mhm, seems the QOS-Options are already enabled
$ grep 'CONFIG_NET_SCH' ../build/.config
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
# CONFIG_NET_SCH_HFSC is not set
CONFIG_NET_SCH_PRIO=m
# CONFIG_NET_SCH_MULTIQ is not set
CONFIG_NET_SCH_RED=m
# CONFIG_NET_SCH_SFB is not set
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
# CONFIG_NET_SCH_CBS is not set
# CONFIG_NET_SCH_ETF is not set
# CONFIG_NET_SCH_TAPRIO is not set
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
# CONFIG_NET_SCH_NETEM is not set
# CONFIG_NET_SCH_DRR is not set
# CONFIG_NET_SCH_MQPRIO is not set
# CONFIG_NET_SCH_SKBPRIO is not set
# CONFIG_NET_SCH_CHOKE is not set
# CONFIG_NET_SCH_QFQ is not set
# CONFIG_NET_SCH_CODEL is not set
CONFIG_NET_SCH_FQ_CODEL=y
# CONFIG_NET_SCH_CAKE is not set
# CONFIG_NET_SCH_FQ is not set
# CONFIG_NET_SCH_HHF is not set
# CONFIG_NET_SCH_PIE is not set
CONFIG_NET_SCH_INGRESS=m
# CONFIG_NET_SCH_PLUG is not set
# CONFIG_NET_SCH_ETS is not set
CONFIG_NET_SCH_DEFAULT=y
CONFIG_NET_SCH_FIFO=y
wonder whats missing when you use my ubuntu-image
You could do this too in running system with zgrep and /proc/config.gz
i do not get an error when running tc command on my ubuntu-image with updated (changes for wifi) kernel
[email protected]:~# tc qdisc add dev wan handle ffff: ingress
[email protected]:~# lsmod
Module Size Used by
sch_ingress 16384 1
[email protected]:~# zgrep 'CONFIG_NET_SCH' /proc/config.gz
CONFIG_NET_SCHED=y
your output above does not look like my image…
