Hi everyone,
I am trying for days to figure out how to build a RPi.GPIO version for the M2+. In the Raspbian image the RPi.GPIO module is already installed but only as a compiled version. I’d like to rebuild it for 2 purposes:
- build it for python version 3.8 and higher.
- to be able to use it in docker containers, as copying the current version into a container gives the runtime error
This module can only be run on a Raspberry Pi!
I’ve tried this version GitHub - LeMaker/RPi.GPIO_BP: This a modified version RPi.GPIO for Banana Pi. But no luck: setting pins doesnt result in an error but apparently the addresses are wrong as no effect can be seen (with gpio readall)
Is the package somewhere on github available? Would you have any other idea on how to overcome those problems?
Thanks Lukas
