we are using 2020-04-10 update Raspbian Stretch, kernel 4.4 image in this operating system we can’t operate any ethernet module(like enc28j60,w5500) and we have also tried 10/100 ethernet port which is given on onboard banana pi PCB.
Hi @abhishekmakwana,
I have same problem.
Same setup amd Kernel.
I think all the typical configurations have been correctly set,
the SPI is enabled and wiring connections are good.
But it seems to that the driver that allows the w5500 to work is missing.
Has anyone succeeded?
Or do you have any advice on this?
Thanks in advance
