With a Raspberry Pi (raspbian), when one adds a port expander (like an i2c mcp23017), one can use dtoverlay to load a device tree which will load and configure the device driver to make the additional GPIO pins become available under sysfs (/sys/class/gpio). What does one do under Armbian Focal?
overlays that exits are available in armbian-config -> system -> hardware
Not partitularly helpful. /boot/dtb/overlay does not exist – I cheated and looked at the source code for armbian-config – I don’t really want to manually use armbian-config for this sort of thing – I want something I can include in a script.
I guess what I am looking for is the source code for overlays for armbian for the M64. Where is that?
Check if this helps you:
OK, that looks like it will be helpful. I need to create an overlay for the mcp230XX chips – I think I can craft something using the sunxi-DT-overlay repo and the Raspbian overlays as a guide.
