Note : BPI-M2 Zero support allwinner H2+ chip and H3 chip . since 2022 , BPI-M2 zero default with H3 chip onboard .
Banana PI BPI-M2 Zero is the open source hardware platform,Banana PI BPI-M2 Zero is an quad core version of Banana Pi,it support WIFI on board. use Alliwnner H2+ chip on board. and mini size only 60mm*30mm, all ineter face same as Raspberry pi Zero W.
Banana Pi M2 Zero: Low-Cost, Quad Core SBC
Banana Pi BPI-M2 Zero series run Android,Debian linux,Ubuntu linux, Raspberry Pi image and others image. Banana PI PBI-M2 Zero hardware: 1Ghz ARM7 quad-core processor, 512M DDR3 SDRAM, and SDIO wifi module on board.
BPI-M2 zero Hardware interface:
BPI-M2 Zero hardware spec:
BPI-M2 Zero GPIO 定义:
Banana pi BPI-M2 Zero all size is same as Raspberry pi Zero W.
Banana Pi BPI-M2 Zero demo: 1080P video play , glmark2-es2 , wiringpi
wiki online documents :
http://wiki.banana-pi.org/Banana_Pi_BPI-M2_ZERO
banana pi BPI-M2 Zero VS raspberry pi zero W
for allwinner H2+ and H3 chip PIN to PIN compatibility , so BPI-M2+ Zero also can use H3 chip
onboard
