BPI-M1/BPI-M1+ New Image:ubuntu-16.04-xenial-minimal-preview-bpi-m1-m1p-r1.img 2016-07-10
(bpi team) #1
2016-07-10-ubuntu-16.04-xenial-minimal-preview-bpi-m1-m1p-r1.img.zip
run on BPI-M1:
run on BPI-M1+
  1. based on ubuntu 16.04 xenial ubuntu-minimal.
  2. BPI-M1 / BPI-M1P / BPI-R1 u-boot-2016.05, kernel 3.4.112 (based on armbian’s build)
  3. username & password: pi/bananapi , root/bananapi
  4. support HDMI 1080P & 720P(default)
  5. support GMAC
  6. support WIFI (module only, no wireless tools)
  7. support SATA
  8. support bpi-bootsel cmd can switch to (bpi-m64 & bpi-m3 & bpi-m2 & bpi-m2p & bpi-m1-m1p-r1)
  9. support boot.scr (boot.cmd) to fatload script.bin & uImage & uInitrd
  10. support boot.scr to set video 1080P & 720P & 480P …
  11. based on armbian’s build env. & rootfs, thanks for armbian (http://www.armbian.com)
  12. github from https://github.com/igorpecovnik/lib by armbian’s work
  13. special thanks for linux-sunxi’s work (https://linux-sunxi.org)
Google Drive:
https://drive.google.com/file/d/0B_YnvHgh2rwjUXFrU0ZDX3Z2NlE/view?usp=sharing
MD5: b900b9ba3b0f664a2cfae1fa1146b2fa
this image also can boot on armv7 raspberry pi 2 armv8 raspberry pi 3 ,but not support armv6 raspberry pi 1, not include raspberry pi kernel module, so just for boot test.
#2
Hi! Can you explain how to install drivers for wifi usb stick realtek 8188 on this distro?
(ivan liao) #3
Hi there,
My M1+ cannot get wifi work. ifconfig shows wlan0, and when I connect to my AP, it ask me to enter my password, after I entered password and click connect, it will show the enter password window again later. How can I get WIFI work?
#4
Are you sure that use this image? Because there is not any window, unless you install some desktop environment. And anyway… if you see your access point - wifi works.
#5
Hi, quick question, out of the box SSH is disabled, how can you enable this during flashing? I’m doing this from a windows machine.
Update: I found a thread here BPI-M1+ Ubuntu 16.04 (Xenial) that recommended to use Armbian, seems compatible with Banana PI M1/M1+.
Best Regards, Glego
