Banana Pi BPI-R2 Pro smart router board with Rockchip RK3568 chip
@sinovoip can you fix this please? link goes to PMIC instead of Switch
btw. i have started some work in wiki/kernel/uboot
Banan Pi BPI-R2 Pro with Rockchip RK3568 chip design ,run Android test
Hello @lionwang
When will the samples be ready for developers?
Does pcie slot support 3A@3V3 on pcie? I ask because mt7915 wifi card needs this to run stable.
yes ,it support . However, the current pcie 3.3V is connected to the system, so as to avoid the impact of too much power on the system, the next version will be changed to independent power supply
not yet , we just sample hardware , we need fixed some issus ,and updtate hardware design,when ready ,will send sample out , now ,just frank got the sample version hardware.
Thanks, received board yesterday.
Can you give me the serial settings for debug-uart? the settings i tried seem not correct (got only garbage in minicom)
Edit: seems to be like rockchip has fixed setting of 1.5mbaud and my cp2102 does not support it,so i have ordered a cp2104
https://wiki.t-firefly.com/en/ROC-RK3328-PC/debug.html#choosing-a-usb-serial-adapter
please discuss with wei.zuo , he will help you.
do you have a shematic? i will need one to discuss with rockchip-people…currently discussing change of vccio6-supply which is 1v8 in evb, but 3v3 in your bsp.
which are differences to ref-board? so i can use evb-dts as base for r2pro and change only things needed
CH340 is much better
What can be done without a schematic though :stuck_out_tongue:
new sample ready:
Banana%20Pi%20BPI-R2%20Pro%20750
I guess 2 typos:
  • hdmi in (should be out)
  • usb-otg is named debug-uart.
Is mt7531 same as on r64 (only used port 5 with rgmii)? Would be nice if some more devs get the board.
Is rtc/reset now working? Any other changes like iodomain? Just want to be sure no damage happens if using my/your current config.
Would be nice to have the sw1 (for disabling emmc) reachable from outside (like power/reset).
1,yes,it is HDMI out 2,it use USB to uart ,not USB-otg , we use a USB-3.0 to burn .(top of 2 use 3.0 interface)
yes ,it is same as BPI-R64, but dirive need some time to do .
when we finished this hardware test ,can send sample to you ,thank you.
Thanks,i have previous version and imho makes more sense that other devs can test too.
Was iodomain changed?
adding switch driver should be no big part as most part is mainline.if using p5 rgmii init is ready to,imho only ethsys/mtk bindung needs to be reworked.
Send sample.
Looking forward to run opnsense on this minux MTK driver
Banana Pi BPI-R2 Pro Public sale,
Wow nice and I still waiting for development sample. Good luck.
please send mail to [email protected] check sample .
