I have installed this image and it is working but I have 2 questions:
why are you using such an old kernel - 3.10.65? Will kernel be updated in your next img?
I have an issue with sunxi-bt. It is logging to syslog every 5 seconds āsunxi-bt bt: block state already is 0ā. Can you confirm this is an issue with the img? Any idea how to resolve it?
OK Thanks. Iām really not sure what to do with this board now. I think the only option for me (very limited skills!) is to wait for a better and more robust image.
Are there any other debian images that I can try or do i need to wait for another release here?
Thanks for the info. Silly to purchase this M2U without proper research first. On the positive, i have it running as a NAS. Itās been running for the last 5 days without too many issues. Just want to get rid of the 17,280 sunxi-bt error messages that are being logged every day!
@charles Thanks for your information.
I change frequency of memory to 576MHz in sys_config.fex, managed to compile the kernel and update my m2u with that kernel. I will see if the instability issue is solved. If solved, I will write a detailed post.
I am newbie, trying to install qt4 dev. tools on bananapi. During installation half of the way, i for this error message: ādpkg was interrupted, you must manually run 'sudo dpkg --configure -aāto correct the problem.ā I tried this too then i get the error: [dpkg: error: failed to open package info file /var/lib/dpkg/updates/0049 for reading: Input/output error]
Tried to remove the ā0049ā from the updates, but couldnāt.
uname -a give me this; Linux bpi-iot-ros-ai 3.10.65-BPI-M2U-Kernel #1 SMP Thu May 25 11:46:04 CST 2017 armv7l GNU/Linux
