0    19531250          0     0  50000         Y
       net1pll_d8_d8                  1        1        0    39062500          0     0  50000         Y
          eth_xgmii_sel               1        1        0    39062500          0     0  50000         Y
       net1pll_d8_d4                  4        4        0    78125000          0     0  50000         Y
          sgm_sbus_1_sel              1        1        0    78125000          0     0  50000         Y
          sgm_sbus_0_sel              1        1        0    78125000          0     0  50000         Y
          usxgmii_sbus_1_sel          1        1        0    78125000          0     0  50000         Y
          usxgmii_sbus_0_sel          1        1        0    78125000          0     0  50000         Y
       net1pll_d8_d2                  2        2        0   156250000          0     0  50000         Y
          sysaxi_sel                  8        9        0   156250000          0     0  50000         Y
             infra_133m_pcie_ck_p3       0        0        0   156250000          0     0  50000         N
             infra_133m_pcie_ck_p2       0        0        0   156250000          0     0  50000         N
             infra_133m_pcie_ck_p1       1        1        0   156250000          0     0  50000         Y
             infra_133m_pcie_ck_p0       1        1        0   156250000          0     0  50000         Y
             infra_66m_usb_hck_ck_p1       1        1        0   156250000          0     0  50000         Y
             infra_66m_usb_hck        0        0        0   156250000          0     0  50000         N
             infra_133m_usb_hck_ck_p1       1        1        0   156250000          0     0  50000         Y
             infra_133m_usb_hck       0        0        0   156250000          0     0  50000         N
             infra_hf_i2c_x16w_pck_ck_p1       0        0        0   156250000          0     0  50000         N
             infra_hf_i2c_x16w_mck_ck_p1       0        0        0   156250000          0     0  50000         N
             infra_hf_133m_cpum_bck       0        0        0   156250000          0     0  50000         N
             infra_66m_msdc_0_hck       0        0        0   156250000          0     0  50000         N
             infra_hf_133m_msdc_0_hck       0        0        0   156250000          0     0  50000         N
             infra_hf_66m_flashif_axi       0        0        0   156250000          0     0  50000         N
             infra_hf_66m_spi2_hck       0        0        0   156250000          0     0  50000         N
             infra_hf_66m_spi1_hck       0        0        0   156250000          0     0  50000         N
             infra_hf_66m_spi0_hck       1        1        0   156250000          0     0  50000         Y
             infra_hf_66m_nfi_hck       1        1        0   156250000          0     0  50000         Y
             infra_hf_66m_sej_bck       0        0        0   156250000          0     0  50000         N
             infra_66m_ap_dma_bck       0        2        0   156250000          0     0  50000         N
             infra_hf_133m_dbg_ackm       1        1        0   156250000          0     0  50000         Y
             infra_66m_aud_slv_bck       0        0        0   156250000          0     0  50000         N
             infra_hf_133m_cqdma_bck       0        0        0   156250000          0     0  50000         N
             infra_hf_66m_pwm_hck       0        0        0   156250000          0     0  50000         N
             infra_hf_66m_gpt_bck       0        0        0   156250000          0     0  50000         N
          pwm_sel                     0        0        0   156250000          0     0  50000         N
             infra_pwm_ck8_sel        0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_ck8       0        0        0   156250000          0     0  50000         N
             infra_pwm_ck7_sel        0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_ck7       0        0        0   156250000          0     0  50000         N
             infra_pwm_ck6_sel        0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_ck6       0        0        0   156250000          0     0  50000         N
             infra_pwm_ck5_sel        0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_ck5       0        0        0   156250000          0     0  50000         N
             infra_pwm_ck4_sel        0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_ck4       0        0        0   156250000          0     0  50000         N
             infra_pwm_ck3_sel        0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_ck3       0        0        0   156250000          0     0  50000         N
             infra_pwm_ck2_sel        0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_ck2       0        0        0   156250000          0     0  50000         N
             infra_pwm_ck1_sel        0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_ck1       0        0        0   156250000          0     0  50000         N
             infra_pwm_sel            0        0        0   156250000          0     0  50000         Y
                infra_hf_66m_pwm_bck       0        0        0   156250000          0     0  50000         N
          axi_infra_sel               1        1        0   156250000          0     0  50000         Y
       net1pll_d8                     0        0        0   312500000          0     0  50000         Y
       net1pll_d5_d4                  3        4        0   125000000          0     0  50000         Y
          usb_xhci_p1_sel             1        1        0   125000000          0     0  50000         Y
             infra_usb_xhci_ck_p1       1        1        0   125000000          0     0  50000         Y
          usb_xhci_sel                0        0        0   125000000          0     0  50000         N
             infra_usb_xhci           0        0        0   125000000          0     0  50000         N
          usb_sys_p1_sel              1        1        0   125000000          0     0  50000         Y
             infra_usb_sys_ck_p1       1        1        0   125000000          0     0  50000         Y
          usb_sys_sel                 0        0        0   125000000          0     0  50000         N
             infra_usb_sys            0        0        0   125000000          0     0  50000         N
          i2c_sel                     0        1        0   125000000          0     0  50000         N
             infra_i2c_bck            0        2        0   125000000          0     0  50000         N
          spinfi_sel                  0        0        0   125000000          0     0  50000         N
             infra_f_fspinfi          0        0        0   125000000          0     0  50000         N
          eth_gmii_sel                1        1        0   125000000          0     0  50000         Y
       net1pll_d5_d2                  3        3        0   250000000          0     0  50000         Y
          netsys_ppefb_250m_sel       1        1        0   250000000          0     0  50000         Y
          netsys_sync_250m_sel        1        1        0   250000000          0     0  50000         Y
          eth_sys_sel                 1        1        0   250000000          0     0  50000         Y
          pcie_mbist_250m_sel         0        0        0   250000000          0     0  50000         N
          emmc_250m_sel               0        0        0   250000000          0     0  50000         N
             infra_f_fmsdc2_hck       0        0        0   250000000          0     0  50000         N
       net1pll_d5                     1        1        0   500000000          0     0  50000         Y
          bus_tops_sel                0        0        0   500000000          0     0  50000         N
          netsys_500m_sel             1        1        0   500000000          0     0  50000         Y
       net1pll_d4                     1        1        0   625000000          0     0  50000         Y
          mcusys_backup_625m_sel       0        0        0   625000000          0     0  50000         N
          netsys_gsw_sel              1        1        0   625000000          0     0  50000         Y
             ethdma_esw_en            1        1        0   625000000          0     0  50000         Y
    apll2                             0        0        0   196608000          0     0  50000         Y
       aud_l_sel                      0        0        0   196608000          0     0  50000         N
          infra_f_faud_l              0        0        0   196608000          0     0  50000         N
       aud_sel                        0        0        0   196608000          0     0  50000         N
          aud_i2s_m                   0        0        0    24576000          0     0  50000         N
       apll2_d4                       0        0        0    49152000          0     0  50000         Y
          a_tuner_sel                 0        0        0    49152000          0     0  50000         N
             infra_f_faud_eg2         0        0        0    49152000          0     0  50000         N
          a1sys_sel                   0        0        0    49152000          0     0  50000         N
             infra_f_aud_aud          0        0        0    49152000          0     0  50000         N
    mmpll                             2        2        0   720000000          0     0  50000         Y
       netsys_pao_2x_sel              1        1        0   720000000          0     0  50000         Y
       mmpll_d8                       0        0        0    90000000          0     0  50000         Y
       mmpll_d6_d2                    0        0        0    60000000          0     0  50000         Y
       mmpll_d4                       0        0        0   180000000          0     0  50000         Y
          nfi1x_sel                   0        0        0   180000000          0     0  50000         N
             infra_hf_fbist2fpc       0        0        0   180000000          0     0  50000         N
             infra_f_fnfi             0        0        0   180000000          0     0  50000         N
       mmpll_d3_d5                    2        2        0    48000000          0     0  50000         Y
          usb_frmcnt_p1_sel           1        1        0    48000000          0     0  50000         Y
             infra_usb_frmcnt_ck_p1       1        1        0    48000000          0     0  50000         Y
          usb_frmcnt_sel              1        1        0    48000000          0     0  50000         Y
             infra_usb_frmcnt         1        1        0    48000000          0     0  50000         Y
       mmpll_d2                       0        0        0   360000000          0     0  50000         Y
    mpll                              3        3        0   416000000          0     0  50000         Y
       mpll_d8_d2                     5        5        0    26000000          0     0  50000         Y
          tops_p2_26m_sel             0        0        0    26000000          0     0  50000         N
          pextp_p3_sel                0        0        0    26000000          0     0  50000         N
          pextp_p2_sel                0        0        0    26000000          0     0  50000         N
          pextp_p1_sel                0        0        0    26000000          0     0  50000         N
          pextp_p0_sel                0        0        0    26000000          0     0  50000         N
          csw_infra_f26m_sel          5        5        0    26000000          0     0  50000         Y
             infra_f_26m_adc_bck       0        0        0    26000000          0     0  50000         N
                infra_f_frc_adc       0        0        0    26000000          0     0  50000         N
             infra_hf_26m_therm_system       1        1        0    26000000          0     0  50000         Y
             infra_pre_ck_sej_f13m       0        0        0    26000000          0     0  50000         N
             infra_dramc_f26m         1        1        0    26000000          0     0  50000         Y
             infra_f_faud_26m         0        0        0    26000000          0     0  50000         N
             infra_pcie_peri_ck_26m_ck_p3       0        0        0    26000000          0     0  50000         N
             infra_pcie_peri_ck_26m_ck_p2       0        0        0    26000000          0     0  50000         N
             infra_pcie_peri_ck_26m_ck_p1       1        1        0    26000000          0     0  50000         Y
             infra_pcie_peri_ck_26m_ck_p0       1        1        0    26000000          0     0  50000         Y
          dramc_sel                   1        1        0    26000000          0     0  50000         Y
          xfi_phy_1_xtal_sel          1        1        0    26000000          0     0  50000         Y
          xfi_phy_0_xtal_sel          1        1        0    26000000          0     0  50000         Y
          usb_phy_sel                 1        1        0    26000000          0     0  50000         Y
             infra_usb_pipe_ck_p1       1        1        0    26000000          0     0  50000         Y
          sspxtp_sel                  0        0        0    26000000          0     0  50000         N
             infra_usb_pipe           0        0        0    26000000          0     0  50000         N
       mpll_d8                        0        0        0    52000000          0     0  50000         Y
       mpll_d4                        0        0        0   104000000          0     0  50000         Y
       mpll_d3_d2                     1        1        0   208000000          0     0  50000         Y
          sysapb_sel                  1        1        0   208000000          0     0  50000         Y
       mpll_d2                        2        2        0   208000000          0     0  50000         Y
          dramc_md32_sel              1        1        0   208000000          0     0  50000         Y
          spim_mst_sel                0        0        0   208000000          0     0  50000         N
             infra_mux_spi1_sel       0        0        0   208000000          0     0  50000         Y
                infra_hf_104m_spi1       0        0        0   208000000          0     0  50000         N
          spi_sel                     2        2        0   208000000          0     0  50000         Y
             infra_mux_spi2_sel       0        0        0   208000000          0     0  50000         Y
                infra_hf_104m_spi2_bck       0        0        0   208000000          0     0  50000         N
             infra_mux_spi0_sel       1        1        0   208000000          0     0  50000         Y
                infra_hf_104m_spi0       1        1        0   208000000          0     0  50000         Y
    netsyspll                         1        1        0   850000000          0     0  50000         Y
       eip197_sel                     1        1        0   850000000          0     0  50000         Y
          ethdma_crypt0_en            1        1        0   850000000          0     0  50000         Y
And again: the pci2 (ngff slot on top side of board) does not work yet with actual kernels in openwrt or from my repo…
Any news and dates about official case and wifi7 card? And about official openwrt realase? Thanks in advance!
Wifi Modul:
Wrong :frowning_face::
→ official openWRT realase:
→ openWRT release
Right :slightly_smiling_face::
→ official openWRT
https://firmware-selector.openwrt.org/?version=SNAPSHOT&target=mediatek%2Ffilogic&id=bananapi_bpi-r4
Not a release yet, just development/nightly snapshots. Release branch will be created in a few months, stable release including support for the R4 towards the end of the year probably.
Okay, I delated the “official”. Sometimes I’m a bit fast … thought snapshot should be clear … .
