Any mPCIe module should work. I tried with Quectel EC-25 and Sierra Wireless EM8455 in NGFF->mPCIe adapter. Due to limitation of the mPCIe socket, only up to USB 2.0 speeds are supported, ie. it doesn’t make much sense to buy faster modems because the speed will anyway be limited to ~ 200MBit/s.
If you want faster (LTE Cat.12 or 5G) modem, you have to connect it via USB 3.0 or PCIe, both aren’t supported on the mPCIe slot of the R3 (which is USB2.0 + SIM only).
The SIM slot is hard-wired to the modem and doesn’t need anything special to work with OpenWrt. Just install luci-proto-qmi (recommended) or even luci-proto-modemmanager and things work out-of-the-box.
If you are inside the EU, ebay seller hebeda is probably the fastest and safest option. But you can just as well pick a suitable module on AliExpress. The best option is actually to wait for MT7916+MT7976 WiFi 6E modules to be available (because that will be 4T4R and support the hardware offloading features of MT7986 SoC)
hi every morning
i have one question
when i set openwrt and click save & apply button then use openwrt luci`s reboot
it is recovery to not set openwrt
how can i fix this bug? or operational problems?
After commit 9b482ee22f3f509880d2420652392971eef3211d (kernel: add more fixes for mtk_eth_soc), bridge is not working.
config device
option name 'bridge0'
option type 'bridge'
list ports 'lan1'
list ports 'lan2'
list ports 'lan3'
list ports 'lan4'
config interface 'lan'
option device 'bridge0'
option proto 'static'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option zone 'lan'
I can ping 192.168.1.1, but DHCP is not working and I can´t connect using SSH or HTTPS…
Started to receive these messages too:
[49483.757250] page_pool_release_retry() stalled pool shutdown 20 inflight 1206 sec
[49544.013741] page_pool_release_retry() stalled pool shutdown 20 inflight 1266 sec
[49604.266293] page_pool_release_retry() stalled pool shutdown 20 inflight 1327 sec
[49664.523107] page_pool_release_retry() stalled pool shutdown 20 inflight 1387 sec
[49724.789378] page_pool_release_retry() stalled pool shutdown 20 inflight 1447 sec
[49785.034781] page_pool_release_retry() stalled pool shutdown 20 inflight 1508 sec
[49845.291468] page_pool_release_retry() stalled pool shutdown 20 inflight 1568 sec
[49905.545321] page_pool_release_retry() stalled pool shutdown 20 inflight 1628 sec
[49965.801673] page_pool_release_retry() stalled pool shutdown 20 inflight 1688 sec
[50026.057952] page_pool_release_retry() stalled pool shutdown 20 inflight 1749 sec
[50086.313949] page_pool_release_retry() stalled pool shutdown 20 inflight 1809 sec
[50146.574644] page_pool_release_retry() stalled pool shutdown 20 inflight 1869 sec
[50206.828271] page_pool_release_retry() stalled pool shutdown 20 inflight 1930 sec
[50267.081913] page_pool_release_retry() stalled pool shutdown 20 inflight 1990 sec
[50327.338814] page_pool_release_retry() stalled pool shutdown 20 inflight 2050 sec
[50387.593781] page_pool_release_retry() stalled pool shutdown 20 inflight 2111 sec
[50447.851519] page_pool_release_retry() stalled pool shutdown 20 inflight 2171 sec
[50508.107949] page_pool_release_retry() stalled pool shutdown 20 inflight 2231 sec
[50568.361955] page_pool_release_retry() stalled pool shutdown 20 inflight 2292 sec
[50628.617148] page_pool_release_retry() stalled pool shutdown 20 inflight 2352 sec
[50688.872151] page_pool_release_retry() stalled pool shutdown 20 inflight 2412 sec
[50749.129896] page_pool_release_retry() stalled pool shutdown 20 inflight 2473 sec
[50809.382267] page_pool_release_retry() stalled pool shutdown 20 inflight 2533 sec
[50869.638402] page_pool_release_retry() stalled pool shutdown 20 inflight 2593 sec
[50929.892010] page_pool_release_retry() stalled pool shutdown 20 inflight 2654 sec
[50990.150322] page_pool_release_retry() stalled pool shutdown 20 inflight 2714 sec
[51050.406240] page_pool_release_retry() stalled pool shutdown 20 inflight 2774 sec
If I remove 732-14-net-ethernet-mtk_eth_soc-drop-generic-vlan-rx-offloa.patch it works again.
I will let the system run for some time to check if the messages are gone…
have you been able to get the MT7921K to work? i have the same card, with adapter and im running OpenWrt SNAPSHOT, r21335-e410833bdd but cannot see firmware or drivers anywhere?
root@OpenWrt:/# lspci -s 01:00.0 -v
01:00.0 Network controller: MEDIATEK Corp. RZ608 Wi-Fi 6E 80MHz
Subsystem: MEDIATEK Corp. RZ608 Wi-Fi 6E 80MHz
Flags: fast devsel
Memory at 20000000 (64-bit, prefetchable) [disabled] [size=1M]
Memory at 20100000 (64-bit, prefetchable) [disabled] [size=16K]
Memory at 20104000 (64-bit, prefetchable) [disabled] [size=4K]
Capabilities: [80] Express Endpoint, MSI 00
Capabilities: [e0] MSI: Enable- Count=1/32 Maskable+ 64bit+
Capabilities: [f8] Power Management version 3
Capabilities: [100] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
Capabilities: [108] Latency Tolerance Reporting
Capabilities: [110] L1 PM Substates
Capabilities: [200] Advanced Error Reporting
lspci: Unable to load libkmod resources: error -12
if i try and install kmod-mt7921e it says my kernel is not compatible, same for architecture
You have to update to most recent snapshot first. You can either download it from downloads.openwrt.org or use one of the semi-auto updater clients like luci-app-attendedsysupgrade or auc.
Try this:
opkg update
opkg install auc
auc
That should fast-forward you the most recent snapshot and subsequently allow to install kernel packages like kmod-mt7921e.
I noticed a wireless module using mini-PCIe interface, which seems to use the combination of MT7916AN+MT7976DN. If possible, can I trouble you to see if this module is compatible with BPI-R3.
Of course, it would be even better if Banana Pi officially launched an M.2 M-Key module that does not require an adapter board.
