3D-Printed case for BPI-R4: wind tunnel cooling, USB serial, wall-mounting option
Features
  • Wind tunnel cooling design with 2x40 mm fans.
  • Swappable bottom for shelf-top or wall-mounted installation.
  • Easy access to the devices installed in the bottom M.2 and miniPCIe slots.
  • Cutout for the boot switch.
  • Can accommodate different antenna configurations (or a purely wired version) thanks to the “invisible” SMA cutout plugs.
  • 4x3 and 5x3 antenna arrangements supported, up to 16 antennas total.
  • 2xSFP and 2.5GbE versions of the BPI-R4 supported (see printing guide for caveats).
  • BPI-R4-NIC-BE14, BPI-R4-NIC-BE19 (preliminary) and third-party wireless NICs supported.
  • Grounding strips for the SMA connectors (DXF and bending guides included).
  • Integrated TTL to USB Type-C adapter (see BOM for the specific part).
  • Cable holders for RG178 and RG316 pigtails.
  • Provided as STL, STEP and ready-to-print .3mf files.
  • Scripting and wiring instructions included to drive the fans from the GPIO header and tie PWM to multiple thermal sensors.
  • This model has been extensively prototyped and successfully printed in PLA-CF on the Bambu Lab P1S with a 0.4mm nozzle.
All the necessary files, BOM, printing and assembly instructions are available on my MakerWorld page. This has been a huge undertaking for me, and I hope other people find the result useful. Feel free to comment and make suggestions for improvement.
P.S. The guy who did laser cutting for me somehow managed to mess up the dimensions of the grounding strips, as seen in the pictures. The DXF drawings are still correct.
Change log
v.1.1.0
  • Added back plates for the 2.5GbE version. Can’t test for fit, as I don’t have a 2.5GbE version to verify dimensions. Adjust the STEP file if necessary. There’s also not enough room to use the PoE module and TTL to USB adapter in the same device and I gave up on finding alternative placement for the adapter.
  • Corrected an error which made one of the baked-in support fins on the back plate disconnect from the model after slicing.
  • Revised and expanded documentation.
v1.2.0
  • Added part variants for the 5x3 antenna arrangement.
  • Added printable washers for SMA connectors.
  • Restored supports for the back plates, some of which were missing in v1.1.0.
Good morning, great work. I have a few questions.
  1. Can you input the temperatures you get from all the sensors?
  2. Can I change the antennas like this?
antenna placement
  1. What’s the price if they do it for you?
  2. How much has the noise changed compared to the original Banana Pi R4 box?
Thank you for your work and your explanation.
I’m glad you liked the project.
  1. Here’s the temperature during normal use as a router (Wi-Fi + 2.5GbE SFP module for uplink) with ASPM set to powersave.
  1. Yes, you can move the SMA port openings by editing the main body and the back panel in CAD.
  2. You can get an instant quote from PCBWay after uploading the parts you need. It might end up on the expensive side, but I’ve only heard good things about their 3D-printing services. Another possibility would be to find a person with the same printer I used or a similar one (thankfully, Bambu Lab devices are quite popular) and ask to pay for their time and materials. That way you can simply use my print profile from MakerWorld and be assured the print comes out as intended.
  3. The RPM oscillates between 50 and 70 % to keep the temps under 50 °C. I can’t hear the fans from a 1 meter distance at all. The stock SoC cooler was silent for me, too, though.
Good afternoon, thanks again for your explanation. With 2.5GB, I had temperatures of 40 degrees, with 5GB, I got 50 degrees, and with 10GB symmetrical, which is what I have contracted, I get 63.5 degrees. Before, I got about 68 degrees. But with the latest modification, these are my 24/7/365 temperatures. The temperature in pink is 10Gb XGS-PON ONU SFP 8311-was-110, which is the one I use for the fiber that brings home. XGS-PON ONU SFP+ Stick with web management MAC 10Gbps SC/APC 1270/1577nm -40 to 85°C Industrial grade SMF 10G/10G XGSPON ONT.
I’m leaving you an image of the temperature of the main router in the house.
But I really like your box, and I’ll ask around my city, since they do 3D work, how much it would cost.
Thank you so much for your work
I like what i see! , i wish this was the main case design
It looks beautiful! how are you powering the fans?
Check the link to the MakerWorld page. There are detailed instructions on wiring the fans.
Big thanks for doing this. This looks amazing. Smart idea to include the serial to USB Adapter. And that heatsink for the wifi NIC looks crazy good and effective.
This case looks amazing!
Only one thing (of course :smiley: :wink: ) it looks like the space between CPU and case is very small. Did you have a heat sink at the cpu? I also use a 5g modem which gets very hot, without a heatsink this is not possible. If the board and the fans would be exactly in the middle than you would have enough space for both sides.
The antenna ground and the port for UART is a very nice idea :slight_smile:
This as a metal case would be brilliant :smiley:
There’s 22.8 mm of clearance between the PCB and the case on the SoC side (not counting the SoC package height). This is plenty for a 15 mm tall heatsink, which is what I used.
Of course for the cpu, this is not the problem, but the 5g modem on the m2 socket is about 1cm above the board. But maybe with the airflow is enought :thinking: the queltec rm520n gets about 60 degrees without heat sink (75 is allowed max) :thinking:
However, @sinovoip should get inspired by your case design :wink:
A 5–7 mm tall copper heatsink for the modem should, hopefully, be good enough. I’m going to try it with a 4G modem, which I bought recently, and see how it goes.
This case design is very good and i think it fits nice to the board design. Left fan is blowing above sfp and cpu, right fan above modem and ram. So with a tiny heat sink it should be enough (it’s just cause i have 11mm copper height plates at home :rofl: )
This case gives me a lot of inspiration :smiley: Best solution would be to combine modem and cpu heatsinks somehow :thinking: (saw that long time ago with a round copper bridge for an asus mother board to cool north and south bridge with one heat sink)
Are the fans screwed? Or only fixed by the case? Cause something like a optional dust filter would be also a very special feature i think :smiley:
Each of the fans is slotted into its own holder, which secures it horizontally, then the studs sticking out of the bottom part keep the fans from moving vertically. So, no screws. Dust filters would be a good addition, I’ll give it a thought. Thankfully, the holders are slightly oversized, so they could accommodate a very thin mesh. Better yet would be to make circular 3D-printed frames for the Noctua fans, which would hold a mesh (like a window fly screen) and sit flush agains the surface.
Would love to see a way using a dust filter :slight_smile: maybe the space is enough to use a dust filter with a small metal mesh
https://www.amazon.de/XINGLIDA-Staubfilter-Computer-Schwammgewebe-Schwarz https://www.amazon.de/YEYONG-Staubfilter-PC-Gehäuse-Staubschutz-Staubschutzabdeckung https://www.amazon.de/YIMATEECO-Gehäuselüfter-Lüfterabdeckung-Netzabdeckung-Schutzgitter/
Good day, great job.
I am printing your model and a question arose, could you model Plate 2 - Back for 2.5GbE and 2.5GbE + PoE versions?
I was considering doing that after buying a 2.5 GbE version, but I ended up getting another 2xSFP+ and can no longer verify the dimensions of the back panel for tight fit. If you have one on hand, you can actually help with that by measuring the width of the 2.5 GbE connector housing and the height (from the PCB or together with the PCB) as accurately as possible with calipers. The official DXF is of little help here, as the manufacturer can change parts suppliers freely.
If you can, and doing custom case, you can and make special pockets in side walls, avoid antena cables going across the PCB, route those straight over the edge and then to the connector.
This is a neat idea. But in this case, the pigtails absolutely have to be facing away from the Mini PCIe connectors to avoid picking up RF noise from the main PCB.
Cool design!
I’ll attempt the project very soon, just one clarification. You mention to source “2 × Noctua NF-A4x20 5V PWM”, but these are 4-pin fans, and in the guide you only say to plug 3 “The fans can be connected in parallel to the GPIO header instead; pin 4 is 5V, pin 6 is GND, and PIN 7 is PWM;”.
Are you using an adapter from 4 to 3 pins?
